Old Apr 14, 2002, 10:25 AM
Hammer Head is offline
Find More Posts by Hammer Head
the journey is the reward
Hammer Head's Avatar
Canada
Joined Apr 2002
WD-40 ok on electric motors?
Can one use WD-40 as a lubricant and cleaner for electric motors?
All input appreciated
Hammer Head
Hammer Head is offline Find More Posts by Hammer Head
Old Apr 14, 2002, 11:41 AM
Red Baron 47 is offline
Find More Posts by Red Baron 47
Most Exalted Windbag
Newark, DE USA
Joined May 2001
I wouldn't use it. It supposedly gums up over time. If you mention that you use it on a gun in any firearm newsgroup or forum you'll be burned at the stake.
I have a lock with 10 plastic pushbuttons on an outdoor back gate. I didn't think it would last a year. I spray it yearly with WD-40 and it's been working for over 20 years.
I just apply a small drop of good oil at the bearings of motors. I tried some of the commercial motor cleaner and it evaporated so quickly that the motor was covered inside and out with water condensed from the air.
Red Baron 47 is offline Find More Posts by Red Baron 47
Old Apr 14, 2002, 12:35 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
Try using gear oil. I also have a quesation what about the oil used for lubing sewing machines?
kushal_22 is offline Find More Posts by kushal_22
Old Apr 14, 2002, 01:06 PM
Canada
Joined Apr 2002
Thanks for the responses!!
Happy Landings
HH
Old Apr 14, 2002, 01:16 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
WD-40 is a great cleaner, but a very poor lubricant. If you use it to clean, then oil any bushings/bearings you should be fine.
Mikey-flies is offline Find More Posts by Mikey-flies
Old Apr 14, 2002, 03:07 PM
Canada
Joined Apr 2002
Thanks Mikey!
Old Apr 14, 2002, 10:49 PM
RocketRonbo is offline
Find More Posts by RocketRonbo
the correct 51%
RocketRonbo's Avatar
Rancho Cucamonga, CA
Joined Apr 2002
wd-40
Do not use wd-40 in the motor, the motor will fail. Whe the oil hits the brush it will wreck it.
I race electric r/c cars, 15 years ago i put a wd-40 label on a can of lps, (too fool competitors, it worked) when they came to the starting line they had their can of wd-40 and sprayed it into the motor and woof their motor was a dog and smoked.
kinda of felt bad not 8^)
Ron
RocketRonbo is offline Find More Posts by RocketRonbo
Old Apr 15, 2002, 12:47 PM
rojoyinc is offline
Find More Posts by rojoyinc
Piccolator
rojoyinc's Avatar
Grand Rapids, MI
Joined Jan 2002
while on the subject of motors. I read somewhere that you should break in a motor in water... it gives the impression of submerging the motor in a cut of water....
Now I'm not electrical engineer, but something about shorting out positive and negative currents in water doesn't sound wise.
Whats the story behind this and how is it done? does the motor fill with water?
rojoyinc is offline Find More Posts by rojoyinc
Old Apr 15, 2002, 01:20 PM
U2Steve is offline
Find More Posts by U2Steve
Now with more COWBELL!
U2Steve's Avatar
United States, KY, Lexington
Joined Mar 2001
Yes, there's water, water everywhere!!
It works because you only use 2 cells for break-in; at 3V, clean water doesn't carry enough current to short the motor.
Blow out the water with compressed air, hit the motor with a hair dryer on LOW for 5 minutes, lightly oil everything as stated above.
If it really worries you, spend a buck for a jug of distilled water. At 3V, it's an insulator...
U2Steve is offline Find More Posts by U2Steve
Old Apr 15, 2002, 01:53 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
The reason you can use water is not only lowish voltage, but the fact that water does not naturally conduct electricity. Pure water is an excellent insulator, it only becomes conductive when impurities are added. In addition to that remember that electricity always takes the path of least resistance, when you have a motor underwater the path through the motor is easier to transverse than the path through the water. Thus you can run motors underwater with no problem... however I wouldn't try it on somthing like a 32 cell's and an F5B motor or anything :-)
Jim McPherson is offline Find More Posts by Jim McPherson
Old Apr 20, 2002, 09:22 AM
tekochip is offline
Find More Posts by tekochip
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
Even at a short distance tap water is a few thousand Ohms of resistance (if you have a well, a little less) and that will be in parallel with the motor which will be orders of magnitude less.
Now, what the water does to your skin resistance is another story.
tekochip is offline Find More Posts by tekochip
Old Apr 20, 2002, 10:06 AM
Harry Mueller is offline
Find More Posts by Harry Mueller
Manitoba, Canada
Joined Jun 2001
WD-40 works great at getting water out of tight places....WD stands for water displacement. It doesn't work that well as a lubricant.
Harry....
Harry Mueller is offline Find More Posts by Harry Mueller
Old Apr 20, 2002, 10:27 AM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
ok, already, so we know about water and electricty, but what Good does water do inside any motor , and some of these Are sealed up right good, like , how you gonna git the stuff out if there aint no holes..........??? .......kw
KillerWatt is offline Find More Posts by KillerWatt
Old Apr 20, 2002, 10:51 AM
Willy is offline
Find More Posts by Willy
Just Mothphing around :~)
Willy's Avatar
Singapore
Joined Dec 2001
Motor break-in in water
__________________
-Ron
The motor is submerged in a beaker filled with water at a very low voltage (much lower than actual running volatge in your plane).
The purpose of water is to remove the carbon dust as the motor is broken in & the carbon is suspended in the water & after an hour, the water turns carbon dark grey in colour.
DO NOT break in an IPS motor in water, it is sealed with no air vent holes for water to escape. For the IPS you may perform dry break-in. For other brush motors that have vents, they may be broken-in in water.
Willy is offline Find More Posts by Willy
Old Apr 20, 2002, 11:52 AM
Alberta, Canada
Joined Sep 2001
Water breaking, wd-40 bath to remove water and prevent oxidation or sedimentation during drying, then oiling with a light machine oil on any bushings etc. Optionally you may want to use some kind of lubricating contact cleaner on the com (caig labs has some good ones). Dry bushings can be a premature source of failure when the motors are pushed, and yes you don't want to just spray with wd -40 and go! It will dry out all the lubrication and can gum up the motor if it is run while the wd is wet. (heat seems to be bad)
Discussion Great prices on electric motors, LiPo & Esc. WinTech Motorcycles 5 Feb 27, 2006 12:03 AM
FAQ on electric motors/batteries? asennad Beginner Training Area (Aircraft-Electric) 3 Mar 11, 2004 10:47 PM
Book or Article on Electric Motors, Batteries & Controllers DanS Batteries and Chargers 3 Feb 16, 2004 07:47 AM
