Old May 24, 2005, 08:39 PM
David Winter is offline
Find More Posts by David Winter
'Riders fan.
David Winter's Avatar
Vancouver, British Columbia
Joined Mar 2004
Well a bit of a change of plan. I orginally wanted to build this stock before converting to brushless. However with the added weight it looks like the first flight will be brushless. This thread will probably continue with the conversion to brushelss.
The model with be outfitted as follows; HIMAX HA2015-4166 brushless W/6.6:1 offset Gearbox (similar to a GWS C but aluminum) and an ALIGN 10 AMP ESC. 3S1500 LiPo. I don't know what prop size yet. Maybe a 1040 or the stock 9070.
David Winter is offline Find More Posts by David Winter
Old Jun 06, 2005, 11:41 AM
'Riders fan.
Joined Mar 2004
Had the maiden flight this past Sunday at the local park. My Himax 4166 has been lost in the mail so instead of letting the model sit on the shelf I purchased another e-flight 370. Now both my Corsair and Spitfire are using the same power and controller system. To get the CG correct I had to use the full amount of clay that was provided in the kit stuff up into the nose. I may try to find a heavier spinner and remove some of that clay.
The very first flight lasted only about 30 seconds. As I tossed the model the canopy cover popped off and I flew one circut around the park and touched down. The first flight proved the plane could fly. I don't know why the pilot ejected so quickly though . A little tape secured the top hatch down and off she went again.
The model performs very well. I always hand launch and this guy needs a very gentle toss at full throttle to get it going. Barely a noticeable dip as she pulls up into the air. Very cool. Once in the air I drop the throttle down to about 1/2 and I'm moving faster than my Mustang does with the stock GWS brushed system. With full or 3/4 throttle, loops are very easy, and rolls are a blast.
It's faster on landing approach and I'm going to need practice with that. Landing has always been an issue with me and I perfer models that sort of float down. Both the Spitfire and the Corsair come in very fast but then, they're also double the weight of my slow flyers. The model does tend to tip stall at low speeds so you have to touch down at a pretty good clip. My final flight of the night I came in a little slow and a little bit high. The models wing dipped, hit the grass, and it did a bit of a cartwheel from a couple of feet off the ground. There was a small crack down the forward section of the fuselage that I've repaired with 5 minute epoxy. I'm really surprised this happened though. The fibreglassing should have prevented a break like that. Well maybe the fibreglass just prevented the model from shattering like my Mustang always did.
Unforutnately, this isn't something I can easily replicate on my flight sim. Landing on that is easy. When I get into the real world though, it's another story.
Old Jun 06, 2005, 01:19 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Glad you are happy. I love mine, you are right about the speed you have to carry some into landing or it will snap. That wing was well known for that!
But o does that ellipitcal wing look great in the air!
Old Jun 09, 2005, 02:37 PM
Balsabird is offline
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
Probably the wrong thread but I've been searching for a while and can't find a reference I saw recently about masking GWS foam with wet paper instead of tape so as not to pull off the previous paint during mask removal. Does anyone know of such a process? If memory serves, wet newsprint was mentioned. This will be used to paint markings on my Spitfire to match the cover photo in a recent magazine (Flight Journal?) I saw at the LHS.
Balsabird is offline Find More Posts by Balsabird
Old Jun 09, 2005, 02:58 PM
'Riders fan.
Joined Mar 2004
That would work but the paint can soak through depending on how you've thinned your paint. The best advice I can give is to go to a home renovation place and get some low tack masking tape. It's green rather than the off white of the high tack stuff. It doesn't pull off the previous layer of paint from the foam.
The other option is to use some regular masking tape but press it against a cotton shirt a few times until the majority of the adhesive is gone.
Old Jun 09, 2005, 03:02 PM
Rondog is offline
Find More Posts by Rondog
Permaculture de NEW Technology
Rondog's Avatar
United States, CA, Redlands
Joined Dec 2002
That's a great idea!
And just .01 more cent to add, don't try and think the blue painters tape will work because it doesn't.
Tried it, and had to repaint.
Rondog is offline Find More Posts by Rondog
Old Jun 10, 2005, 06:31 PM
JREEVES is online now
Find More Posts by JREEVES
Wayward Pilot
JREEVES's Avatar
USA, FL, New Port Richey
Joined Sep 2001
Great work David, definately an awesome looking plane and great tutorial. I'm still wondering what you final weight came in at? If you try another GWS Spit later on, give it a try with the SG kit unglassed and the elongated (Mk IX) nose, covered in other threads. With your power setup you'd be sub 15 oz AUW and all of the bad habits in the air go away. Thanks again for your efforts!
Jim
JREEVES is online now Find More Posts by JREEVES
Old Jun 10, 2005, 07:50 PM
'Riders fan.
