Espritmodel.com Heli Air
Old May 27, 2005, 09:58 AM
novice flyer
Dexter, Missouri
How to find Amps on can motor
How can you find amps with a multimeter on a brushed motor? Thanks
andyg is offline Find More Posts by andyg
Old May 27, 2005, 10:38 AM
Fort Worth, Texas
There are two ways you could do this. You could measure it between the battery and esc or between esc and motor. With the volt meter, you will want to set up the meter to read Amps, DC. Make sure your leads are in the right position on the meter. Then, on either the positive or negative side of ONE of the wires... you will need to interrupt the circuit. The meter will be the device completing the circuit. For example... From the ESC to motor. Take positive wire, cut it, put red lead from meter on one side, and black lead from meter on the other side. This will essentially, complete the circuit.
Here is a picture
Chris Moon is offline Find More Posts by Chris Moon
How many amps on EPS300C? Dunqun Batteries and Chargers 5 Sep 25, 2003 10:59 AM
How many amps to prop a 480 motor for? RSCherry Power Systems 6 Jun 14, 2003 09:29 AM
How many cells on 6v motor? rythmsekshun Electric Ducted Fan Jet Talk 1 Mar 16, 2003 04:42 AM
How many cells on a GWS motor? jaco Parkflyers 6 Nov 08, 2001 12:19 AM
How many amps on a S600? PunkerTFC Electric Plane Talk 2 May 14, 2001 07:43 PM
