Old May 27, 2005, 08:47 PM
may-day is offline
Find More Posts by may-day
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
anybody have any experience with OS film?
as it says...
i am building a daddy-o from some pull out plans and i am building right off the plans. it is supposed to be scaled up 200%. i am looking for really lite material and i have stumbled onto the OS film web site. claims to be .5 microns thick. probably a real pain in the ( you know) to work with. so i was just wondering if anyone has any 1st hand knowledge of the stuff.
any other covering materials easier to work with would also be helpfull. the full scale version is supposed to weigh some 254 grams. mine is on a slimfast diet until it gets down to around 30 grams. just thought some info might help.
thanks
dave
may-day is offline Find More Posts by may-day
Old May 27, 2005, 09:31 PM
vener is offline
Find More Posts by vener
vener's Avatar
Malaysia
Joined Mar 2005
ok lets see here a human hair is 100microns thick yet this OS film is .5micron thick??
and i think a transistor in a p4 processer is small
vener is offline Find More Posts by vener
Old May 27, 2005, 10:03 PM
may-day is offline
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
http://www.osfilm.com/
pretty thin stuff.
dave
Old May 27, 2005, 10:50 PM
Zlatko is offline
Find More Posts by Zlatko
My member is not
Zlatko's Avatar
Melbourne City Hlpt, Australia
Joined Jun 2004
Hmmmmm,
It looks like its about 0.8gm / square meter....
Thinest Wes-Technik Mylar is 2.2gm / square meter and is 2micron thick (0.002mm)
I guess 0.5 micron ( 0.0005 mm ) is possible .
Thanks for your find Dave.
Cheers
Zlatko
Zlatko is offline Find More Posts by Zlatko
Old May 27, 2005, 10:59 PM
RC_AV8R_181 is offline
Find More Posts by RC_AV8R_181
RC_AV8R_181's Avatar
state college, pa
Joined Aug 2002
Hi Dave,
I just covered a model with Harlan Ultrafilm, which is ~1.4um thick and 2.2g/m^2. I wouldn't recommend it for anything over 10g max. Have you considered codenser paper? It's 5.3 g/m^2 and pretty easy to work with, and it doesn't cost $32 a role. 2um mylar would probably work pretty well too, and is 3.3g/m^2.
Ben
RC_AV8R_181 is offline Find More Posts by RC_AV8R_181
Old May 28, 2005, 08:36 AM
Jerry Combs is offline
Find More Posts by Jerry Combs
is it flying time?
Jerry Combs's Avatar
Wyandotte Oklahoma
I use OS film on my indoor free flight models and it is not that bad to work with once you get used to working around the static cling problems. I don't think that you will be happy with it in your application as it is VERY fragile and tears very easily. For your use, I would use the Ultrafilm from Ray Harlan. It is slightly heavier but much more durable. For either use a spray glue such as 3M 77 sprayed lightly on your wing and stab frames and cut it out using a 5 watt soldering iron or a cautery, don't try to use a razor blade or sissors.
Jerry Combs
Jerry Combs is offline Find More Posts by Jerry Combs
Does anyone have any experience with www.parkflyers.com? randall1959 Parkflyers 16 Mar 27, 2004 05:24 AM
Question anybody have any experience with these chargers? asjeep Batteries and Chargers 4 Feb 12, 2004 12:59 PM
Does anybody have any experience with the Mega 16/25/xx series Masterpiece Power Systems 14 Oct 30, 2003 11:04 AM
has anybody had any experience with the Cobweb Flybyguy Scratchbuilt Indoor and Micro Models 10 Jun 23, 2003 07:10 AM
Has anybody had any experience with Hobby Club? tempest411 Vendor Talk 6 Feb 21, 2002 09:06 AM
