Old May 24, 2005, 01:11 PM
Lynxman is offline
Find More Posts by Lynxman
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
Got my Hyperion EOS 7i charger today. Like it a lot!
I got my Hyperion EOS 7i charger today. So far I'm liking it a lot. There's not a lot of info here about this charger so here are my impressions.
A quick look through the (short) manual and I was ready to set it up for my battery packs. Setup was easy and quick, and it has ten programmable memory choices for my different packs and two non-programmable chioces, automatic Ni-Cd and automatic Ni-Mh. I can set set charging current in 100mA increments and can choose between Li-Io, Li-Po, Ni-Mh, Ni-CD and lead batteries of different cellcounts. The delta voltage is also selectable for Ni-xx batteries. The charger included a temperature probe which seems to work like it should. I didn't know about this so for me this was a bonus.
This is my first charger that will display stats and record info about the charge and I can't believe I managed without this feature before. My previous li-po charger was an Apache Smart-Charger 2500 which has worked exactly like it should but falls short now that I'm about to go up a few notches in aircraft size. I ordered two PolyQuest 4000 mAh 4S packs for a new plane and am charging one of them now.
The fan on the charger seems to be temperature-controlled and makes a relatively loud blowing noise (not a whine) while charging, at least at 4A 4S, but that's not a problem for me.
After the charge has finished there is a lot of data available about the charging process like temperatures, voltages, time and mAh put into the pack.
Lynxman is offline Find More Posts by Lynxman
Old May 27, 2005, 01:37 PM
aV8ter is offline
Find More Posts by aV8ter
aV8ter's Avatar
Alpharetta, GA
Joined Sep 2004
Do you have any chargers to campare this to?
Kevin
aV8ter is offline Find More Posts by aV8ter
Old May 27, 2005, 03:50 PM
Lynxman is offline
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
I don't have any other computer chargers. Previously I used an Apache 2500 for Li-po and a Hitec CG-335 for ni-xx.
I charged an Apogee 3S2P 1660 mAh pack yesterday which I had drained to 9V under load. It put 1610 mAh into them and it took 87 minutes with a 1.6 A charge current.
Old May 27, 2005, 04:59 PM
PerfectStranger is offline
Find More Posts by PerfectStranger
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
Everything I have that Hyperion makes is top notch. Not tons of stuff but different bits and pieces, and the EMeter. It's no suprise to me that the charger is nice also , but good to hear.
matt
PerfectStranger is offline Find More Posts by PerfectStranger
Old Jun 01, 2005, 05:36 AM
gauchers is offline
Find More Posts by gauchers
United States, CA, San Marino
Joined Jun 2003
EOS Charger
Ditto - I have been using this charger for about 3 weeks and I love it. I now use it more than my standby Schulze 330 - it's just easier to use and my side-by-side comparison has shown that the Hyperion actually charges my packs faster. Next up, I will check packs from both chargers on my CBA II and post my results...
gauchers is offline Find More Posts by gauchers
Old Jul 12, 2005, 04:32 AM
brhnz is offline
Find More Posts by brhnz
Joined Apr 2004
7I sure is better
Well the old GP triton is heading for the " Things to blow up" shelf, This EOS 7I is fantastic, for my 2x 4S packs in parallel it kicks ass! The triton took 4hrs .. Zzzzz
brhnz is offline Find More Posts by brhnz
Old Jul 14, 2005, 08:19 PM
Retro is offline
Find More Posts by Retro
Auckland New Zealand
Joined Oct 2003
brhnz
I have a the Hyperion e-Meter and an Hyperion 50 amp ESC - very very good products
I have been looking at the Hyperion Charger to supplement my Triton.
Is it just me OR does the Hyperion Charger really look like a new and improved V2 Triton in drag??
I just looked at the on-line manual for the Hyperion charger and man is it similar to the Triton manual - you then look at the display of the Hyperion - the way you navigate thru the menus etc etc...
In no way meant to be negative about the Hyperion products - just curious if you agree
Retro is offline Find More Posts by Retro
Old Jul 14, 2005, 09:16 PM
gauchers is offline
Joined Jun 2003
Hyperion is much better
I used to have a Triton. The Hyperion is far more capable - it can charge up to 5S and can pump out much higher amperage plus it can be safely used with pcm guards. Who knows what factory is making all these chargers, but there are definitely many differences in features.
Old Jul 14, 2005, 11:40 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
I am just a flyer who loves good products and good price :-)
And sure there are many good stuffs out there.
However, not to bash or support anyone,
Thunder Power has good products, agressive marketing stratergy
and great technical support. I think TP has an edge over others.
Just Like Castle Creations. People, including me, just love their great
tech support. I thought of this Hyperion charger before,
but I got the TP 425 instead, just because there is plenty
of info available about the TP charger while almost none about
the hyperion.
rcguy01 is offline Find More Posts by rcguy01
Old Jul 15, 2005, 04:00 AM
ViktorF is offline
Find More Posts by ViktorF
ViktorF's Avatar
Krasnodar, RUSSIA
Joined Nov 2004
Originally Posted by Retro
brhnz
Also I have:
- Charger
- Emeter
- ESC 10A, 20A,50A
- 2213/20 motor
- Hi-Watt GEARBOX 300
- Propadapter&propsaver
- Ultra-Micro 3.7g Servo
If not two times "very good", then once precisely.
Minus only it:
Aluminum SHAFT for Hyperion XG-300 Gearbox
Soft material
ViktorF is offline Find More Posts by ViktorF
Old Oct 02, 2005, 03:05 PM
badcockr is offline
Find More Posts by badcockr
badcockr's Avatar
NZ / Wellington
Joined Jan 2004
You've sold me!
Okay,
I was looking for a new charger for my larger packs, and needed a charger with higher charge rates than my trusty Schulze 330. You guys have sold it to me; my order is in and I'm now waiting for my shiny new EOS 7i.
All my other Hyperion gear has been excellent; I expect the same from the EOS 7i!
Rod
badcockr is offline Find More Posts by badcockr
Old Oct 02, 2005, 03:17 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
It still has a 120W maximum charge, so you can only use 7A on small packs. At full voltage, the maximum charge is closer to 3A same as the Triton.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Oct 02, 2005, 03:23 PM
Lynxman is offline
Lynxman's Avatar
Troms, Norway
Joined Jan 2004
I have used 7A charge rate on 4S2P 8000 mAh packs.
Old Oct 02, 2005, 03:28 PM
badcockr is offline
badcockr's Avatar
NZ / Wellington
Joined Jan 2004
Yep, but I went in with eyes wide open as 120W gives
5 Cell LiPo = 21V at 5.5A = 115.5 W
4 Cell or below = 7A!
Suits me at the moment! (and I still have the Schulze for charging other packs at the same time)
.... all we need now is a portable thermonuclear 12V power station in order to supply the power at the field
Rod
Old Oct 02, 2005, 03:49 PM
rpage53 is offline
Boffin
rpage53's Avatar
Joined Apr 2001
But that is a low voltage compared to 25 Ni cells and under the 120W limit.
Sold Hyperion EOS 7i Charger Dynomike Aircraft - Electric - Batteries & Chargers (FS/W) 3 Dec 27, 2006 09:03 PM
Sold hyperion eos 7i charger $90 SHIPPED kmp647 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 15, 2006 05:16 PM
Sold Hyperion Eos 7i Charger trw43 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 13, 2006 10:03 PM
Sold Hyperion Eos 7I charger dr.E Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 10, 2006 06:50 AM
Question Question about Hyperion EOS 7i charger Lou Batteries and Chargers 4 Jan 29, 2006 08:03 PM
