Old Apr 11, 2002, 09:08 PM
topforce is offline
Find More Posts by topforce
USA
Joined Feb 2002
Need input regarding twin edf300 design project
Hi all. Im cooking up a design for twin edf 300 power. I want it to be similar to a hotliner aerobatic glider. Im wondering how much weight can a pair of these fans carry. The plane will be hand launched, and should be able to loop from level if this is possible. I plan on using standard spd 300 motors, and an 8x600ae nicad pack to power both fans. I think I can keep weight down around 18 ounces. Also,, what kind of wing loading should I shoot for to be sure the model is fast like a df should be, and yet be no problem to hand launch? Thanks!
topforce is offline Find More Posts by topforce
Old Apr 11, 2002, 09:22 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
EDF 300
I'm using a WeMoTec 300 fan in a EJF Minx. It has a flying weight of 18 oz. I'm using a 280 BB on 10 600 AE. No problem looping from level flight. This plane flies very well. Good luck with your project.
Bob Ruff
bruff is offline Find More Posts by bruff
Old Apr 12, 2002, 08:25 AM
topforce is offline
USA
Joined Feb 2002
surprizing performance
Bob, thanks for the info. It sounds like the little edf 300 is much more powerful than I expected. I would have never guessed that a single edf 300 would support 18 oz of flying weight and be able to loop from level. This broadens my limits a bit. I am pretty sure 18 oz is doable with twin fans and a single pack of 8x600ae, but I may just go a bit bigger, and use slightly larger cells now. I think twin edf 300 may have been pushing those 600ae a bit hard anyway.
Old Apr 12, 2002, 08:37 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
I would also have never thought this would work. I'm glad to hear different, however. Bob, how many amps does it pull?
GregG is offline Find More Posts by GregG
Old Apr 12, 2002, 08:40 AM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
AMPs
The Minx is pulling 9 AMPs fresh off the charger.
Bob Ruff
Old Apr 12, 2002, 10:28 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
The speed 300's draw a lot of current, a twin setup may be a bit much for 600ae's. I would plan to use 1300cp cells think that would add about 5oz over a 600ae pack using 8 cells.
dave morris is offline Find More Posts by dave morris
Help! New project idea-Need input! monkeywrencher FPV Talk 17 Feb 01, 2007 08:18 PM
Discussion Questions regarding UAV as a design project flatland2d UAV - Unmanned Aerial Vehicles 19 Sep 26, 2006 10:23 AM
Help! Lightest Stevens Aero Micro Cap (1:12) so far? need input for an upcoming project. Zeroaltitude Parkflyers 0 Jan 06, 2006 06:42 PM
470mm night blade project, need input! helifrek Electric Heli Talk 1 Aug 12, 2005 12:47 PM
Question Need Input regarding tail Design Tommy D The Builders Workshop 2 May 18, 2004 03:25 PM