Joined Mar 2004
Jim
Ready to fly, the model is about 450grams.
Old Jun 11, 2005, 01:05 AM
ParkJeff is online now
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
David,
Good job! Your AUW is excellent too. Glad to hear your maiden went well.
I've found that when landing warbirds (and other low wing planes) I really need to fly them in. I just pretend the runway isn't there and fly her down with a little power on and a little nose high. Cut power just after touch down and you'll have a nice three pointer. A smooth landing area helps as nose overs tend to happen if the wheels cannot roll freely.
Regards,
Jeff
ParkJeff is online now Find More Posts by ParkJeff
Old Aug 05, 2005, 06:56 AM
majorglory007 is offline
Find More Posts by majorglory007
Howdy one and all
Hello to one and all:
I have read several differing threads about fiberglassing your GWS models and thought I might give it a try. I used 2.0 oz cloth for the Fuselage and .50 oz cloth for the wings and left rudder and elevator alone. I did not have many pics about spits available in the limited time I have ( work many hours a week) so I trusted to my local hobby store for colors. All Colors are canned Tamiya Colors. I used sig Weld diluted with a little water instead of Poly. I just could not find the time to get to the local Lowes and I had the sig on hand. The sig weld penetrated the cloth easily and sticks well to the foam. Dried in no time and gave me a sandable surface to apply color too, but time will tell if it holds up to the test. Now for facts and questions.
I have weighed this bird with Prop and gear and it weighs in at 13.5 oz without battery pack
I am using the stock GWS gear Box With B gear drive
I have a 10/7 prop on her and all GWS reciever and servos
I have left the rudder attached and plan to fly with just Aelerons and Elevator. I have ordered the GWS 1600 Ni Mh pack which should fit.
My questions are this. Has anyone flown this bird with stock motor after glassing? (With battery pack I should come in at around 19.5 oz)
Has anyone flown in this config? (Aeleron Elevator and speed )
Has anyone tried this 1600 ma Ni Mh from GWS in this plane? ( i have ordered this battery pack from GWS and gone off the dim for fit.)
Has anyone found any better Wheels than these? Sheeeeesh!
majorglory007 is offline Find More Posts by majorglory007
Old Aug 06, 2005, 11:44 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Did I told you guys to try EPS400C D gear drive with EP1060HD for 2 cells or EP9050 for 3 cells in this thread?
GWS4CEO is offline Find More Posts by GWS4CEO
Old Aug 06, 2005, 12:16 PM
Wayward Pilot
JREEVES's Avatar
Joined Sep 2001
Mr. Lin, the sweet spot for mine is with a Himax 2808-1160 using your 9x7.5 DD prop cut down to 8" on 3s lipo. We need more deep pitch, small diameter props in the DD/HD line. What a great plane your Spit is!
Old Aug 06, 2005, 12:33 PM
Wayward Pilot
JREEVES's Avatar
Joined Sep 2001
It'll fly with an 8 cell pack, but will be a heavy bird, try to get plenty of altitude before trying anything tricky, keep your aileron and elevator throws to 3/8" or less up or down and be sure your CG is per specs. Aileron and elevator only is how most people fly them without landing gear, you may wish you had rudder for takeoffs on gear but that's about it. I think www.allerc.com has some light foam wheels in a variety of sizes that are narrow enough to fit the stock gear wire. My first Spit was similar to yours in weight with landing gear and rudder and just flew on 2 cell lipo with nose weight to balance. Could tip stall at low speed. Spit #2 with brushless and 3 cell lipo came in at 15 ounces and flies like a champ but slows down to floater speed. No landing gear or rudder though.
Old Aug 06, 2005, 10:31 PM
Thanks for the help
Howdy one and all:
Thank you for the help. My local Hobby stoer has lost my battery order so I will have to waite a little while longer. My wheels are not yet hard points as I have not decided to keep them yet. I hope to have this bird up soon. I have never played with brushless or lipos yet as I am budget minded and have already put out the expense for a charger that handles nicd and ni mh. Will keep watching the skies, and thanks again.
Jim
Old Aug 07, 2005, 12:19 AM
'Riders fan.
Joined Mar 2004
A tutorial on fibreglassing turned into a battery discussion?
My Girlfriend's GWS Beaver Build Thread (With Pics) nitroaddict Parkflyers 84 Aug 11, 2007 10:51 AM
Discussion GWS Me-262 Build thread with the GWBLM005A Motor kensp GWS (Grand Wing Servo) 516 Jan 31, 2007 02:27 AM
Idea GWS spitfire build tips? topforce Parkflyers 5 Mar 12, 2004 11:37 AM
Total Newbie GWS Spitfire build Happy|Harry Parkflyers 143 Feb 09, 2004 08:29 AM
directions to a good GWS a-10 build thread machine Parkflyers 3 Jan 28, 2004 02:21 PM
