Old May 24, 2005, 03:41 PM
sulkul is offline
Find More Posts by sulkul
Joined May 2005
FMS: Exception EComPort...
FMS 2.0 Alpha 8.5 on computer without serial port crashes with following error:
Application Error
Exception EComPort in module FMS.exe at 0008AFEC. Registry error (win error code: 2).
You can see solution there.
sulkul is offline Find More Posts by sulkul
Old Dec 29, 2009, 11:01 AM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
FMS fixes for WIndows XP and Vista
The link in the previous post is gone. Here is what you need.
Read the file Readme.txt.
Please reply if this works for you or if you have problems, so others can benefit.
Here are fixes necessary to get FMS to run on XP, Vista (32 or 64), or Windows 7 (32 or 64).
FMS.BAT and FMS-ECOMPORT-FIX.REG are necessary for Windows XP.
FMS-VISTA.BAT, FMS-ECOMPORT-FIX.REG, and D3DRM.DLL (a file from Windows XP) are necessary for Windows Vista (or later) 64 (I think).
FMS.BAT, FMS-ECOMPORT-FIX.REG, and D3DRM.DLL (a file from Windows XP) are necessary for Windows Vista (or later) 32 (I think).
Edit: added untested Easy Star models for download.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Dec 29, 2009, 04:41 PM
TCIII is offline
Find More Posts by TCIII
Autonomous Vehicles
United States, FL, Fort Lauderdale
Joined Dec 2007
theothercliff,
Any solution using FMS on a Windows 7 OS PC and an Nvidia video card?
FMS works fine on my XP OS and Nvidia video card, but I get a flashing/flipping display when used on Windows 7 with an Nvidia video card. Turning off "texture" stops the flashing/flipping but makes for a crummy display.
Regards,
TCIII
TCIII is offline Find More Posts by TCIII
Old Dec 30, 2009, 10:19 AM
ggunners is offline
Find More Posts by ggunners
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
Flashing is a known problem documented on the FMS Forum.
You need to modify the scenery and drop the size of the bottom image to something that cannot be displayed. 1x1 or something a few pixels off of the original so it will not display.
I believe this is only a problem with Nvidia graphics cards. Check the forum.
-- ggunners
ggunners is offline Find More Posts by ggunners
Old Dec 30, 2009, 06:56 PM
TCIII is offline
Autonomous Vehicles
Joined Dec 2007
ggunners,
Thanks for the tip. Much appreciated.
Regards,
TCIII
Old Jan 07, 2010, 10:49 AM
yoramlevy is offline
Find More Posts by yoramlevy
Joined Jan 2010
works good
I'm using windows XP and the BAT + REG fixed the problem
yoramlevy is offline Find More Posts by yoramlevy
Old Jan 10, 2010, 02:11 PM
darel is offline
Find More Posts by darel
Joined Jan 2010
Dear All,
I have just received my own maiden! I am novice and do not want to harm her due to the lack of practice. I have installed the included FSM simulator software and everything works fine except one thing: I do not know how to switch of mixing in the RC transmitter. I tried to re-calibrate it with both windows and the program, but if I move the right joystick, both Ch1 and Ch2 is active (mixing). Please, help! I need training!!!
Darel
darel is offline Find More Posts by darel
Old Jan 11, 2010, 01:55 AM
darel is offline
Joined Jan 2010
FSM Mixing
I have received help from Marcello:
"There is a switch that controls the elevon mixing on the radio, but it was covered with the sticker "face" of the tranmitter (the film that says ArtTech and has other things printed. You should be able to feel the covered hole to the left of the leftmost "reverse" switch. Just open the film so you can access it and change the position. Remember to return it to mixing before flying!"
Thank you very much for this fast help.
By the way, the USB Controller work very well even with HAWX.
Darel
