I dont care
about the curl
it looks beatiful ,anyway there are flat bed printers out there, some big ones too.
Latest blog entry: For motor builders
California
Joined May 2005
Mike,
The following applies to 1 mm or less thick styrofoam sheet with a closed surface cell structure and is known by the trade names Depron, Zepron or Selitac. I apply an inkjet receptor which allows the ink to be absorbed. It's applied on the surface and allowed to thouroughly dry. You can find a commercial source here: http://www.inkaid.com/Instructions/Instructions.html Or you can mix up your own by mixing 40% PVA, 50% Acrylic Gloss (or Matte) Medium, 10% water and a drop of liquid detergent. Apply a thin coating to the sheet styrofoam with a napless roller and allow to completely dry before attempting to print. I sometimes add Acrylic Matte Gesso to the percentage of Acrylic Medium portion to achieve better printer roller traction which can be an issue if the foam sheet is too "slick". Make sure to clean the foam surface by washing with warm water or better yet wipe it down with denatured alcohol prior to surface treatment. The sheets should be as flat as possible. Some applications may require a coating of a white primer-sealer in order to hide the foams base color. Use a water based product preferrably acrylic as they tend to remain flexible and aren't as subject to cracking. You will need to set the printer on "T-Shirt Transfer" mode. In Canon i560/960 printers this consists of selecting this mode in the print setup and switching the printhead from paper to the thicker stock setting by opening the access lid and switching the lever to the right most position. The image will need to be reversed on the horizontal axis because the T-Shirt Transfer mode prints a mirror image. Set the print in manual to "graphic" and reduce the amount of "K" or black ink in the CMYK bars. You may have to help feed the sheet into the printer to get it started. Once the print starts let it go till it ejects the finished sheet. Let the sheet dry for a few minutes before coating with Acrylic Gloss/Matte Medium to waterproof the print. This method allows the application of high detail card models to foam based models. I like to think of it as detailing a model with a whole surface decal. The builder has the option of repainting the scanned image to suit their taste. Hope this is enough to get some of you going or better yet flying..., Gilley P.S. Most HP Printers do not have a straight through paper path and therefore are not candidates for this process. |
| Thread Tools | |
| Hot Glue on Fanfold Foam | bmizes | Foamies (Kits) | 9 | Nov 19, 2005 06:19 PM |
| Inkjet printing on Litespan | Work in Progress | Scale Electric Planes | 12 | Sep 10, 2005 11:23 AM |
| Inkjet printing on covering materials. | vintage1 | The Builders Workshop | 10 | Feb 01, 2004 04:40 AM |
| Business Check Printing on an inkjet printer? Is it common? | mrebman | Life, The Universe, and Politics | 8 | Dec 02, 2003 09:04 AM |
| Arcel sheet foam source? | hardlock | Foamies (Kits) | 2 | May 19, 2001 01:00 AM |
