Old May 25, 2005, 02:22 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Anyone have access to a GWS dragonfly and a walkera dragonfly #4?
I would just like to know if the rotor heads are interchangable... (the part you attach the blades to that pops off in a crash)
Anyone? please?
dacaur is offline Find More Posts by dacaur
Old May 25, 2005, 02:54 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Do not mix to use other than GWS original blades or parts on GWS Dragonfly.
During 2005 RCX show, I flew with Steve Lo and Jarhead, I feel the timming even longer that that I said before!
With EM150 version GWS Dragonfly, some time arround 25 minites if the mechanic in properly set up.
However, after too many heavy landing or crashed damage, the friction will eat more current and reduce you flight duration.
Pls also read about this thread: http://www.rcgroups.com/forums/showthread.php?t=366222
Although many micro helicopter rotors looks similar, but performance quite different to each others.
Do not mix to use other than GWS original blades or parts. They may cause uncompetible problems!
GWS4CEO is offline Find More Posts by GWS4CEO
Old May 25, 2005, 03:44 AM
Rickenbacker is offline
Find More Posts by Rickenbacker
Sunday Flier
Rickenbacker's Avatar
Sweden
Joined May 2005
Jesus, why is this guy even allowed access to these boards?
Rickenbacker is offline Find More Posts by Rickenbacker
Old May 25, 2005, 01:49 PM
autoair is online now
Find More Posts by autoair
autoair's Avatar
Essex, United Kingdom
Joined Jul 2004
They are completely different, bearing size and spacing, plus there is a web on the Walkera which would foul the GWS hub.
autoair is online now Find More Posts by autoair
Old May 25, 2005, 04:46 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
thanks
Old May 25, 2005, 09:27 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
The gear ratio and motor design are totally different to each others!
I did test with Walkera and Jabo main rotors to be fit on GWS Dragonfly some time ago.
I had seen that the gear ratio and motor design are totally different to each others!
GWS current production of Dragonfly EM300H version which come with the main rotor from FEDA takes 3.6A at 260g lift. The GWS new rotor take only 3.1A.
When Max thrust FEDA rotor get 350g while take 6.4A. GWS new rotor max thrust 380g but takes only 5.9A.
But the test datas had shown they are not fit into GWS Dragonfly!
W brand takes 7.6A at max but only 290g lift thrust for GWS Dragonfly EM300H version.
J brand takes 7.4A at max but only 290g lift thrust for GWS Dragonfly EM300H version.
I just instruct GWS RD also should try to find a Walkera, E-Sky....others helicopter to see how a GWS main rotor balde will perform on them?
Discussion Anyone have a photo of a Super Dragonfly? BrentB Slope 9 Jan 28, 2007 08:25 PM
Anyone Have problems with Dragonfly #4 mixer/gyro/esc board? haddorh Micro Helis 1 Jan 08, 2005 08:12 AM
WTD- Anyone have a couple GWS Pico or Naro Rx's (neg shift)?? Etonic Aircraft - Electric - Airplanes (FS/W) 4 Mar 05, 2004 02:26 PM
Does anyone have MPJet GWS Zero? Beaver-man Parkflyers 1 Sep 24, 2003 05:25 PM
Anyone have any GWS pico gearsets??? JStory Aircraft - Electric - Airplanes (FS/W) 4 Mar 19, 2002 10:32 PM
