Old May 19, 2005, 05:36 PM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
BLUE ALBACORDE... a second opinion
Thanks Patrick !!!!!.... didn't realize we were so "blabby "... just having too much FUN... and now , for more of the same ......and for a trip down memory lane www.rcgroups.com/forums/showthread.php?t=339432 (thanks to Genebond)
gpw is offline Find More Posts by gpw
Old May 19, 2005, 07:17 PM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
I'm in!
TeamTEOR is offline Find More Posts by TeamTEOR
Old May 19, 2005, 09:02 PM
bob s is offline
Find More Posts by bob s
kentucky
Joined Feb 2004
what prop should you use with the j=250 on 3s pack?
Bob
bob s is offline Find More Posts by bob s
Old May 19, 2005, 10:40 PM
AKACully is offline
Find More Posts by AKACully
Can't build them all!
AKACully's Avatar
Orlando, FL
Joined Jan 2004
Bob
I personally use a GWS 3-3 with great success.
Cully
AKACully is offline Find More Posts by AKACully
Old May 20, 2005, 10:17 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
I forget what GeneBond said (he's my motor GURU ) but I think that's about all you can use with the 3c, cause the amp draw should be kept under 5A ...and not stay WOT all the time ... which is hard to do cause' you're having so much FUN ...Now I gotta try that on mine .... hahahaha
Mutation Alert: The recent models involving mid and pusher motors( especially the BA ) and the motor in the slot thingie' has led to a new version of a well used flyer .... FB BOB put the BP 12 on his ALBE and it was a rocket , but expressed concerns of his expensive brushless on the nose , where all the action happens .... so now we have the 3D ALBATROSS PUSHER #9X.... motor in a safer spot ...Strange alien/shark looking ... Weird!!!!
Old May 20, 2005, 10:55 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Hey gpw, you aught to edit your first post to include a link to the first thread: http://www.rcgroups.com/forums/showthread.php?t=339432
You can copy and paste (removing the quote marks):
"http://www.rcgroups.com/forums/showthread.php?t=339432"
Edit: OK, I have scaled the originals to 80% and 120% for experimental purposes. I can't edit the post back on the first thread, so I will upload all 3 versions here. Note that on the scaled versions, the slots will not be the right thickness, so manually edit these before you cut too wide or narrow of a slot.
Gene Bond is offline Find More Posts by Gene Bond
Old May 20, 2005, 11:06 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Thanks , Did it ...!!!
Old May 20, 2005, 12:08 PM
AKACully is offline
AKACully's Avatar
Orlando, FL
Joined Jan 2004
Staying off WOT all the time is the hard part. She does such nice axial rolls at WOT and loops that have her chasing her tail. I haven't slowed down enough to try harrier yet but it will come soon enough. I did discover one thing the JSW does better. If you slow the JSW down, chop the throttle, and give full up elevator, it falls ever so gently like a leaf. My BA just sort of falls. Different beasts but both loads of fun. I'm working on getting my GB CDRom fixed so I can go 3S with it and really rip the wings off my BA. Of course, if I rip the wings off, what will be left?
Cully
Old May 20, 2005, 12:28 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
on with the comparison....
Why do you think the JSW had a blunt nose?
It can take it in the kisser and go again without additional tape
But, it is kinda like comparing apples and oysters...
Old May 20, 2005, 06:41 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
The JSW has proven to, be a FINE craft in every way , very different indeed from the BA... I agree with the NOSE thing though ....spare Noses ??? on a dollar plane ....hahahahahaha
Cully , want a leaf ??? move the cg back ... you'll get leaf !!!! bring the spare nose ....hahahahahaha
Old May 20, 2005, 09:37 PM
Prashanth is offline
Find More Posts by Prashanth
Bangalore Hindustan, India
Joined Apr 2003
on a 3S pack and j250 what would be the current drawwith 3x3 prop
and what would be the draw on a 2s pack on 3X3 prop?
my white albacorde is ready, will try and maiden this sunday if weather permits...
need to put the power system and batteries
Prashanth
Prashanth is offline Find More Posts by Prashanth
Last edited by Prashanth; May 20, 2005 at 09:38 PM. Reason: missed to add the prop
Old May 20, 2005, 10:04 PM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
DCM-189, 3030, 2s = ~7a
3s=??? 10a ???
I don't know, but I just started running 3sET1200 on my worn out G4046 with a 3030 on the MiniSpeedWing Clone. Not hot, but warm... Not full throttle continuous, but 40-50mph fast passes
Old May 20, 2005, 10:48 PM
madfisherman is offline
Find More Posts by madfisherman
Pacific Northwest, USA
I say you should not run lipo 3's on the G4046 as it will burn up fast. The DCM189 can hold up better. Here is some info on the two types of J-250's.
J250 DD 20500 [G4046]
3030 7.4V 8amps 4.1oz thrust
4025 7.4V 9amps 4.7oz thrust
4040 7.4V 9amps 4.2oz thrust
4540 7.4V 10amps 5.8oz thrust
5043 7.4V 11amps 6.1oz thrust
J250 DD 20519 [DCM-189]
3030 7.4V 5amps 4.1oz thrust
4025 7.4V 6amps 5.7oz thrust
4040 7.4V 8amps 5oz thrust
4540 7.4V 9amps 6.4oz thrust
5043 7.4V 10amps 7oz thrust
madfisherman is offline Find More Posts by madfisherman
Old May 20, 2005, 11:51 PM
AKACully is offline
AKACully's Avatar
Orlando, FL
Joined Jan 2004
I really don't need the leaf as it means I just have to really land the BA rather than dropping it at my feet. I love both the JSW and BA but I'm curently enamored with the BA. I would be willing to bet that with a JSW and my current skill level, I'd be having just as much fun. I need more airbourne electronics so I can have more than a choice of just two plans to fly. I really need to invest in more 3S LIPOs. As a side note, I should have my GB CDRom back up and running very soon and it is awsume on 3S.
Cully
Old May 22, 2005, 01:26 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Cully , you know what they say , "never enough stuff !!!!"... I'm set Up currently for 15 planes and a helicopter... still not enough !!! This stuff is as addictive as Cheap Cold Beer...hahahahahaha
Video Pilots View Speed Test Blue Albacorde UBILDIT Electric Plane Talk 1 Jun 03, 2006 08:22 AM
BLUE ALBACORDE... J250/cd... gpw Foamies (Kits) 513 May 19, 2005 06:25 PM
