Old Apr 10, 2002, 09:05 PM
cfossa is offline
Find More Posts by cfossa
cfossa's Avatar
Stow, MA
Joined Mar 2002
Zero CG Questions for GWS4CEO
GWS4CEO,
What c.g did you guys test the Zero (300 version) with? I set mine up with the cg about 55-60 mm back from the leading edge as recommended in the manual. I'm using 600 mAh NiMH packs that weigh about 3.5 oz, and the plane weighs 10.5 oz (total flight weight just over 14 oz.)
The plane had a tendency to climb at full throttle, and seemd a bit unstable .. as if it was tail heavy. I fed in a bunch of down elevator trim, and that did not solve the problem. Slowed doen to about 2/3 throttle and it seemed to fly straight.
I've seen some other posts recommening moving the cg to about 45 mm.
Any updated cg recommendations now that the Zero is out and flying? Is anyone else seeing this tendency to climb with the cg at 55-60 mm?
Carl
cfossa is offline Find More Posts by cfossa
Old Apr 10, 2002, 09:10 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
The new CG is now 45 to 50 MM back from leading edge.
russ6421 is offline Find More Posts by russ6421
Old Apr 10, 2002, 09:26 PM
joemi is offline
Find More Posts by joemi
joemi's Avatar
United States, WA, Kent
Joined Sep 2001
ahh.. that must be it... Mine was climbing so much with full throttle, I had to give full elevator down just to keep it from climbing so much. I thought it was my thrust angle becuase I had just remounted the motor (after breaking it off), but after taking a closer look, the motor and mount look fine. I'll see if I cant move the CG up a bit for the next flight.
joemi is offline Find More Posts by joemi
Old Apr 10, 2002, 10:14 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Sorry, GWS Zero in our test is by suing Sanyo 600mAh AA Nicd at 7.2V. at EPS-100C for the original. When EPS-300C equipped, the powerful speedy flying will make climb tendncy obviously, need to move CG a little forward. 5~10mm.
When you use AAA getting light again, need move CG even more forward.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Apr 11, 2002, 12:21 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
I think you need some downthrust. I built it into mine, and alittle up aileron to stop the snap roll !
Fred Bronk is offline Find More Posts by Fred Bronk
Old Apr 11, 2002, 10:19 AM
cfossa is offline
cfossa's Avatar
Stow, MA
Joined Mar 2002
Fred,
You may be right about the down thrust. I taped a quarter in the battery compartment and got the c.g. to 50 mm with an 8 cell 600 mAh NiMH pack. I took off, and the plane still wanted to climb. I added a bunch of down elevator trim and eventually got it to fly straight and level ... still seemed to want to snap a bit in turns though.
I had flown about 6 minutes, and the batteries were getting a bit weaker. I'm not sure what happened, but the plane nosed up and stalled. It started coming down and I pulled hard on the elevator ... but she didn't pull out. It went in nose first hard
The good news is that the Zero took the crash well. I broke a prop, the battery busted through the firewall, the wing bolt plate tore out, and the fuse cracked on one side just behind the trailing edge of the wing. It's all epoxied back together now and will be good as new ... with a few battle scars
I checked out the controls after putting it back together, and it is no wonder I couldn't recover from the stall. The bunch of down elevator trim to keep the plane flying level had made it so I had almost no up elevator movement .... didn't really notice because I was just flying straight and level.
Before going up again I'm going to move the c.g. forward even more. I plan to tape 1 or 2 quarters inside the cowl and try to get the c.g. to about 40-45 mm.
I may need down thrust too, as you suggest, but I'm pretty sure I have a c.g. problem here. The plane was very "squirrelly" in the air and wanted to tip stall in turns ... classic symptoms of being tail heavy. Not sure how I'd add down thrust now w/o damaging the fuse trying to get it apart.
Hopefully moving the c.g. will help. I'll post another message after I try again .
BTW, my plane (pre-repairs) weighed in at 10.5 oz, and the NiMH pack at just over 3.5 oz. If you are using similar wieght batteries, I'd seriously consider moving you c.g forward before your first flight.
Carl
Old Apr 11, 2002, 11:11 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
If you are welling to add down thrust, add right thrust too. Since your over cells add on more prop thrust will make slightly left turn when take off.
Old Apr 11, 2002, 05:16 PM
jah is offline
jah
Find More Posts by jah
jah
BALD MEMBER
jah's Avatar
North Georgia
Joined Nov 2001
I flew yesterday for the first time at 55mm CG. I had built in down and right thust, had the ailerons slightly reflexed up. Did not fly to well. Here is a post detailing the first flights yesterday:
http://www.rcgroups.com/forums/showt...5&pagenumber=1
Today I put the battery far foward, actually into the cowling, almost against the cowling, and got a CG of 47mm. Trimmed down the elevators, and........
TOTALLY different aircraft. AWESOME
Thanks GWS, just wish the manual had the correct CG for the IPS300 planes.
jah is offline Find More Posts by jah
Old Apr 11, 2002, 06:09 PM
cfossa is offline
cfossa's Avatar
Stow, MA
Joined Mar 2002
JAH,
I just read your first flight report, and it sounds just like mine! Glad to hear that moving the CG seems to have solved your problem. I did not build in down thrust and I think it is too late at this point. Hopefully just moving the CG will solve my problems.
I flew the Zero today with a CG of about 50-55mm. It wanted to nose up and roll left. A bit of right rudder trim solved the left roll easily. But, it took a bunch of down elevator trim to get it to fly straight. Still wanted to nose up and stall in turns, and finally did one stall I couldn't recover from. Nose down straight into the ground!!
Turns out I had so much down elevator trim that I had almost no up elevator movement .
I glued the front of my battery compartment back in, so can't try you method of sliding the batteries into the cowl. But I did tape three quarters inside the bottom of the cowl and I now have a CG of about 40-45 mm. I also have decided to jam some foam in behind my batteries so they can't shift in flight ... the crash loosened things up a bit
Once the wind cooperates I'll give it another try. Hopefully it will be better than today! I'll post a post flight report.
Like you, I wish the manual had the right CG and/or thrust angle for the 300 motor system. Might have saved me some epoxy
Carl
Old Apr 11, 2002, 06:54 PM
jah is offline
jah
jah
BALD MEMBER
jah's Avatar
North Georgia
Joined Nov 2001
Carl, good luck on your flight. Yeah adding the down thrust after the stick is glued into the fuselage is a real puzzle. Maybe you could shave it down and add a little wedge of balsa to get it right. In my thread Lefty and Louie posted a great pic of the correct measurements to get it right. Check his website, the link should be in my "Captured Zero" report.
good luck
Later on
Jerry
Old Apr 11, 2002, 07:22 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
If you really need to dig out the stick to change it you can glue it back in with some ProBond whipped up and it'll be stronger than original and lighter. Don't have a Zero but it worked great on my moth. am using a EPS on my SB.
BC
Basketcase is offline Find More Posts by Basketcase
Questions for Wattage lightning Owners Michael Heer Scratchbuilt Indoor and Micro Models 55 Aug 03, 2002 10:55 PM
Zero questions for GWS4CEO or Horizon Hobby cfossa Parkflyers 2 Apr 02, 2002 10:43 PM
Questions for clipped wing T-52 flyers All__talk Foamies (Kits) 2 Sep 27, 2001 01:47 PM
questions for discus or sidearm hlg flyers MKH Electric Sailplanes 7 Jul 26, 2001 04:19 PM
Questions for Simprop Sukhoi Pilots Brian Nixon Parkflyers 17 May 11, 2001 12:22 AM
