Old May 31, 2005, 02:25 PM
Munch is offline
Find More Posts by Munch
El Cajon, CA, USA
Joined Feb 2001
Question...lipolys and the bottom line.
Ok. I've flown and read a fair amount about Lipolys for the past 2 years. I've looked at graphs and think I've got a handle on things but I am curious.
If I follow the steps below is it safe to assume I am not "hard" on my Lipoly's?
1. Put your motor/batt on a whatt meter and ensure you arn't exceeding the rated amp draw for the pack.
2. Set your speed controller to cut off at 3.3 volts/cell.
Is it that simple or am I missing something?
Daniel
Munch is offline Find More Posts by Munch
Old May 31, 2005, 02:28 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I'd say 3v per cell is OK, and run at 75% of manufacturers continuous as your 'peak' rating..
Old May 31, 2005, 02:38 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
have good cooling for them. like vintage says avoid the max peak recommended, and continous operation is hard even then. I like to avg a 10 min flight and put back about 75% of the rated capacity during the recharge. Thats around 4.5C. This will provide a decent life cycle and avoid a lot of problems. The AVG is important. I like the newer cells as they can withstand higher discharges, like 10-12c, but I only do this is very short burst, again I look for an AVG discharge rate of 4.5 (75% cap/10min flight).
dave morris is offline Find More Posts by dave morris
Old May 31, 2005, 02:40 PM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Yup, 3.0V per cell is a good starting point, albeit a hair on the conservative side.
I have found that 2.8V-2.9V allows you to overcome the initial sag you get until the Li-Po self-heats a little, and the voltage recovers. (only really relevant for EDF's and other high-load 'planes which need 100% power for the first 30s of flight)
Keep in mind that 2.7V is a universally accepted cut-off voltage published by Panasonic, Sony, etc.
Also, if you fly at say, 5C or higher, you will have substantial reserve capacity at lower power settings as the Li-Po voltage is proportional to load. (for example, a 10C cut-off at 3.0V/cell has nowhere near depleted the cell...)
Fun!
meteor is offline Find More Posts by meteor
Old May 31, 2005, 03:06 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Fun!
That depends on the LiPoly cells in question.
Have a look in the Battery Graph Valut at the TP ProLites. They will deliver high voltage and near maximum capacity even at 13C loads which will deplete the packs even at 3 v LVC to the point there is very little bounch back.
The newer generation cells from TP,Apogee,Tanic,Etec, and PolyQuest all carry a minimum 3.0V LVC recomendation for good reasons.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Bottom line....Aiptek or GSmart Mini 3? Danny Troy Aerial Photography 15 May 16, 2003 10:05 AM
CARGO, bottom line? megawatt Foamies (Kits) 33 Sep 17, 2002 04:38 PM
Micro flight - the bottom line aeronutz Scratchbuilt Indoor and Micro Models 8 Dec 31, 2001 12:29 PM
Kwik-E Question: Where Does the Line Start? Brian Nixon Sport Planes 53 Dec 14, 2001 04:01 PM
T-33 What's the bottom line? JIMFRISKY Electric Ducted Fan Jet Talk 1 Aug 01, 2001 12:26 AM
