Old May 30, 2005, 12:23 AM
Charley is offline
Find More Posts by Charley
Thousand Oaks, Ca
Joined Jan 2002
Rave
15 gm Lazer 200 w/Plantraco radio
Just flew my 14.8 gram Lazer 200 with Plantraco radio .Rudder,elevator and throttle.Motor is 7mm direct drive with one of Matt's props.Flys well but needs a little more dihedral.Made from a foam hand toss glider.(Tiger Co. is out of business)
Matchlessaero is correct -this aircraft is a Lazer 200
Chuck Haverlah
Charley is offline Find More Posts by Charley
Old May 30, 2005, 12:30 AM
Plantraco is offline
Find More Posts by Plantraco
Plantraco's Avatar
Saskatoon, Canada
Joined Jan 2003
Originally Posted by Charley
Just flew my 14.8 gram Extra 300 with Plantraco radio .Rudder,elevator and throttle.Motor is 7mm direct drive with one of Matt's props.Flys well but needs a little more dihedral.Made from a foam hand toss glider.(Tiger Co. is out of business)
Chuck Haverlah
Oh man that plane is cool!
Plantraco is offline Find More Posts by Plantraco
Site Sponsor
Old May 30, 2005, 10:26 PM
matchlessaero is offline
Find More Posts by matchlessaero
matchlessaero's Avatar
Tennessee/Mid-South US
Joined Mar 2002
Great looking little project...
BTW, that is a Lazer(200 I think), done in Leo Loudenslagers colors.
matchlessaero is offline Find More Posts by matchlessaero
Old May 31, 2005, 12:21 AM
Charley is offline
Thousand Oaks, Ca
Joined Jan 2002
Thanks Matchlessaero - You are correct
Thanks you - I stand corrected as you are correct !!It is a 200 and the pilot is Leo Loudenalager, " Champion of Chamions" per the documents with the foam glider kit.They even tried to printed his name below the cockpit but it is not readable.
You have good eyes and knowledge!!
Thanks for the correction.
Chuck Haverlah
Old May 31, 2005, 12:33 AM
Amp User is offline
Find More Posts by Amp User
Amp User's Avatar
Joined Feb 2005
erm, so did ya hang it on the prop yet ? Next is ailerons ? 1:1 thrust ratio ?
lol of course not but hey geeeeeez times are changing wont be long now woohooo! Full 3D flight sub 1oz should be possible.
Well done Charley!!!!!!!
Amp User is offline Find More Posts by Amp User
Old May 31, 2005, 12:54 AM
wannafly1 is offline
Find More Posts by wannafly1
this place rocks!!!
wannafly1's Avatar
albuquerque,nm
Joined May 2005
quik question how do you measure how much thrust you have
wannafly1 is offline Find More Posts by wannafly1
Old Jun 01, 2005, 12:29 AM
jay flay tway is offline
Find More Posts by jay flay tway
Tryin 2 get in2 slot cars
Viktoria, British Kolumbia, Kanada
Joined Feb 2005
I don't know if this would work for measuring static thrust, but...
attach the plane to a scale with the prop pointing upwards and turn on the motor, then put standard weights on the scale till it reads 1 gram, subtract one gram.
Or attach the whole plane to a stick (the longer the better) and hold the stick at the other end to keep it straight but free to move up and down.
Take a piece of lead or something else heavy that weighs at least 3 times as much as the plane and alternately tape it along the stick until it's at the point that the stick stays horizontal. Do a little algebra to figure out the thrust.
I'm sure others have much better ways. I haven't tried these ways myself.
jay flay tway is offline Find More Posts by jay flay tway
Old Jun 01, 2005, 07:15 AM
Joined Mar 2002
Doesn't look like a prophanger to me, but it sure does look like a nice little flyer.
Did you happen to trace the foam before assembling it? It really does look like it would fly well on ailerons and elevator.
Any chance of seeing your gear installation? It looks very clean.
