Old Nov 22, 2005, 09:02 AM
shockflyer12345 is offline
Find More Posts by shockflyer12345
shockflyer12345's Avatar
United States, MD
Joined Nov 2004
well what do you guys think of the yak scheme
shockflyer12345 is offline Find More Posts by shockflyer12345
Old Nov 22, 2005, 09:35 AM
3DNobody is offline
Find More Posts by 3DNobody
3D nOOb...sort of...
3DNobody's Avatar
Roanoke, VA
Joined May 2005
The Yak scheme looks good. It should look good on just about any plane. It is one of my favorites because of the selection of colors, and the contrast of the top and bottom wings.
3DNobody is offline Find More Posts by 3DNobody
Old Nov 22, 2005, 01:53 PM
GT2000 is offline
Find More Posts by GT2000
UK
Joined Mar 2005
Thanks for the compliments. The setup of my extra is as follows:
Hacker A20-20L
Flightpower 1200 3 cell 20C Lipos
Hacker X30 ESC
10-4.7 prop
AUW 13.5 oz
This setup gives fantastic and effortless vertical, although I was a little wary of full throttle as my initial tests showed 20 amps static on a fully charged pack. In reality I was rarely above 1/2 throttle which allowed the first part of a knife edge loop to be performed. (I can't do the down bit!!!!)
On both flights I landed after 11 minutes so I don't know what the real duration is.
The colour scheme was quite simple with the original idea coming from the avatar of Ben-Rod. The blue and black is solartrim and the checks are a permenant felt tip pen. Sorry no paint!!
GT2000 is offline Find More Posts by GT2000
Old Jan 03, 2006, 11:40 AM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
GT2000 Really like your plane. You seem to be using close to the same set as me. Awesome power huh???
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Jan 03, 2006, 11:11 PM
Darth-Jester is offline
Find More Posts by Darth-Jester
Hey guys, is the extra 330 wing the same as the diablo? It looks like the same plane with an extra 330 fuselage. I guess I could just print it out. I have been flying the diablo for about 6 months now. I built it with a G-Force wing and made the fuse 12mm instead of 6. The fuse is a hollowed 6mm core with 3mm skins laminated to it with gorilla glue just like the wing. My AUW is 14.5 oz. Would like to post pics but don't know how.
Darth-Jester is offline Find More Posts by Darth-Jester
Old Jan 03, 2006, 11:29 PM
Boss248 is offline
Find More Posts by Boss248
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
Darth...the Diablo has a different wing than the 330...if memory serves both the leading and trailing edges have a different rake and the ailerons are bigger on the 330. There is quite a bit of difference in the way they fly with the edge going to the Extra. The 330's roll rate is more axial and faster and the 330 seems to do roliing harriers more easily but bot are at the top of the scale in my book..I like them both..a lot.
On attaching a pic before you hit submit keep scrolling down until you see a manage attachments bar..click on it and browse your hard drive for the pics you want to add..hit upload and wait for the confirm window..then hit submit...and you're done.
Boss
Boss248 is offline Find More Posts by Boss248
Old Jan 04, 2006, 10:46 AM
Ben-Rod is offline
Ben-Rod's Avatar
Joined Nov 2004
I really would like to see a pic of the plane, sounds neat. Yea what Boss said. The 330 does have a faster roll rate, but both are good planes.
Ben
Old Jan 04, 2006, 01:58 PM
3dflyindan is offline
Find More Posts by 3dflyindan
PB #2212
London, England
Joined Dec 2005
if my electrics are suitable
I have been watching this thread closely for a while now and am considering making on after a long delay i just wanted to know if this stuff is ok
-hyperion 2209-32 brushless motor
-10*4.7 prop
-1000mah 3cell
i wish to make the plane mostly out of 6mm and some 3mm depron
would this be ok ?
3dflyindan is offline Find More Posts by 3dflyindan
Old Jan 04, 2006, 02:21 PM
Boss248 is offline
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
-10*4.7 prop
-1000mah 3cell
would this be ok ?
I have never used that motor but it should work as long as you keep it as lite as possible..
Boss
Old Jan 04, 2006, 02:29 PM
PB #2212
London, England
Joined Dec 2005
is the 1000mah battery powerfull enough to pull out of hovers and most 3d manouvers ?
will start building this weekend
Old Jan 04, 2006, 02:58 PM
Boss248 is offline
ProBro # 501
Boss248's Avatar
Austin Tx
Joined Jul 2005
It depends on the AUW of the plane mostly but has a lot to do with props and age of the 1000 lipoly. I sometimes use a 2s 860 and a larger prop when it calm wind and I can pull from hover but just..can easily fly around doing rolls and K/E and junk like that. So I am willing to bet the 2209 will do the trick. A buddy of mine used the Axi 2208 in almost all his 12-13oz. size/style planes with very god results..actually it surprised me at how well it did. So go ahead and stick the motor on it and find out... Just don't get carried away with the hot glue and paint....
Boss
Old Jan 04, 2006, 03:23 PM
PB #2212
London, England
Joined Dec 2005
luckily i only use UHU por and 5minute on the motor for strentgh i hate using geared motors they a waste of time
will upload some piks thorugh the stages of building
Old Jan 04, 2006, 04:02 PM
Ben-Rod is offline
Ben-Rod's Avatar
Joined Nov 2004
-10*4.7 prop
-1000mah 3cell
would this be ok ?
That motor and battery should be fine if you can keep it 12 oz or under. Lots of guys in this thread have tried mixing the 6mm with the 3mm and were not happy. I would use 6mm all around. Good luck!!!
Ben
Old Jan 05, 2006, 11:42 AM
PB #2212
London, England
Joined Dec 2005
ok will do
Ok i think i will do theres a change of plane i will still make the plane this weekend but my electrics have just found a new home in a ef yak balsa
will still tell you the weight of my plane and will update you when my ef yak is destroyed which noing me wont be long i push my planes hard especially foamies
dan
Old Jan 05, 2006, 12:59 PM
Ok, this has been my ride for the last 6 months, an almost crash proof Diablo from 3D Batix. The fuse is 12mm. It has a hollowed 6mm core with 3mm skins laminated to it with Probond. The wing is laminated in the same way. It's just like the original G-Force wing from 3D Foamy. Laminating the plane in this fashion adds great strength. I got tired of the depron always snapping everytime I hit the ground. I also moved the battery to the top of the plane over the center of gravity. The weight of the battery would always rip the fuselage apart when I crashed. I fly outdoors with lots of wind so a durable plane has been a must for me. The plane came out at 14.5 oz. a little heavier than I wanted but It still flys great. I have a razor microheli V2, gws "D" box, swinging a 12x6 prop and 1320 3s thunderpowers. I am currently working on the extra 330 plane with the edge 540 mod and a 39" wingspan.
Fliton Extra 330 Free Style Balance Point rcfunflyer Sport Planes 1 Oct 27, 2005 01:04 AM
Yippee! Free Plans of a great scale plane. Vagabond324 Scale Kit/Scratch Built 0 Sep 25, 2005 11:06 PM
Looking for suggestions for a Extra with free plans. CptanPanic Foamies (Kits) 2 May 27, 2005 11:52 AM
