Old May 16, 2005, 08:53 AM
lexma is offline
Find More Posts by lexma
Aix en provence (France)
Joined Apr 2005
Antonov-124 building project
Hello All
I'm considering the building of a 1.50 m wingspan foam Antonov-124, but i'm not very confident in building such a plane.
I've already a very good plan of it that i found here http://www.airwar.ru/other/draw/an124.html
Some photos of it
And my problem is the choice of the motors.
I want to use 4 GWS EDF-64-300H like this one http://www.aircraft-world.com/prod_d...stem/edf64.htm
And a KAN 2 Ah 9.6V battery pack
I've already a 40A brushed controler, 4 Futaba S3003 servos, and a six channel receiver.
I don't know if those ducted fans will be enougth powerfull to move this plane.
I estimate the final weght around 2 Kg do you think that is under estimated.
I need some advices from the builders you are, thank you.
Sorry if i'am a bit confuse but i'm french and i dont speak english as well as i want.
lexma is offline Find More Posts by lexma
Old May 16, 2005, 09:29 AM
Eric.Payan is offline
Find More Posts by Eric.Payan
Lyon (France)
Joined Apr 2004
GWS said that the EDF-64 give a 190g trust :
190g x 4 engines = 760g of static thrust for a 2kg plane it's possible but it will be under-powered.
In order to keep the plane as light as possible, I would use a Lipo battery (4000 mAh ?) and choose a light depron structure.
Eric.Payan is offline Find More Posts by Eric.Payan
Old May 16, 2005, 09:43 AM
lexma is offline
Joined Apr 2005
in fact i dont know if 2 kg is a good estimation , because each edf weight 73g, with wires and controler the four motors will weight together approx. 350 g , another 350g for the 2 Ah Nimh batteries pack, 120g for the four servos.
350 +350 + 120 = 820 g only for furniture
Now the big problem is the weight of the foam, i dont really know how much it will weight with some balsa pieces for structure, i've estimated it around 1 Kg for
a plane that will be 1.40m long 1.50m wingspan and 0.16 m of fuselage diameter.
Old May 16, 2005, 10:12 AM
Lyon (France)
Joined Apr 2004
120 g for 4 servos ? For me 4 servos is about 40g.
For the structure, I think you can do lighter. I build a 2m Latécoère (a sea plane so water proof) and the structure weight is about 1kg.
Bye
Old May 16, 2005, 02:13 PM
lexma is offline
Joined Apr 2005
I can use the EDF 75X4A model, it can provide up to 279g thrust with an intake ring, but what is an intake ring ?
But this ducted fan is a bit too large with a diameter of 8.6 cm whereas the motors are supposed to measure 6 cm ...
Can you give me others ideas\solutions, thanks
i put a link to this ducted fan
http://www.gws.com.tw/english/produc...stem/edf75.htm
Old May 16, 2005, 02:31 PM
mdlifcrisis is offline
Find More Posts by mdlifcrisis
"Up Chuck-Up Chuck"
mdlifcrisis's Avatar
Ft. Lauderdale, Fl.
Joined Aug 2004
His servos are standard size. Some 9gr or so micros would be the ticket
mdlifcrisis is offline Find More Posts by mdlifcrisis
Old May 16, 2005, 02:38 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
Sounds like a great project, keep us informed of progress.
foamflyer is offline Find More Posts by foamflyer
Old May 16, 2005, 03:24 PM
Lyon (France)
Joined Apr 2004
[QUOTE=lexma] but what is an intake ring ?
QUOTE]
Sorry for the French :
Un "intake ring" est le conduit d'amission d'air. Dans ce cas il est en forme d'entonoir pour mieux alimenter la turbine (les Gws 55 et 65 en sont equipé d'origine).
If you want more power, you can use brushless engine, with the GWS 65 300g can be achieve. The problème will be the cost with a controler for each engine.
A solution is to build the plane for the gws 65 and to look at the weight for choosing the engine.
Bye
Old May 16, 2005, 03:27 PM
lexma is offline
Joined Apr 2005
Thank you for your encouragements.
I've just tried motocalc and it wasn't able to find a suitable configuration for the plane, i'am a bit discouraged because i can't find a working configuration that i can afford, i know that lipo and brushless motors would be great but it's simply too expensive.
Some informations of the model that can be usefull
-Wing surface only 22 dm²
-fuselage 1.40 m long, 16 cm diameter
Old May 16, 2005, 03:38 PM
lexma is offline
Joined Apr 2005
I dont know if ducted fan is the good solution in fact , and if a standard geared brusher motor with propeller would not be better even if it's not like on the real plane
Old May 16, 2005, 03:54 PM
Lyon (France)
Joined Apr 2004
You should have a look at the french paper "RCM special Depron" (published last year) They build an Airbus with 2 gws 50. It's a light construction witch seem close to want you want to do.
Bye
Old May 16, 2005, 03:59 PM
lexma is offline
Joined Apr 2005
Thank you Eric to see what is the scale of what i want to build here a comparision with an easystar
Old May 17, 2005, 09:26 AM
lexma is offline
Joined Apr 2005
Hello
I'm on the point of cuting the left wing in foam with an hot wire, but i dont know if i should follow the wing shape of the plan :
Or use another wing shape more adapted to this plane, if there is a better wing shape for my plane
Bye
Old May 17, 2005, 12:14 PM
lexma is offline
Joined Apr 2005
Finaly i choose a NACA 2415 wing profile, it should be good , or not ... we will see if will ever fly.
Old May 17, 2005, 02:22 PM
lexma is offline
Joined Apr 2005
After the building of my hot wire i've cut the two wings, but it's just the edge of the wing, not yet the final shape, i'm cutting the gauge of the NACA 2415 profile
Thank you for your advices
"Kawafoamie" Ki-61 building project Brian Courtice Slope 52 Dec 07, 2004 09:28 AM
Chipmunk - Building Project Gary Warner Dallas Electric Aircraft Fliers (DEAF) 33 Sep 08, 2002 09:31 PM
Scratch Building Project - Need Advice!!! Model Aero Parkflyers 42 Mar 11, 2002 08:57 PM
Building Project LittleMoose Parkflyers 7 Mar 02, 2002 06:08 PM
Building Project LittleMoose Parkflyers 0 Mar 01, 2002 12:37 PM