Old Jun 01, 2005, 09:56 PM
Charley is offline
Thousand Oaks, Ca
Joined Jan 2002
To : Wannafly1
I do not measure static thrust anymore. Stopped measuring static thrust several years ago as I found I usually had only 3 to 5 props that seemed to be the "looks about right to me " size. So I just check Gordon Johnson's data on small motors and bench check the current draw at 4 volts with several props and if reasonable go fly with one. Then change to different props in the field to see if I can find the best.
At this time the direct drive small props seem to be the following:
(Listed in no specific order)
1- U-80
2- GWS 2.5 X .8
3- GWS 2.5 X 1
4- AeroX blue prop (very small)
5- GWS 3 X 2
6- GWS 3 X 3
7- Several 65 mm black props - from B2 bomber and blimps
IMHO this is not to many to chose as direct drive usually seems best with props less than 3 inch dia.
To : Matchlessaero
You are right- It is a good flyer but not a prop hanger!!!
I did not trace the foam as I have several others I have not cut out.
Yes - think it might be better on ailerons and elevator-as the turns are somewhat flat-I hope to do that soon.
I do not have a camera that does good closeups; so will try to describe the installation.
1- motor is 7mm orange hopup from Toys-R-Us
2- prop is one of the 65 mm black "blimp" or "B2" or special "Matt" prop-all fly well
3-900 recr with battery attached are just aft of motor and against the leading edge of wing
4-Two mag Plantraco actuators under wing. Actuators first mounted on 3/32 square inch spruce stick about 3/4 ' long.Mounted at right angles to each other to provide centering.A hole and a slot were cut in the fuse with the slot just under the trailing edge of the wing.The hole was cut appox 3/4 inch ahead of the slot for the rudder actuator and the elevator actuator slipped in the slot.A very small brass screw through the fuse and into the spruce holds the actuators in place.The pushrods are .020 inch brass rod( Heavy but quick to build)Control horns are 1/32 plywood.
Old Jun 05, 2005, 05:18 PM
Team3D is offline
Find More Posts by Team3D
Joined May 2005
That is an great idea After seeing this thread I ran down stairs and
grab some depron and make an 11 inch wingspan Edge 540T. I am planning
to use for an motor is the hop-up motors that came with my ZipZap rc
car.My goal is to make an airplane this size fly 3d. This thread convinced
me to try it.
Thanks and great plane and thread
Edit: Question, is there any micro 4 channel recievers I can get out there
to use on my plane????
Team3D is offline Find More Posts by Team3D
Old Jun 06, 2005, 07:38 AM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
me to try it.
Try this:
http://www.bsdmicrorc.com/productDet...86&catID=10002
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Jun 07, 2005, 06:20 PM
Team3D is offline
Joined May 2005
I getting close to the test flight I decided to go with an 3 channel.
I am going to use (ailerons, elevator, and throttle). I decided to use no
rudder. I have the motor installed and I am using 2 small actuators I found
hanging around in the basement including an reciever I found also in the
basement.I know it won't fly 3d ,but I hope it will do loops,rolls,fly inverted,
and ect....
Sold Extreme Flight Extra 300 w/Hacker A-30-16 and ESC. Free shipping!! ronrandle Aircraft - Electric - Airplanes (FS/W) 5 Mar 26, 2007 10:27 PM
For Sale Goldberg Extra 300 w/ Saito 150 and more... wannabe Aircraft - Fuel - Airplanes (FS/W) 2 Jan 18, 2006 01:02 PM
FS: 1.20 Size ISC Extra 300 w/ Moki 1.35 WreckRman2 Aircraft - Fuel - Airplanes (FS/W) 1 Apr 14, 2004 03:35 PM
Corona w/ Mega 16/15/3 and Hughs 300 Canopy Gil Weiss Electric Heli Talk 16 Sep 03, 2003 05:39 AM
DAW Extra 300 w/Hacker Power... TedLarson Foamies (Kits) 5 Jun 19, 2002 08:52 PM
