Old May 13, 2005, 01:42 PM
demetrius is online now
Find More Posts by demetrius
demetrius's Avatar
Van Nuys
Joined Mar 2004
jepe a-4 with retracts or fixed?
i was considering converting the a-4 to retracts mechanical! Or maybe the nose mech and fixed mains! any thoughts?
demetrius is online now Find More Posts by demetrius
Old May 13, 2005, 01:44 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
also has anyone ever converted these nose retracts to steerible?
Old May 13, 2005, 01:51 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
i wanted to keep the weight down due to i put a midi in it and that setup brought the weight up as oppose to the carbon one offered by jepe! so far with mega 2t and 20x gp 2200 i am looking at 5.3 lbs i think. So any thoughts? Also i was thinking i would keep it with nimhs since it has a few miles on it.
Old May 13, 2005, 01:56 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
i also have one robart steerible 602 retract
Old May 13, 2005, 04:39 PM
Ductedfann is offline
Find More Posts by Ductedfann
Ductedfann's Avatar
mid west
Joined Jan 2002
well fixed would be the easiest.
Ductedfann is offline Find More Posts by Ductedfann
Old May 13, 2005, 05:40 PM
JEllis is offline
Find More Posts by JEllis
Joined Sep 2004
Do it and let us know how it turns out. I would like a Jepe A-4 one day but I am not a fan of bungee launching or fixed gear.
Jason
JEllis is offline Find More Posts by JEllis
Old May 13, 2005, 06:16 PM
Ductedfann's Avatar
mid west
Joined Jan 2002
uncle Joe did a A4 with retracts a year or so ago. It can be done, next year JEPE will release a version for retracts,along side the bungee version we should have on to show soon, I cant wait to get them in we do have the bungee version in now.
Morris Ductedfans.com
Old May 13, 2005, 06:53 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
De,
Retracts all the way, `round.
Dan
DanSavage is offline Find More Posts by DanSavage
Old May 13, 2005, 06:56 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
A Mega 2T in a Midi???????????
Which 2T are you using?
skyhawk is offline Find More Posts by skyhawk
Old May 14, 2005, 12:29 AM
gbruce is offline
Find More Posts by gbruce
gbruce's Avatar
Canada, AB, Airdrie
Joined Oct 2001
Hi
When did you get those retracts from PILOT?
I'd like to pick up a set for my F-18
Bruce
gbruce is offline Find More Posts by gbruce
Old May 14, 2005, 01:12 AM
demetrius's Avatar
Van Nuys
Joined Mar 2004
i currently have installed, midi with 22/30/2t mega & cc80. with 20x-> GP2200, GP3300, cp2400.
Old May 14, 2005, 01:16 AM
demetrius's Avatar
Van Nuys
Joined Mar 2004
Originally Posted by gbruce
Hi
Bruce
I picked them up at my local hs! there dj's and ild imagine you could order them with whom ever is currently selling there kits. EAM carried them for a while. I'm not sure if they're still selling them.
Old May 14, 2005, 01:18 AM
Alexis_Ruiz is offline
Find More Posts by Alexis_Ruiz
Joined Mar 2004
Retract mod
Demetrius:
I once modified the front retract of my dj 3 to be sterable, but it was too weak, I basically machined a groove about 1/8 above the line where the leg enters the pastic rotating base (it has a name I don't recall) then I opened a slit from the back part of the palstic base to slide a retaining clip into the groove, turns out the groove made the piano wire weak and in less than perfect landings the leg would bend (even though it was inside the plastic base) another method to do this(I dion't recall the reason I did not do it on this one, maybe lack of space inside the retract case) is to disassemble the retract, remove the leg and drill the rotating base all the way through the leg hole, then insert the leg with a dual steering horn and a spacer(more on the spacer later)all the way through the hole and use a friction clip placed on the top side where the top of the leg would exit, yet this would have to have a very shallow height of the wire protuding out, 1.5 to 2 mm, just enough meat for the friction clip to hold the leg from falling, the steering horn would keep it from going into the retract. The reason for the spacer is that the horn has to be away enough from the base of the retract to clear the retract housing when retracted. The issue with this method is that the litte amount of wire protuding from the top may not always work, allowing the clip sto slip and the leg would fall, the second proble is that the retract case has to be ground on the inside to allow clearance for the friction clip and the protuding wire to move. I sold my DJ- 1 a long time ago but the new owner is still using this retract I modified. I have done this on the GP .10 retracs also, though I would not recommend them for front wheels as their cases only have about .7 to 1 mm of plastic on the area that absords landnd shock, on any plane I tried them on the base broke on landing. The picture below will give you a better idea of the second alternative, this is a GP .10 retract, it does not have the retaining clip because I lost it:
Alexis_Ruiz is offline Find More Posts by Alexis_Ruiz
Old May 19, 2005, 01:29 AM
demetrius's Avatar
Van Nuys
Joined Mar 2004
hey guys will hs-81s work with these retracts?
If not what will or what will work at a lighter weight?
Discussion Jepe A-4 with first gen 3W... Tram Electric Ducted Fan Jet Talk 6 Apr 28, 2007 09:46 AM
Jepe A-4 with Lipos? dcognat1 Electric Ducted Fan Jet Talk 5 Jan 10, 2005 01:08 PM
Ace Cloud Dancer with Retracts and saito 4 stroke for sale. Steve H. Aircraft - Fuel - Airplanes (FS/W) 1 Feb 16, 2003 11:04 PM
Jepe A-4 - retracts? ROG? randallp Electric Ducted Fan Jet Talk 17 May 01, 2002 05:19 PM
first EDF with retracts or wheels? Muah Electric Ducted Fan Jet Talk 2 Apr 16, 2002 11:09 AM
