Old May 24, 2005, 10:53 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Just picked up an Astro 109.. DOn't wanna burn down my house. ;)
OK guys..
I'm about to charge some packs...
Lipo's should be charged at ~1c of their maH right?
So a 2480 pack should basically be charged at 2.5 amps?
and a 2100 pack should be basically charged at 2.1 amps?
Regardless of #s#p it's the total maH that determins the rate of charge right?
Like if I had a 4S2P 6000 I could charge at 6 amps?
I just don't wanna burn down my hacienda..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old May 24, 2005, 11:00 PM
Daniel G is offline
Find More Posts by Daniel G
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Yes, lipos should be charged at 1c.
Daniel G is offline Find More Posts by Daniel G
Old May 24, 2005, 11:19 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
You got it! And your going to like your 109.
I am sure you know this, but watch the first 3 minutes through phase 1 when charging. Make sure the correct number of cells is selected for phase 2 where # cells are locked in. I have NEVER had a problem with a wrong cell selection, but others have. And never charge an already charged pack! Always start the charge with 0 amps selected and then turn up the amps to 1C after noting the pack voltage. Also, LiPo packs don't need peaked ... ever ....
Love my 109. Just ordered another for a new EP flyer (formally glow) who wants to go LiPo from the start (over all my concerns about a newbie starting out with LiPo ) .
[edited] Actually you should say rather LiPo packs can be charged "UP TO" 1C . 0.5C would work just fine ... just take longer . That said, I always charge at 1C . So far that has worked great for me .
rclark is offline Find More Posts by rclark
Old May 24, 2005, 11:29 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Well.. I started E flying with lipo's from the start.. This is the first charger I have gotten that is selectable.. The rest of my chargers are apache 2500's..
Old May 24, 2005, 11:37 PM
ShamelessMale is offline
Find More Posts by ShamelessMale
In need of a new name...
Clarkston, MI
Joined Dec 2002
Sorry for hijacking your thread, my bad.
If lets say that 95% of Li-Poly errors are started by user error (setting the charger to Ni-Cd, not selecting the correct number of cells, or abusive treatment), why would you suggest a newbie learn bad habits from Ni-Cds before switching to Li-Poly?
Wouldn't encouraging a newbie to build up a large collection of Nickel cells that he can't afford to give up when eventually making the switch to Li-Poly be the worst possible outcome from a safety standpoint?
Once again my apologies, just feeling anti-social for some reason tonight!!!
ShamelessMale is offline Find More Posts by ShamelessMale
Old May 24, 2005, 11:39 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
YOu are in need of a new name.. I thought it was ShamelessSheMale for some reason.. Soo many SS's I guess..
I understand your logic about Lipo's though.. I think a compotent adult will be fine with lipo's..
Old May 24, 2005, 11:44 PM
Clarkston, MI
Joined Dec 2002
I really should change that name, someone gave it to me 12 years ago in a different kind of forum. I just wanted to ask a quick question here a few years ago and used the name I have. Still here, go figure!
Old May 24, 2005, 11:50 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Hehehe..
Old May 25, 2005, 02:31 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I have found that sometimes its quicker at a bit less than 1c.
This allows the Astro to stay in phase 2 a bit longer...
Old May 25, 2005, 09:50 AM
Daniel G is offline
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Interesting, vintage 1, I've never tried that.
Old May 25, 2005, 10:09 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
AF 109 Very Effective LIPO 1C Fast Field Charger
SLOW CHARGING
But if U want even better duration and full power performance, there is no other better way than a FIXED REGULATED VOLTAGE SUPPLY CURRENT LIMITED THRU A 12VDC 50W HALOGEN BULB charging at around 200-1000 ma for at least 2 hours or more
Even works on NMHIEs
I use a surplus switcher
BEST WAY IS STILL THE CHEAPEST WAY, Imho
hall woo is offline Find More Posts by hall woo
Old May 25, 2005, 10:21 AM
Daniel G is offline
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Hall woo: how do you keep from overcharging the lipos?
Wouldn't they explode?
Old May 25, 2005, 10:34 AM
hall woo is offline
Permanently Banned
Joined May 2003
$1.00 12 VDC 50W Halogen Bulb and Whattmeter
Is used to control charge current and whattmeter used to check voltage and 100% charge zero charge current condition
Its been and still working for the last 3 months.
Getting spectacular results , even on salvaged packs
Old May 25, 2005, 12:41 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Competent adults will be just fine with LiPos as long as they follow all of the safety rules. Even competent adults occasionally make mistakes. The safety rules are designed to provide backup for those occasional mistakes that we all make.
Dave Hederich is offline Find More Posts by Dave Hederich
Old May 25, 2005, 12:56 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Hall Woo has a policy taken out with God Inc. As part of the premium he gets divine protection from folly of all sorts.
Discussion just picked up an ATC-1000 for only $15 dogon1013 Aerial Photography 11 Dec 17, 2006 10:39 AM
Discussion Just picked up an XPV bendavis2003 Foamies (Kits) 5 Oct 26, 2006 04:50 PM
Discussion I don't want to burn up my stuff EEC Power Systems 3 Feb 24, 2006 09:53 PM
Wow! Just picked up an Inferno Bipe at $50 off from Hobby Lobby Sale! mrebman 3D Flying 60 Sep 06, 2005 08:38 PM
WooHoo! Just picked up an Inferno Bipe from Hobby Lobby Sale, $50 off! mrebman Parkflyers 1 Aug 25, 2005 10:04 PM
