Old Apr 12, 2002, 04:04 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
P-39 conversion
Hi Gang!
I've got a P-39 that I am considering converting to electric. I don't recall the kit manufacturer, as I bought the plane built at a fly in, but my original intent was to fly it slope. I weighted the nose as necessary and installed standard sized radio gear, but it test-glided like a brick so I didn't slope it. It may have been produced by modeltech or similar. It's sized for a .10 to .15 glow, and I'm wondering what it might take to power this thing electric, not for screaming aerobatics, but for scale semi-aerobatic flight. She is about 40 inches in w/s, with approximately 250 sq in wing area, and as she sits now (weighted nose, but no radio gear) she weighs about 20 oz. Thanks for any suggestions! Here's a pic
Martin Hunter is offline Find More Posts by Martin Hunter
Old Apr 12, 2002, 04:06 AM
Leave me alone!
Joined Feb 2002
another pic
Old Apr 12, 2002, 03:46 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Dreamer
It might be barely be doable.
I'll throw out my guesses- Jeti 15/4 plus 7 cell CP 1700 pack -nice combo on a 9 x 4.5 for good vertical pull on a 30 ounce airplane, not killer quick. This pulls about 200 watts- for good power loading at 30 ounces or so. Weighs around 14.5 ounces. Radio wt- add 1.5 ounce. This brings you up to 16 ounces of gear you need to add. If the airplane is 20 ounces, stomp on it or just hang it up- you'll be at 36 ounces and it'll probably be unpleasant to fly. However, you've got weight in the snoot. If you knock out 4 oz- you get down to 32- might just make it. 30 or lower is happiness. Rev up your dremel if you're going to do it....
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Apr 15, 2002, 06:24 AM
Leave me alone!
Joined Feb 2002
Sam,
Thanks for your advice... that's kind of what I was expecting. Even with my little bit of weight removed from the nose, I'm still about 18 oz. The best I could hope to do is strip the covering and start going nuts with making lightening holes, but I'd rather keep it as a display piece at this point... looks good on my wall!
Old Apr 17, 2002, 08:45 AM
Leave me alone!
Joined Feb 2002
I should correct myself on one thing... it's a global kit, not modeltech
Rave Sureflite P-39 Airacobra Conversion Joe Papa Vendor Talk 27 Aug 15, 2005 12:57 PM
Top Flight P-39 conversion BandDButton Scale Kit/Scratch Built 11 Feb 05, 2004 08:25 AM
HOB P-39 Conversion RJB Sport Planes 9 Oct 31, 2003 01:02 PM
WM P-51 conversion to electric TedLarson Sport Planes 1 Sep 28, 2001 05:45 PM
Cox p-51 Conversion, does anyone have a link?? Dandi6065 Parkflyers 1 Jun 15, 2001 10:30 AM
