Old Apr 13, 2002, 08:15 PM
fprintf is offline
Find More Posts by fprintf
[intentionally blank]
fprintf's Avatar
Cheshire, CT, USA
Joined Jan 2001
Flying on the cheap - what to use for control horns and rods?
Ok, I have built my Zagnutz and installed my radio gear. I am going flying tomorrow and the hobby shop is closed - what do you guys use for control rods and control horns?
After trying some leftover household wiring (it is pretty stiff) I determined that it was just a little too flexible. So I cobbled together some leftover dubro pushrods and parts to the appropriate length. For a control horn I have made a 2 ply 1/8 (times 2) balsa square that I epoxied onto the elevon.
So what are you guys using? Or do you just suck it up and go to the hobby shop and buy proper control horns and music wire?
p.s. what is the easiest way to make z bends in wire? It was really tough using two pairs of pliers, even though I eventually made some pretty ugly looking bends.
fprintf is offline Find More Posts by fprintf
Old Apr 13, 2002, 09:36 PM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
Use "real" hardware.
Seriously, you can make wood control horns, but make them out of light ply. I wouldn't trust balsa, it's just too soft
You can use short pieces of stiff wire (like from the hobby shop ) to make much longer pushrods. Just use hardwood dowels with a hole drilled through. A 90 degree bend with the wire through the hole. Chamfer out a trough in the dowel to lay the wire in, then use common thread and CA glue (or epoxy) to attach the wire to the wood.
DBCherry is offline Find More Posts by DBCherry
Old Apr 13, 2002, 09:42 PM
DBCherry is offline
Worcester, MA.
Joined Nov 2001
"Z" bend with ONE pair of pliers.
Hope you figure out my sketch.
Old Apr 13, 2002, 10:16 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
1/32 or 1/16 ply will do just fine for a small to medium airplane.
BEC is offline Find More Posts by BEC
Old Apr 13, 2002, 10:56 PM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
I've used an old credit card cut into thin strips
Philip
fill is offline Find More Posts by fill
Old Apr 14, 2002, 12:48 AM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
I have also used OLD bicycle spokes for pushrods. It all depends on how far you have to go. Also the wooden BBQ shishka bob skewrs work well.
kushal_22 is offline Find More Posts by kushal_22
Source for control horns mluniewicz Foamies (Kits) 11 Mar 24, 2002 11:11 PM
What to use for Battery connectors joegib Beginner Training Area (Aircraft-Electric) 4 Oct 18, 2001 10:15 PM
