Old May 22, 2005, 04:30 PM
Alfredo Rubio is offline
Find More Posts by Alfredo Rubio
Moderador.
Alfredo Rubio's Avatar
guadalajara, jalisco, mexico
Joined Sep 2002
Indoor Jedi Star Fighter
Hello guys, not pics yet but the las saturday I tried to fly the new plane in the fleet, a styrofoam JSF, 9" w.s with JMP receiver and std. actuators, powered by M20 7:1 geared, 10 cm blue prop, but the plane is some hard to fly, it has camber and reflex in the delta wing, and is unpowered, once I got the correct trib, only flew half circle.... do you can tell me an advice to get more power?
The JSF weighs 26.2 grams and have a WL of 2.6 oz/sq. ft. I thought to replace the motor, to use the N20 with DD u80 prop.
Thanks.
Alf
Alfredo Rubio is offline Find More Posts by Alfredo Rubio
Old May 22, 2005, 05:24 PM
Pete P is offline
Find More Posts by Pete P
Micro Flyer, Big Poster
Pete P's Avatar
Joined Feb 2005
Maybe to omcuh drag in the airframe. Also, the Jedi Starfighter lacks proper vertical stabalization. Is this the new starfighter or the older one, IE does it have a TIE-fighter canopy in the middle, or is it a long triangle?
I believe all the trim you put on it added too much drag, so you need an alternate form of stability; adding a clear plastic v-stab underneath/on top will help stability.
Pete P is offline Find More Posts by Pete P
Old May 22, 2005, 05:26 PM
snakeX2 is offline
Find More Posts by snakeX2
Flap chap
snakeX2's Avatar
Most Southern England, Brighton UK
Joined May 2004
Very interesting. I have heard of other larger (cd rom brushless i think) jedi starfighter projects in RC groups, one had some success, profile body/depron. It is basically a delta and should be easy to 'make' it fly. I can't help you with the power system but i'd like to wish you luck. I had built some sp400 powered Millenium falcons, had some success but still in the process of finishing my new one, hopefully to fly better with some brushless urge. Thanks, you have encouraged me to get back on my millenium falcon project. Good luck with yours!!
James,
snakeX2 is offline Find More Posts by snakeX2
Old May 22, 2005, 05:28 PM
Moderador.
Joined Sep 2002
Is the older one, profile fuselage and delta wing, the stability is not problem, the profile cockpit serves as a rudder, the foamy is 3mm, so the drag is small, the real rpoblem is the low power, it can not mantain the flight.
Thanks.
Alf
Old May 22, 2005, 05:31 PM
Moderador.
Joined Sep 2002
Like this but smaller:
http://www.rcgroups.com/forums/showthread.php?t=125797
Cheers again
Alf
Pete P is offline
Pete P's Avatar
Joined Feb 2005
I see. You may need a geared n20 or even a small brushless :-)
Old May 22, 2005, 05:34 PM
Moderador.
Joined Sep 2002
I think in N20, as the receiver is the JMP with one 145 mah cell I can not to use the brushless
Cheers
Jedi Alf
Old May 22, 2005, 05:44 PM
Dan Leonard is offline
Find More Posts by Dan Leonard
Dan Leonard's Avatar
Lenexa KS USA
Joined Jun 2001
Alfredo
I use the Blue 10cm prop with the kenway gearbox which is 4.2-1 and I think it produces more thrust than the N-20 geared or direct drive. Make sure you put a small drop of oil on the bushings of the gearbox and on the motor bushings. This has to be done about every 8 or ten flights. You also need a fresh 250 ma battery to get max power from this set up. I don't think the 170ma or smaller can maintain enough current to give you maximum output.
Dan
Dan Leonard is offline Find More Posts by Dan Leonard
Old May 23, 2005, 12:43 AM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
sorta-x-wing
i built this when the plantraco equipment first came out. i loved the X-Wing look of star wars, but thought i'd give it my own twist, and this is what came out. i wanted it to have some unconventional looking wings, even if that meant sacrificing total wing area, so i put on 4 wings instead. i put on a penny for a glide test, not knowing how it would really fly, but surprisingly it glided rather well, much further than i expected. i know the standard micro equipment will be too heavy, but the .38g plantraco rx, with .6 gram actuators, 4mm or 6mm DD motor and 30mah lipo, the AUW should be low enough to not make uncontrollably fast. unfortunately, i dont have the plantraco equipment yet, so it's still just a glider, but someday...
micro_builder is offline Find More Posts by micro_builder
Old May 23, 2005, 10:39 PM
Moderador.
Joined Sep 2002
Hi guys, I changed the M20 motor for an N20 with the same 7:1 gear and the 12 cm blue prop, not fly yet but the power "sense" more, I hope to get the flight now
Dan thanks for the oil advice I going to do it
Micro, nice glider, complex and unexpected design it is, maybe in a near future flight RC it will... I love the Joda style
In june 18 and 19 will be the SW Guadalajara convention, I wish to build a lot of gliders for the kids, I think in the A wing, JSF from E2 and E3 and to get the flight handle in the RC small version, in next days the report
Jedi Master Bodo Baas
Keeper of the Holocronīs bridge
Old May 23, 2005, 10:44 PM
Moderador.
Joined Sep 2002
Snake, thanks for share your Millenium Falcon, a guy from the SW club will to love it, how do MF handle? I guess it is a speedy plane...just as the original
Cheers
Alf
Old May 24, 2005, 08:18 AM
snakeX2 is offline
Flap chap
snakeX2's Avatar
Joined May 2004
Actually, there is two threads on the millenium falcon in the Parkflyer section, all progress is there. I am not the only one who has built one, but the thread starter has had the most successful flying so far.
From my flights, it handled rather well, but trimming it up is rather hard and i had a fair few crashes. I hope to return with #2 and a Brushless motor someday, it has a larger wing area which will help.
Yesterday, i tried a micro falcon with a 1 channel rx to imitate the JMP, flew fine and glided nicely, i installed some actuators but the contol surface were too small, but i think rudder will be alot easier to make and will work much better. Obviously, the verticle stabilzer/rudder shows clearly, but some clear plastic will do next time.
Just someday...she'll fly..
James,
Old May 26, 2005, 11:44 PM
Moderador.
Joined Sep 2002
We hope soon
Old May 27, 2005, 12:02 AM
Pete P is offline
Pete P's Avatar
Joined Feb 2005
Hey Alfredo- Do you have plans for the FF A-wing? Or a good 3-view?
Old May 27, 2005, 08:43 PM
Moderador.
Joined Sep 2002
Let me to ask to my son Yhoshua, he have a computer game that have almost all the first ships , latter I tell you, but now:
http://search.espanol.yahoo.com/sear...+wing&ei=UTF-8
Cheers.
Alf
Jet Design Contest. Jedi Star Fighter. oldpilot Electric Ducted Fan Jet Talk 43 Apr 03, 2006 05:41 PM
For Sale Star Wars X-Wing Star Fighter Flying Scale Model for RC conversion shschon Aircraft - Electric - Airplanes (FS/W) 13 Sep 20, 2005 07:11 PM
Article 04/05 JDC: Jedi Star Fighter Old Pilot Electric Plane Talk 9 May 21, 2005 11:26 PM
The STAR FIGHTER! scratchbildr Foamies (Kits) 6 Nov 06, 2004 12:05 AM
R.C. Jedi Star Fighter Alfredo Rubio Scratchbuilt Indoor and Micro Models 104 Aug 20, 2003 05:11 PM
