Old May 19, 2005, 10:26 PM
jnyoun is offline
Find More Posts by jnyoun
Spritual Pilot
Silicon Valley, CA
Joined May 2001
Installing HS-56HB in ARK X-400?
What is the best way to install Hitec HS-56HB servos in X-400?
The frame has only one screw hole each side, but the servo has two holes? Should I drill two additional holes in the frame? Since it is aluminum frame, I am afraid if it is easy work to drill....
Thanks in advance
JN
jnyoun is offline Find More Posts by jnyoun
Old May 19, 2005, 11:42 PM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
put the servo against the frame and use the frame as guide to drill a hole in the middle of the servo ears.
thanhTran is offline Find More Posts by thanhTran
ARK X-400 Newer Version Review skeppley Mini Helis 486 Jan 11, 2009 02:13 PM
What motor for ARK X-400? jnyoun Mini Helis 11 Jul 10, 2005 05:09 PM
ARK X 400 build problem thanhTran Mini Helis 22 May 13, 2005 09:05 PM
Question T-Rex 450 or Ark X-400 turbolover Mini Helis 4 Apr 25, 2005 09:39 AM
ARK X-400 CCPM Pro gigawatt Mini Helis 0 Apr 03, 2005 10:47 PM
