You're correct, I think the rule of thumb when switching from two to three blades is to drop an inch diameter to get the same loading. I was taking that for understood, sorry. What I was getting at is that even when you equalize the loading by dropping the inch, the extra blade creates more thrust at the expense of more drag from the extra blade. In theory that would give you more pull in tight maneuvers and less straight line top speed.
In reality it's not that simple and some field experiments are in order to see what the actual results are from the change. I've seen it work good in some applications and be unflyable in others. |
New Zealand, Waikato, Hamilton
Joined Aug 2005
I think Jim I will stick with the two bladed prop.. I have the wing finished and the fuselage, all I need is to install the electrics, I found a little trick to the whole thing, use 24 hour epoxy and it makes you build sloooow which means you dont tend to rush and make mistakes...............like today's effort was to glue the nacelles in with the motors........
Joined Aug 2005
and yes you are so correct
Im going to sleep on it but are considering using some balls and links from my parts box (i fly helis too) to space them off the motor a little I will let you know if it works |
Now that you mention it, I think I remember having to raid my screw bin as well. I'm so used to changing a few things out in included hardware bags, I guess I didn't think much of it and didn't mention it in the article. Most of the hardware was just fine though which is a plus. Let me know how it flies.
Joined Aug 2005
Will do that mate I also had the small brass pin/clamp for the nose wheel not have a threaded hole to clamp the control rod........fixed with a 4 mm tap but and is a small thing but still a real pain to sort out considering what the part is worth .......but its STILL an awesome plane....taxied around the lawn on Friday and the sound of those two motors resonating off each other was awesome
Joined Aug 2005
I have heard a few folks talk about tuning issues with twins and resonance well im just about ready to get things going (winter here) and our local hobby shop told me to avoid tuning problems mount the motors with the heads not vertical but slightly pointing outwards like a "V" he said to me with twins you can get both resonance issues and tuning issues with both motors , another point did you tach both motors wide open or not bother?
| Thread Tools | |
| Article Multiplex Twinstar II Review | gwh | Electric Plane Talk | 13 | Apr 28, 2009 03:05 AM |
| Article Hobbico's Phoenix Strega ARF Review | therotund1 | Fuel Plane Talk | 4 | Jan 22, 2007 04:34 PM |
| For Sale NIB Hobbico Twinstar 25 ARF | rheumatical | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 13, 2006 12:51 PM |
| Hobbico Twinstar 25 ARF: G to E Conversion | Gary Warner | Glow to Electric Conversions | 12 | Aug 04, 2005 07:55 PM |
