Old Jun 06, 2001, 02:30 AM
Will Chapman is offline
Find More Posts by Will Chapman
Son of Jet Jockey
Will Chapman's Avatar
Redmond, WA (60 Acres Park Flyer)
Joined Apr 2000
Tail feathers help for my Pico J-3 Cub Fuse?
That horizontal stab in my J-3 Sub Fuse seems super weak! Can I strengthen it somehow? Should I use a dowel or carbon rod/tube attached to the moving surface at the hinge line?
I can't use the bamboo sticks. We had shish-kebabs last night and the teriyaki soaked in a little too deeply and now they're all sticky.. ;P
--Wondering in Washington
Will Chapman is offline Find More Posts by Will Chapman
Old Jun 06, 2001, 05:04 AM
pfg is offline
pfg
Find More Posts by pfg
pfg
Vancouver, BC, Canada
Joined Feb 2001
what do you mean weak. remember this plane will fly at about 15 miles an hour, if you blow on it does the surface deform ? did you split and then tape the entire length of the elevator ? more details please
pfg is offline Find More Posts by pfg
Old Jun 06, 2001, 10:06 AM
pullin-gs is offline
Find More Posts by pullin-gs
Arlington,VA USA
Joined Jan 2001
PFG,
One of the weakest points on my PICO-J3-cub is the elevator. It got "mushy" in the 1/2" (offset to accomidate the rudder) section in the middle of the elevator. It was so bad that I had to brace it with a small piece of stronger foam in the middle of the rudder.
pullin-gs is offline Find More Posts by pullin-gs
Old Jun 06, 2001, 12:51 PM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
I modified my elevator before I ever assembled the plane. I cut a recess between the two elevator halves, and glued in a short length of 3/32" hardwood dowel, and anchored the whole mess flat on my workbench overnight. The joint is rock solid, and there is no flexing when I need elevator input.
Tony Turley
t-turley is offline Find More Posts by t-turley
Old Jun 06, 2001, 03:35 PM
Son of Jet Jockey
Joined Apr 2000
I bought some small dia carbon tubing today. Not only will it strengthen the tail, it will also replace the ugly bamboo dihedral brace sticks.
However, it is not inexpensive. At my LKS (Local Kite Shop) It runs $2.40 for a 3-ft length.
Question GWS Pico J-3 Cub different battery sizes to use..? TheDustyPagan Parkflyers 2 Mar 29, 2007 11:04 AM
Sold New GWS J-3 Cub (fuse version) Etonic Aircraft - Electric - Airplanes (FS/W) 2 Sep 25, 2005 07:00 PM
Help me finish a Piper J-3 Cub Anniversary Edition... JoeVen Fuel Plane Talk 2 Mar 18, 2005 05:25 PM
my little J-3 Cub gbruce Parkflyers 6 Apr 20, 2004 09:52 PM
How does the GWS J-3 Cub(fuse version) fly compared to the Tiger Moth? mefly2 Parkflyers 7 Jun 07, 2002 01:04 PM
