Old May 19, 2005, 03:41 PM
dmb is offline
dmb
Find More Posts by dmb
dmb
dmb's Avatar
Prague, Czech Republic
Joined Jan 2005
Dumas 19' Racing Runabout, bow section
I have just finished the mahogany planking on my Dumas 19' Racing Runabout, and have started to sand down the hull, the manual reads like this “You will have noticed that the 1/2" wide planks , when finished sanded extend out past the edge of the bow by about 1/4". Since we are not planking the bottom of the hull this situation will naturally come up. To rectify this situation simply fair the side planking downs by sanding the mahogany planking with a sanding block until the new shape of the bow blends in. if it is done correctly, you won’t even tell where the wood planks and the plastic hull meet. “
Ok well I get most of this but it follows on, “remember the outer edge of the first mahogany strip is the outer edge of the chine and must be maintained at all times” and the illustration says “Keep Line sharp” and indicates all the way to the front of the bow.
Unfortunately I am now a bit confused, does any body have any pictures of the bow section (front and under) of the Dumas 19' Racing Runabout in about the same construction stage or even completed so i could get an idea of what it should look like.
I would really appreciate it.
dmb is offline Find More Posts by dmb
Old May 19, 2005, 05:11 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Yes,...Maybe...
http://www.rcgroups.com/forums/showthread.php?t=215695
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old May 19, 2005, 08:03 PM
K Lipskie is offline
Find More Posts by K Lipskie
Joined Nov 2004
I remember scratching my head at this point also. You can sand and bring the edge back only so far then you will need to use a polyester finish and blending putty applied to the plastic below the chine strip to even the bow. Don"t sand the edge of the bottom strip to much or you will loose the line. My camera is on the fritz or I wouls take a picture of my finished hull but it won"t show you what you need at this point. hope this helps.
K Lipskie is offline Find More Posts by K Lipskie
Old May 20, 2005, 10:08 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
If you make a really big mistake on the mahogany planking on this kit, all is not lost. The 1947 version of the 19' Racing Runabout were planked with cedar and painted white, with red trim and antifouling paint.
One reference book is:
Chris-Craft
By Jack Savage
MBI Punlishing Company
729 Prospect Avenue
P.O. Box 1
Osceola, WI 54020-0001
ISBN: 0-7603-0606-0
Page 57 has a picture of the red & white 19' Racing Runabout.
CG Bob is offline Find More Posts by CG Bob
Old May 21, 2005, 12:02 AM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
CG Bob makes a good point. Another reference book is:
Chris-Craft Boats
By Anthony Mollica, Jr. and Jack Savage
MBI Publishing Company
Galtier Plaza, Suite 200
380 Jackson Street
St. Paul, MN 55101-3885
ISBN 0-7603-0920-5
In this well-illustrated book, on page 53 there is a nice color picture of a 19-foot Racing Runabout that came 'back into the lineup for 1948.' It is stated that the first 205 produced had painted hulls because of a shortage of 'Chris-Craft grade' Philippine mahogany.
Although a Runabout model with a painted hull would be authentic and would have a different look, it would be a shame to sacrifice that beautiful mahogany appearance.
If you can, let us see how it turns out. Best of luck...
Bill
jeepers1940 is offline Find More Posts by jeepers1940
Old May 22, 2005, 12:40 PM
dmb is offline
dmb
dmb
dmb's Avatar
Joined Jan 2005
Hi, thanks for the replies, I will spend a little time doing some research and looking at some pictures, I do not want to paint it as I want to keep the Mahogany finish
Dumas 19' Racing Runabout P. Tritle Scale Boats 54 Jan 26, 2016 03:25 PM
Build Log Dumas 19ft Racing Runabout mcfly1883 Scale Boats 361 Oct 14, 2015 10:46 PM
Build Log A beginners build of the Dumas 19' Racing Runabout -=Odie=- Scale Boats 32 Nov 20, 2006 05:36 PM
Fair price for Dumas Racing runabout ? K Lipskie Scale Boats 0 May 18, 2005 07:26 PM
My Dumas Racing Runabout arrives downunder! jb4845 Scale Boats 1 Feb 04, 2005 07:26 AM
