Charles |
Space Coast
Joined Oct 2000
Ok it was a 2 cell 1500 Kokam pack and was in a small First Alert firesafe. I take all the packs out of the safe and only keep the cell being charged in the safe. That being said I believe I had checked to see if it was reading correctly and I did so as I noted in my log with the voltage. I log every pack I use. What plane, what pack number, charging current, starting voltage. At the field I note the temp of the pack and the motor after the plane has landed. I like the fact I can get a running idea if a problem is occuring or not with my planes and how many times I have used a pack.
I now believe the problem was caused by a voltage tranient or momentary power drop that caused the cell miscount to happen between stage 1 and 2. I use the Astro power Supply and I had charged a number of cells since the problem occured without any problems. Perhaps a change can be made to halt the charging process if a tranient happens or surge. Thanks for posting and happy I have helped some people. I try to be safe but.... things can still happen. John F. Clarke AMA 9473 |
| Thread Tools | |
| Is it normal to have spark for Lipo?? | yikan | Batteries and Chargers | 3 | Oct 24, 2004 08:31 AM |
| GWS ESC safe for LiPo? | 4throttles | Batteries and Chargers | 15 | Dec 01, 2003 08:08 PM |
| Hey Hippo... Do you have plans for..... | Tram | Foamies (Kits) | 22 | Oct 18, 2003 10:18 PM |
| Whats the best price you have seen for GWS flight pack? | AMTJIM | Electric Plane Talk | 7 | Feb 09, 2002 02:07 PM |
