Old May 14, 2005, 12:04 PM
Frankd1 is offline
Find More Posts by Frankd1
Canada
Joined Mar 2004
Which connectors and mounts for Little Screamers?
What size of bullet type connectors should I use for my Little Screamers motor? Hobby-Lobby has the MP Jet gold connectors that are 1.8mm, are these the ones?
I'm also looking for the best way to mount the motor to a Shockflyer F3A, Hobby-Lobby has instructions that suggest using a plywood ring slightly inset (1") from the front of the fuse. I would then screw the motor using the existing mount to the plywood ring.
Any suggestions?
Frank
Frankd1 is offline Find More Posts by Frankd1
Old May 14, 2005, 12:30 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The 1.8mm are rated at 25A so no worries there. The wires from the LS and from, say, a Phoenix 10 are small enough to fit into the connectors - so that would be my choice. For applications with 18ga wire or bigger you need to go to 2.5mm.
The plywood ring and radial mount will be fine. Alternatively, can you cut a slot into which to fit a stick to the Shockflyer? then you could use the LS stick mount.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 14, 2005, 12:34 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
I use the 1.8 mm on mine.
bildo baggins is offline Find More Posts by bildo baggins
Build Log Eurofighter Typhoon for the Little Screamers Park Jet errolw98 Pusher Prop Jet Models 316 Nov 14, 2011 06:11 AM
Discussion Which connectors where for 4 cell lipo @ max 40A krislarsen Batteries and Chargers 6 Aug 03, 2006 03:28 AM
Which connectors for brushless motor leads? rocstar Power Systems 4 Jul 06, 2005 12:33 PM
Deans little black connectors--safe for 280BB? Pat Daily Power Systems 5 Jan 29, 2003 07:17 AM
Which connectors for the Hacker combo Adrian Jeday Electric Heli Talk 8 Dec 28, 2002 11:12 PM
