Old May 20, 2005, 01:53 PM
Albuquerque NM
Joined Jul 2002
Stator insulation
There is a liquid called "tool dip" I think, it is used to plastic coat the metal handles of tools, plyers for example, when this stuff cures it is a firm rubber like surface, one coat is about 1/32 thick not thick enough for a tool, but good enough for our needs. I'm going to get some tool dip and do some testing, I'll follow up with my findings... unless someone else had already done this?
Charlie F
cfischer505 is offline Find More Posts by cfischer505
Old May 20, 2005, 03:10 PM
Fishnut's Avatar
Joined Feb 2004
Have not tried that stuff in particular, but I have not had good results using anything soft. The wire just mashed through it at the corner.
Good luck,
Kurt
Fishnut is offline Find More Posts by Fishnut
Old May 20, 2005, 03:19 PM
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
I had a chance today to examine a 12 pole stator from a drill motor, it was not insulated and the cornors of the slots were lightly ground smooth with a small radius, why wont this work for our needs too, I'm about to try it on a GB 12 tooth stator.
mike3976 is offline Find More Posts by mike3976
Old May 20, 2005, 04:02 PM
Ron H's Avatar
Bishopville S.C.
Joined May 2003
I haven't used it on a motor as a dip due to obvious drawbacks. It will barely cover the corners where it's most needed, yet it will readily fill the area between the teeth and coat the ends. Less copper, same risk.
Ron H is offline Find More Posts by Ron H
Old May 20, 2005, 05:16 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
Chamfer the corners.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 31, 2005, 03:19 PM
Belleville, IL
Joined Mar 2004
Just wrap 2 or 3 turns of teflon pipe threading tape around them. it is thin and very heat resistant. I have used this in motors and transformers for years with no bad results.
Dale
dwentz is offline Find More Posts by dwentz
Old May 31, 2005, 05:17 PM
landru's Avatar
Vancouver, Canada
Joined Mar 2003
After trying heat-cured epoxy coatings and quite a few different kinds of tape, the best I've found is this UHMW tape. The link is to leevalley.com, but I think the tape is a 3M product. This tape is very tough!
To use, simply apply two layers of tape to each 'flat side' of the stator, trim around the stator circumference, and then make slits in the tape between the stator teeth. The excess tape folds over into the stator slots when you wind the stator, forming very effective insulation. For the GB stators, chamfering the sharp edges before applying the tape is highly recommended.
Andrew
landru is offline Find More Posts by landru
Old May 31, 2005, 07:30 PM
Joined Feb 2001
Dale, teflon is not a good idea, it flows under pressure, see item #7:
http://www.rcgroups.com/forums/showthread.php?t=240993
http://groups.yahoo.com/group/lrk-torquemax/message/153
Vriendelijke groeten Ron van Sommeren
e-motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, August 28th, Nijmegen, the Netherlands
Old May 31, 2005, 08:20 PM
It flies? I like it!
Joined Apr 2004
Gunkote baked PTFE/Moly. Chamfer the edges with a swiss file, spray it on, bake for an hour. Tough as nails! Just did two 25 mm GB stacks today. Never had it fail.
Lomcevak is offline Find More Posts by Lomcevak
Old May 31, 2005, 09:30 PM
CD-ROM Junkie
Art Newland's Avatar
Camas, Washington, USA
Joined Apr 2001
http://www.brownells.com/aspx/NS/Sto...20GUN%20FINISH
Art Newland is offline Find More Posts by Art Newland
Old May 31, 2005, 09:44 PM
Joined Feb 2001
Glass and epoxy, baking paper (pictures):
http://www.modellflug-hager.de/lrk.htm
Old May 31, 2005, 10:23 PM
United States, NC, Belmont
Joined Mar 2004
After many trys to rewind a PJS motor that had been stripped to bare metal and many, many shorts later I was able to rewind it actually twice (decided to go from Y connection to Delta) without a single short.
I used some stuff called Insulating Cambric cloth.
It's a yellow cloth, fairly thin and very flexible and will insulate up to something like 5000 volts.
I cut two circles slightly larger then the front and back of the stator, glued them on with CA, cut slits between the stator teeth and wound it.
I cut off the excess after it's wound.
I've been fying with that motor for a few months now.
If anyone wants some it's available from quite a few sources on the internet.
mgdon is offline Find More Posts by mgdon
Old May 31, 2005, 11:00 PM
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
Originally Posted by mgdon
A
Can you post us a link.
Bill
Bilbobaker is offline Find More Posts by Bilbobaker
Old Jun 02, 2005, 05:23 AM
Proud to be a Belgian.
rafgol's Avatar
Averbode, Belgium.
Joined Jul 2004
3M Cambric tape..
http://products3.3m.com/catalog/us/e...er/output_html
Can be found in smaller quantities too, I think.
rafgol is offline Find More Posts by rafgol
Old Jan 21, 2006, 08:58 PM
Joined Mar 2001
I thought I'd post to this older thread rather than opening a new one. Has anyone tried vacuum forming on their stators? I built a very simple vacuum box, and my 1st attempt is shown. Probably 3 stators at once was too much. I used .015 styrene. I've also attached a pic of the simple vacuum box made from a Radio Shack project box. I'll give this a few more tries before I pass judgement on the technique.
Tony Turley
t-turley is offline Find More Posts by t-turley
methods for stator insulation Ron van Sommeren Power Systems 0 Oct 21, 2005 08:56 AM
