Old May 15, 2005, 08:13 PM
jgmtens is offline
Find More Posts by jgmtens
but it's a nice obsession
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Build Log
F-106 Delta Dart
I am not an accomplished scale designer like Steve (jetset44) so my goal was to make a very simple to cut and simple to build profile model of the F-106 interceptor.
Fortunately it turned out to be a very good flyer for intermediate and above pilots.
I have included some basic actual size cutout plans here for your personal use only - not commercial.
Here are the specs:
Wing span: 22" (equilateral triangle)
Wing area: 211 sq. in.
Weight: 9.5 to 10.5 oz.
Himax 2808-980 outrunner or a 2015-4100 in a 5.33 GWS gearbox
9 X 7.5 SF APC prop
Phoenix 10 ESC
3s lipo in the 800 to 1300 range
Thrust about 14 oz. here at 5,000 feet above sea level
Top speed 50 to 55 mph
Well, I'll get started with the build thread now. Jon
jgmtens is offline Find More Posts by jgmtens
Last edited by jgmtens; Jul 02, 2006 at 11:15 PM. Reason: uploaded .doc format plans instead of .zip and larger photo
Old May 15, 2005, 08:23 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Basically it is a three ply fuselage. Here's what the parts look like. Not included in this photo is a fourth fuselage ply for the front 12" which I added at the end to provide battery and receiver bays, and to add strength to the front.
Good idea since I did manage to nose dive it once already. No damage - it's tough!
The material is 6mm Depron.
Old May 15, 2005, 08:38 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
First I glued (epoxy) the wing parts together. Then I rounded all the wing edges. Then I cut out the elevons. Make them 5 X 1.75 in. ( edit note: I have since gone to larger elevons 2 X 6 in. for better slow control and added a carbon fiber rod - see later posts)
The distance between the elevons is 1.25 to 1.5 in. depending on your motor/gearbox width.
Next I glued (epoxy) the motor mount onto the wing.
Put it so the prop will clear the elevons and tail fin by about .25 in.
Old May 15, 2005, 08:57 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Next I glued the the fuselage plies and the tail fin together.
Then I cut out places for the motor/gearbox, motor mount and servos.
Then I glued in the servos. Before you do this, make sure you hook them up with your elevon mixing and test to be sure they are positioned correctly for the proper movement.
Old May 15, 2005, 09:14 PM
Ralph A. D'Amelio is offline
Find More Posts by Ralph A. D'Amelio
Ralph A. D'Amelio's Avatar
United States, MA, Chelmsford
Joined Jul 2000
Very, very nice!
Ralph
Ralph A. D'Amelio is offline Find More Posts by Ralph A. D'Amelio
Old May 15, 2005, 09:25 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Then I glued (epoxy) the fuselage and wing together.
I added 2 strips of packing tape just forward of the elevons on the underside of each wing to stiffen them up a bit. I also added a strip over the wing joining seams.
This is where I added a fourth ply - only the front 12 in. to the right side of the fuselage.
Then I rounded the fuselage and tail fin edges and cut/sanded the front to make it look a bit more like a nosecone.
Next I painted with acrylic craft paint and a foam brush.
Old May 15, 2005, 09:30 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
I did some packing tape reinforcement on the front part of the fuselage before cutting out a battery bay from two of the plies, leaving two intact for strength. I also cut out a place for the receiver from the fourth ply only.
For the desired CG which is 9.25 in. from the back of the wing, and using the 830mah battery pack, the bay is situated right in front of the wing. For the 1050mah pack you will need to cut out some more toward the rear, taking out about .5 in. to .75 in. of wing.
Old May 15, 2005, 09:34 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Here's how the electrics went together on the right side.
Also, after the paint job, I added strips of packing tape on the leading edges of the wings and tail fin to make them smooth.
Old May 15, 2005, 10:25 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Now, a short aerodynamic lesson.
For stability, the model needs to have the center of gravity in front of the center of lift.
And that means for this model, since we don't have a horizontal stabilizer, we need to fly with some up elevator trim. 6mm or .25 in. of up trim seems to work with this setup.
Old May 15, 2005, 10:43 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
For the numbers and letters decals, I just printed them out on an Avery clear full sheet label sheet (#8665).
Here is the file. (Edit note - I made the US Air Force bolder)
Last edited by jgmtens; Mar 10, 2006 at 05:36 PM. Reason: added new .doc file for lettering
Old May 15, 2005, 10:49 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
For the Star and Bar decal, I printed out on Avery Matte White Color Printing Full Sheet Label paper (#8255).
Just copy this one into a word program and size it to 4 in. for the wings and 3 in. for the fuselage.
Cover all your decals with clear packing tape to keep any water out.
Old May 15, 2005, 11:01 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Well, that's it for now. Let us know how your builds go. Jon
By the way, if you want to know some history about the F-106, it's here at the Air Force Museum:
http://www.wpafb.af.mil/museum/resea...hter/f106a.htm
Old May 16, 2005, 04:45 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Forgot to mention control throws. You will want full authority to get your nose up during landings so it should be about .75 to 1 in. Jon
Old May 16, 2005, 05:17 PM
Geecee is offline
Find More Posts by Geecee
Geecee's Avatar
Suffolk England
Joined Jan 2005
Looks great - thanks for the plans its another on the list to build
Gary
Geecee is offline Find More Posts by Geecee
Old May 18, 2005, 03:16 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Your welcome Gary.
For launching, it is best to throw it with a slight upward angle at about 75 to 80% throttle and then bring up the throttle as it gains speed. If you launch with 100% using this power setup, you will probably get a little torque roll to the left. Jon
Build Log F-106 Delta Dart... DanSavage Electric Ducted Fan Jet Talk 270 Mar 23, 2012 06:58 PM
Discussion Aero Ace F-106 Delta Dart sr71fan Scratchbuilt Indoor and Micro Models 7 Apr 10, 2007 02:37 AM
Question F-106 Delta Dart Aceshigh84 Electric Ducted Fan Jet Talk 18 Jan 20, 2007 05:10 PM
F-105 Delta Dart? LawnDart Electric Ducted Fan Jet Talk 4 Mar 24, 2003 09:50 AM
F-106 Delta Dart dirtdiver Electric Plane Talk 22 Dec 22, 2002 10:17 AM
