Old Dec 13, 2011, 11:50 AM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
I think the designer is Zack West.
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Dec 13, 2011, 03:46 PM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
I have no [I]dea just a guess from reading earlier post
RTF Thumper is offline Find More Posts by RTF Thumper
Old Dec 14, 2011, 10:02 AM
SD One. is online now
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Lots of foamies like this use a single servo for ailerons. The only advantage of having two is the ability to program aileron differential with a transmitter. This can also be done by using a differential control horn on a single servo. Two servos can also enable flaperons, which serve no purpose on one of these. In almost every case, saving weight is preferred over those two options.
SD One. is online now Find More Posts by SD One.
Old Jan 04, 2012, 01:41 PM
ralph123 is offline
Find More Posts by ralph123
Joined Jun 2008
Hi,
i've got a question, from what site do you download the plans of the extra?
www.3dbatix.com does not work..
kind regards
ralph123 is offline Find More Posts by ralph123
Old Jan 04, 2012, 01:45 PM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
They are contained in this thread. You can search in this thread for the .pdf. There are several in here some where.
Pickle72 is offline Find More Posts by Pickle72
Old Jan 05, 2012, 09:36 AM
JoeRC is offline
Find More Posts by JoeRC
Mouth of the Midwest
Joined Mar 2003
Plans Attached...
Plans Attached...
JoeRC is offline Find More Posts by JoeRC
Old Jan 07, 2012, 12:50 PM
Big Jim
Joined Jun 2011
What a great plane
If you have not finished your plane yet. Get after it this plane cost me one dollar to make used on hand hardware.
5 Jan 12 Maiden of the Yellow Zonker (3 min 12 sec)
Old Jan 07, 2012, 03:53 PM
JoeRC is offline
Joined Mar 2003
http://www.youtube.com/watch?v=__ocCYb4WCI
Not only is it inexpensive to bulid it flys great and can pull off just about every 3D move in the book! AS RTF Thumper says, get after it!
Old Jan 07, 2012, 04:27 PM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Dang you guys are going to make me have to make another one.
Old Jan 09, 2012, 11:00 AM
USA, TN, Gallatin
Joined Aug 2009
Here are the original 36" 3DBatix Extra 330 plans. Sorry, I don't have a tiled version.
I'm also attaching the 37" 3DBatix Diablo plans in both full and tiled versions. This plane is very similar to the Extra but flies a nicer KE.
I'm also attaching my own Diablo V3 plans. I took the original Diablo, scaled it down to 32", removed all the extra foam, extended the ailerons and rudder, added a rudder counterbalance and modified the cut lines for 9mm EPP. The whole setup weighs 7.4 oz and it's a 3D machine!
Old Jan 24, 2012, 09:22 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Here we go again! Its all your fault
I am going to try this little guy out.
http://www.nitroplanes.com/86ma64-2215-740kv.html
I have heard some good things about these Rocket motors, and there cheap. I like cheap!
Matt
Old Jan 24, 2012, 10:21 AM
mjcmyers is offline
Find More Posts by mjcmyers
Got Foam?
mjcmyers's Avatar
United States, TN, Greeneville
Joined Sep 2011
Hey that's why I take the file to Staples and let them print it full size for $5.
mjcmyers is offline Find More Posts by mjcmyers
Old Jan 24, 2012, 10:39 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Good idea! I did that with some larger self made plans but didn't even think about for this. Where were you yesterday?
Old Jan 24, 2012, 11:11 AM
mjcmyers is offline
Got Foam?
mjcmyers's Avatar
Joined Sep 2011
Down in my "Lair" putting landing gear on a EPP GRX Parkjet...
Old Feb 28, 2012, 02:33 PM
rajeevmk is offline
Find More Posts by rajeevmk
Joined Aug 2010
And here is my new Extra. Haven't flown it yet. Will let you all know how it goes.
36"
All 6 mm Depron
Hacker 20-22L Clone
Turnigy 30A ESC (it's a bit oversized but that's all I have at hand)
Rhino 1050 20C
GWS 1047
9 gm servos X 3
No landing gear
AUW 15 oz
rajeevmk is offline Find More Posts by rajeevmk
Fliton Extra 330 Free Style Balance Point rcfunflyer Sport Planes 1 Oct 27, 2005 01:04 AM
Yippee! Free Plans of a great scale plane. Vagabond324 Scale Kit/Scratch Built 0 Sep 25, 2005 11:06 PM
Looking for suggestions for a Extra with free plans. CptanPanic Foamies (Kits) 2 May 27, 2005 11:52 AM
