Joined Jan 2002
Ben, people often "instinctively" do the right things in a crisis.
Water cools things down and represses the flamability of surrounding materials. Another point: A 2s 700mah LiPo is a relatively small pack. A 3S 2100 contains six time the potential energy and a 3S is by no means a big pack, these days. Let's charge them outdoors in an open area. - RD |
Another important point is that if you use a charger like the GP's Triton be sure you have the correct battery type selected before charging. One afternoon I put a 3s 1020 pack on the charger. In a rush and with poor lighting in the shop I set the charger to PB (lead acid) rather than Lipo. When I come back later the charger had kicked off but not before swelling the pack. Discharged and scraped the pack. Hopefully lesson learned.
Electrolyte burning
I am starting to think about the batteries like a cup of gasoline covered with a plate of glass. It can be perfectly sealed and safe until the top is bumped off by a careless action. I shutter to think about what the 3200mah lipolys I have might do. No wonder things burn down. Extra smoke detectors in the garage and hobby room would seem a good idea also. They do work when there is still enough oxygen to get out of the house. |
Wiz |
Lipo just helped my truck burn down about 3 weeks ago.. Here is the post.. Check it out..
Glad you are OK. I use to be a Floor guy so that would be easy to fix or replace it all. You can just cut the bad Squares out and put new ones in. Just double cut the vinyl to get a perfect fit. If you need more instrunctions just PM me and I will be glad to help you.. GLAD you were not hurt... LATER Oh yea here is the post.. http://www.rcgroups.com/forums/showthread.php?t=368758 |
| Thread Tools | |
| My fire, my fault | No Step | Batteries and Chargers | 49 | Apr 24, 2005 01:12 AM |
| First Flight Ever, Learned Some Lessons the Hard Way | rgreene | Parkflyers | 3 | Aug 06, 2002 06:37 AM |
| Got my Corona tonight,... some questions. | Pongo | Electric Heli Talk | 4 | Jul 19, 2002 05:52 PM |
| Got my Zero! Need some advice on Rx and battery pack | cfossa | Parkflyers | 0 | Apr 01, 2002 10:37 PM |
| Setting up my second Adrenalin, some questions... | Erik Johansson | High Performance | 0 | Jul 01, 2001 04:45 PM |
