Letchworth, Great Britain (UK)
Joined Jul 2004
LIke ryanl2006 says, put a 3-cell and a 2-cell in series and you've got a 5-cell pack of about 18.5v (5 x 3.7v).
Looking up the Axi 4120/18 spec I see that it's designed for "16-20 cells", by which they mean NiCad or NiMh cells at about 1.2v per cell. So that's about 19.2 to 24v. So I would say that six Lipos would be bang in the middle of the recommended range. But that's not all there is to it: You need to know what power (watts) your model needs (watts = volts x amps); what pitch of prop will drive your plane best for your style of flying; then what size prop will result in the right number of amps. Hobby Lobby http://www.hobby-lobby.com/brushless-axi4120.htm recommends 13x6.5 to 14x7 prop. They also suggest it will be drawing 39.7amps, so I would think that your 2100 packs (theoretically 42amps if the 20C rating is believable) might be marginal. I've converted 2 glow models to electric using that sequence of logic, plus help from this forum, so I'm no expert. I'm sure others in this forum will be able to be more specific concerning your particular model. |
Joined Jul 2004
Quite right, too early in the morning for me -- I mis-read the 37.9
Anyway, the point I was making (and I'm sure you'll have read it elsewhere in this forum) is that some manufacturers are more optimistic than others in their C ratings, so their packs might not be able to deliver the amps that you think they would. I haven't used LiPos myself yet, so I'm not qualified to comment whether Kokam tell it like it is, or not. Lower voltage can be compensated for by higher amps, and vice versa; and the size and pitch of prop determines the amps, if everything else is equal. But other things then come into play such as motor r.p.m. (depends on voltage, if everything else is equal), motor efficiency, and ESC rating. That's why you're best to start off within the manufacturer's recommended range unless you have advice from someone who's successfully used your motor with a specific battery/prop combo in a model similar to yours. |
| Thread Tools | |
| Question LiPo Question - How do you know when you need a charge again? | torcgolf | Batteries and Chargers | 3 | Nov 12, 2006 04:12 PM |
| Dumb question: How do you know when your batteries have had it for the day? | steve crewdog | Radios | 4 | Sep 04, 2005 05:55 AM |
| Using a winch: how do you know when to release? | tempest411 | Thermal | 35 | Dec 10, 2003 07:14 PM |
| GWS SS, How Do You Know When. . . | bugleboy | Parkflyers | 4 | Mar 31, 2003 04:21 PM |
| How do you know when a battery is low? | Phoenix-IT | Electric Heli Talk | 8 | Jan 26, 2002 12:24 PM |
