Old May 23, 2005, 02:39 AM
Texy's Avatar
Newbury, UK
Joined Aug 2002
Oveview the construction of Outrunner Motor Kit KH-278 - Part 2
....first thread can be found here :
http://www.rcgroups.com/forums/showthread.php?t=347141
Komodo hobby can be found here :
http://www.komodohobby.com/
Texy
http://myweb.tiscali.co.uk/texyuk/
Texy is offline Find More Posts by Texy
Old May 24, 2005, 04:31 PM
Roti's Avatar
UK
Joined Apr 2004
16 Turn Motors
I built two Komodo advanced N50 motors, both with 16T of #24 GoBrushless wire, I like the design nice motors.
The only prob. I had was the shaft on 1 of the motors kept coming loose from the bell ( i tried CA a few times), i have switched to trying thread lock instead now... will see what happens in next few runs. (edit: i will key the shaft up next time)
Also I prefer to fit the stator to the mount before winding (personal preference )
here is some data (i terminated one in delta and one in wye for the tests hoping that I would hit on the ideal for my application)
16 Turn #24 GB Wire
N50 Mags
CC PHX 25 ESC
TP 2100 3S lipo
Carbon Black prop is 5*5 (130*125) - Irvine E IRV0505CS
APC prop is 7*5E Thin electric - LP 07050E
APC 7*5 Wye 6A 65W 9000 RPM 350g thrust (WOT)
APC 7*5 Delta 10.75A 100W 10000 RPM 440g (2/3 Throttle)
APC 7*5 Delta 6A 65W 8400 RPM 300g (1/2 Throttleish)
Crbn 5*5 Delta 13A 135W 17000 RPM 430g (WOT)
Crbn 5*5 Delta 9.6A 100W 15300 RPM 350g
(grr looks messy, how do i do tables ??)
I think for my current build i will go for the 7*5 prop delta ( the wye is just a bit too low kV )and use throttle management yeah right
/Richard.
Roti is offline Find More Posts by Roti
Old May 24, 2005, 06:16 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
Originally Posted by Roti
... grr looks messy, how do i do tables ??) ...
The 'code' tags will give you fixed pitch characters instead of proportionally spaced characters:
http://www.rcgroups.com/forums/misc.php?do=bbcode#code
Rather neat-ish, don't you think ?
Code:
APC  7*5 Delta 10.8A 100W 10000 RPM 440g 2/3 Throttle)
Vriendelijke groeten Ron van Sommeren
e-motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, September, Nijmegen, the Netherlands
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 25, 2005, 07:14 AM
Roti's Avatar
UK
Joined Apr 2004
Thanks Ron, exactly what I was after, I probably had too much wine last night to find the FAQ section
Richard.
Old May 26, 2005, 10:17 AM
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Dear all,
The KH-278 performance data can be downloaded at this link.
http://www.komodohobby.com/download....78-website.pdf
Enjoy@@
Da V.
Komodo Hobby
Da V. is offline Find More Posts by Da V.
Old May 27, 2005, 09:44 PM
Albuquerque NM
Joined Jul 2002
loose bell
/Richard.
Have you tried the green loctite? I forget the # but it will hold a pinion on a 480 shaft so it should hold a bell. You may need a new shaft and or bell if there alot of wear.
cfischer505 is offline Find More Posts by cfischer505
Old May 31, 2005, 10:52 AM
Texy's Avatar
Newbury, UK
Joined Aug 2002
We want cheeseburgers !!!!!!
Originally Posted by Da V.
Mr. McDon Don said within the month of May....
Da V.
Komodo Hobby
Texy
Old May 31, 2005, 12:17 PM
know it all
Miami, Fl
Joined Nov 2003
Yes, where is the cheese?
Herm
hermperez is offline Find More Posts by hermperez
Old Jun 02, 2005, 03:43 AM
Specialist in Crashing
UK, Loughborough
Joined Jan 2004
I think everyone is eagerly awaiting them
saitrix is offline Find More Posts by saitrix
Old Jun 02, 2005, 06:17 AM
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
Hello to all,
We are busying for taking photo of this Double Cheese Burger...We will put them at our site tomorrow. Please keep you eyes on it.
Da V.
Komodo Hobby
Old Jun 02, 2005, 06:50 AM
UK, Loughborough
Joined Jan 2004
Da V., Brilliant news I bet they look real sweet.
Texy's Avatar
Newbury, UK
Joined Aug 2002
You could tell us the price!!
Texy
Old Jun 02, 2005, 08:53 AM
You can do it!!!
Da V.'s Avatar
Joined Mar 2005
We are very happy that Slofly sponsor Komodo Hobby 3 planes for testing our motor. We are so excited to waiting for those planes arrive. Thank you very much, Steve.
Slofly also selling our Komodo products for their local market in US.
Komodo Hobby Team
Old Jun 02, 2005, 09:09 AM
hokonghing's Avatar
Houston
Joined Jan 2002
I like the Kit,I wind 14 turn with the 24 G. wire that come with the kit, motor fire up with the first try, very good value for the money, however, I have a comment for the improvement of the kit. The bearing inetrference with the bearing tube is off, "the hole for the bearing is too large", the bearing just dropped into the hole, the wholething is held by the "C" clip at the back, and the "C" is too small, you need a large washer to retain the C clip inorder to hold the bearing. I thing the hole in the bearing tube should be made smaller, so that the bearing in press fit into the tube. BTW, I have the KH 278 delux kit.
Also I find the most difficult part of this DIY outrunners is not the wire winding part, it is the placing of the magnets and gluing them. I tried spacers with different thicknesses to space them out evenly, finally get them close enough but not perfect, Da V. may want to look into a better way to install these magnets.
My 2C.
Thanks.
hokonghing is offline Find More Posts by hokonghing
Old Jun 02, 2005, 09:35 AM
Texy's Avatar
Newbury, UK
Joined Aug 2002
Ways of installing the magnets have been discussed in part one of the thread. I just used my hands and judged by eye - not easy I admit, but not too difficult.
I agree about the c clip - far too small and very fiddly to fit.
Texy
Mini-Review New Komodo KH-278 V.2 Motor Kit Da V. Power Systems 675 Dec 26, 2007 04:11 PM
Alert Komodo KH-283 Outrunner Motor Kit Version 2 available now!!! Da V. Power Systems 612 Jan 30, 2007 11:14 PM
Alert Oveview the construction of Outrunner Motor Kit KH-278 Da V. Power Systems 515 Jun 02, 2005 11:12 AM
Alert Great News! Super Offer of Komodo Hobby KH-278 Outrunner Motor Kit Da V. Power Systems 32 Mar 31, 2005 10:51 PM
Alert Komodo Hobby e-shop - "Outrunner Motor Kit KH-278" Da V. Product Announcements 2 Mar 15, 2005 09:39 AM
