Old Aug 07, 2005, 09:20 AM
majorglory007 is offline
Find More Posts by majorglory007
Whoops
Sorry Dave:
majorglory007 is offline Find More Posts by majorglory007
Old Aug 07, 2005, 10:17 AM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Look at it this way... it was a free bump
Tommy D is offline Find More Posts by Tommy D
Old Aug 22, 2005, 08:53 AM
Brownwood is offline
Find More Posts by Brownwood
The Colony TX
Joined Jun 2005
Originally Posted by David Winter
Hi All.
I originally wanted to do a glassing tutorial while repairing my corsair, and although the repairs turned out wonderfully, I felt it wasn't a good subject for a full fledged build and glassing thread.
So, as I wanted to build a spitfire anyway, and the LHS had the slope glider version on sale, I picked it up cheap (less than $50 CAD) and will use that as the basis for my build tutorial. This will be a powered version but I'll be using stock equipment (EDP350C with B gearing found in the powered version) that I have laying around. The power system comes from my Corsair which is being convered to Brushless.
As this is mostly a build thread and glassing tutorial, I'll be glossing over some of the minor details of building GWS specific models. If you've built more than one GWS model you'll know that the majority of their construction is the same accross their line.
Materials
- Poly Instafil lightweight spackling compound. This is available from HomeDepot, Rona, or pretty much any home supply store.
- 21 gram (.75 oz) weight fiberglass cloth purchased from hobby shop.
- Minwax, Ultra fast drying Polycrylic. I use cear semi-gloss but any colour will work.
- Various grits of sand paper from 150 to 400.
Model preparation.
Obviously GWS models are made of injection molded foam. The injection technique tends to leave marks and other imperfections on the parts. These need to be filled and sanded. The ejection pin marks are the round 'embosed' marks on the bottoms of the wings and tail surfaces. The fuselage also tends to have a large number of smaller pin marks.
Use the lightweight spackle to fill the larger pin marks. A plastic spatula or thin plastic sheet is used to level the spackle to the rest of the surface just as you would use it on the wall in your house. Let this dry overnight and then sand the whole surface down with 150 to 200 grit sandpaper. Don't worry if the GWS paint comes off (in fact it's better if it does come off).
Where do I find the Minwax polycrylic? Im not familiar with that product.
Brownwood is offline Find More Posts by Brownwood
Old Aug 22, 2005, 09:18 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Brownwood I don't know where are are at sitnce you didn't fill out your location in your profile, but in the US you can get it at Lowes Home Depot Walmart etc.
Old Aug 22, 2005, 01:35 PM
The Colony TX
Joined Jun 2005
OK, Ive got both of thosw within 2 miles of my house. I'm in that wonderful but starnge country of Texas.
Old Aug 22, 2005, 01:36 PM
The Colony TX
Joined Jun 2005
PDA4, just realized you are in TX also. I'm in the Colony.
Old Aug 22, 2005, 01:55 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Yep I'm here...Trophy Club, we not too far apart!
Old Nov 12, 2005, 05:57 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
GWS respect you put so much effert on our airplanes.
What I can say?
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 12, 2005, 07:40 AM
hermperez is offline
Find More Posts by hermperez
know it all
Miami, Fl
Joined Nov 2003
really not that much effort, and it does not add that much weight either, about 30 grams to my Me-109, another 10 grams for paint. Results in a much stronger and better looking plane.
I am building a 70" wingspan foamie A-26 twin, will be powered by about 1000 watts.. my idea is to build it like a giant GWS foamie.
Hopefully the new formosa II will be a success and you will start offering larger warbirds.
Herm
Originally Posted by GWS4CEO
What I can say?
hermperez is offline Find More Posts by hermperez
Old Nov 12, 2005, 09:21 AM
MakMov is offline
Find More Posts by MakMov
Excellence is Expected
MakMov's Avatar
Aurora, Colorado
Joined Nov 2005
Well you asked.....
I start with the unpainted bird and sand carfully in one direction. I use the super light weight spackle stuff to fill in every dent and ding and mold marks. I start with 220grit and then finally to 400 and then 600 grit.
I use .5oz cloth (usually) although .75 is OK. I use very light coats of WBPU - even on the first coat. I can't tell how much you are using as mine are usually raw white foam and I can't see the white like you can. But I use just enough on the first coat to barely saturate the cloth.
I sand only after 24 hours of drying. I use the 220 careful to just start raising the hairs on the fiber. I do another coat, as thin as I can. Sand after 24hours. Then another coat sand with 400 grit, then a super light coat and final sanding with 600.
I don't wrap the cloth over the TE of the surfaces. Make sure they get plenty of WBPU to seal the foam.
Make sure the WBPU goes past the surface being covered then the sandpaper cuts right through it (no knife cutting necessary!). This is due to the overlapped WBPU that is now dry allowing the sandpaper to cut it...
So I use 4 coats of WBPU - all as thin as possible. In my GWS spit I added just shy of 2oz. Not too bad.
Almost verbatem how I do mine.
MakMov is offline Find More Posts by MakMov
Old Nov 21, 2005, 12:32 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Spacemanspiff and David - those are two beautiful Spits!!!
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Dec 10, 2005, 10:24 AM
Dan_eflyer is offline
Find More Posts by Dan_eflyer
Meh, it'll still fly.
Ontario, Canada
Joined Jun 2004
Guys, just wondering on the amount of coats for glassing. Everyone seems to be going with a minimum of 3 coats. why not just 1 or 2? Is it not strong enough? or Does the added weight of 2 not weigh out the strength benefits?
Dan_eflyer is offline Find More Posts by Dan_eflyer
Old Dec 10, 2005, 12:39 PM
David Winter is offline
Find More Posts by David Winter
'Riders fan.
David Winter's Avatar
Vancouver, British Columbia
Joined Mar 2004
I've found that 2 coats doesn't give me the finish I like. I use fairly light coats but the difference in weight between 2 and 3 coats is miniscule.
David Winter is offline Find More Posts by David Winter
Old Dec 10, 2005, 03:38 PM
Ontario, Canada
Joined Jun 2004
SHould I cut the ailerons and elevator out now or after? I've got everything sanded down.. and ready to go.
Old Dec 10, 2005, 04:01 PM
'Riders fan.
Joined Mar 2004
I glass the whole model, then cut away the control surfaces. That way everything covered and glassed and there is a nice even surface. But it's intirely up to you.
A hot knife, as described in the tutorial, works best for me.
My Girlfriend's GWS Beaver Build Thread (With Pics) nitroaddict Parkflyers 84 Aug 11, 2007 10:51 AM
Discussion GWS Me-262 Build thread with the GWBLM005A Motor kensp GWS (Grand Wing Servo) 516 Jan 31, 2007 02:27 AM
Idea GWS spitfire build tips? topforce Parkflyers 5 Mar 12, 2004 11:37 AM
Total Newbie GWS Spitfire build Happy|Harry Parkflyers 143 Feb 09, 2004 08:29 AM
directions to a good GWS a-10 build thread machine Parkflyers 3 Jan 28, 2004 02:21 PM
