Old May 14, 2005, 02:08 AM
deecee is offline
Find More Posts by deecee
depron_dad
Melsele, Belgium
Joined Mar 2005
Ikarus 3D power set any good? for a beginner.
Masters of 3D, I have a question, not having a brushless ESC, me and my son also want to build a 3D foamy now (after learning on an easystar and progressing to an IKARUS SU-27 XXL, 2 already!), Is this power set a good cheap start? has anyone tried it yet? I will build the foam stuff myself, but only have direct drive power plants now.
I'd built something and trim it for go-around flight first and progress from there.
We have a fairly light receiver at 15gr, one of 25gram, a 10 and 18 AMP lipo ESC and at the moment I mainly use NARO std's of 9gram each.
One 3s1p at 110 gram is the power source (apart from an array of nicad combinations for the easystar).
We have 2 xmitters, one 6ch and one 3ch with mixing that works nicely for the my son as it is a very easy xmitter.
Ikarus 3D power set
Any ideas on this setup? Experience?
DeeCee.
deecee is offline Find More Posts by deecee
Old May 14, 2005, 11:50 AM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
It appears to function adequately, and has the advantage of fitting together according to the written instrctions. However, it appears to simply be a brushed Mabuchi motor, and as such, is essentially the same as a GWS EPS 300 power system. A bit of ingenuity can have the GWS system onboard for less money and with cheaper spare parts.
I flew my Superstar shockflyer on the GWS system very successfuly (a C gear ratio and 10.47 prop on 3S lipolys). However, the performance difference between that system and a brushless is large, mainly due to the weight of the brushed system.
Best of luck!
blucor basher is online now Find More Posts by blucor basher
Old May 15, 2005, 01:51 AM
deecee is offline
depron_dad
Melsele, Belgium
Joined Mar 2005
Good info!
Will explore that option, thanks!
Have just aquired a 3s1p 850mA lipo at 60 grams (including connector) so weight wise we lost a potential 60 grams there already, should be a better light foamy plane battery.
DeeCee.
Ebay EPP flyer - Any good for indoor beginner? Cerberus 3D Flying 10 Mar 06, 2008 07:49 PM
Is this Mini Sub any good for a beginner? ken68 Submarines 5 Sep 27, 2007 03:33 PM
Discussion Power set-up suggestions for good performance seagull2200 Electric Sailplanes 11 Oct 10, 2006 10:48 PM
micro 6 any good for 3D? kartman24 3D Flying 3 Jun 22, 2005 03:52 PM
"Nippy Black" brushless motors, any good for 3D? Thomas Manson 3D Flying 9 Nov 25, 2003 08:03 AM
