Old May 13, 2005, 05:27 AM
waynekinney is offline
Find More Posts by waynekinney
Joined Mar 2005
Is this speed controller ok for a brushed Zoom 400?
Hi,
I just wondered if this speed controller would be ok for a stock Zoom 400?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
Not sure about the upgradable firmware for li-po, how would i upgrade?
Cheers,
Wayne
waynekinney is offline Find More Posts by waynekinney
Old May 13, 2005, 09:49 AM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
It states that the BEC can handle 4 servos but no mention of a gyro. The seller pulled it from one of his planes so you might want to look into it further to see if it can indeed handle the extra load. I would assume the firmware update would be for the cutoff voltage.
TheX is offline Find More Posts by TheX
Old May 13, 2005, 11:49 AM
chelsea_fan is offline
Find More Posts by chelsea_fan
Joined Aug 2004
Should be perfect considering the weight and the apege you shouldnt wory about the BEC to be ohnest my gyro draws 10ma lol (pg-03) and they dont realy vary that much what ever your gyro is to be ohnest
if i were you get it dont know whether its worth the 21.50 for the buy it now though
chelsea_fan is offline Find More Posts by chelsea_fan
Old May 13, 2005, 12:21 PM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
Really? Even something like a 240 or 401?
Thanks, Duane
Minimole is offline Find More Posts by Minimole
Old May 13, 2005, 01:28 PM
Joined Aug 2004
ime not sure but it wont be anything near .2 amp ime guessing that will be max for even the best gyros
most gyro's supply around 2-3 amps correct me if ime wrong but it goes down the hgiher voltage you use can any one explain why?
cheers aaron
Alert Is This OK? (Linkages On Zoom 400) Minimole Mini Helis 20 Oct 25, 2005 07:20 AM
Will this speed controller work? BLUEP51MUSTANG Parkflyers 5 Aug 14, 2003 06:55 AM
Jeti JES 40-3P Controller ok for use with older Aveox 1406/2Y? Ed Waldrep Power Systems 1 Jun 08, 2002 02:43 PM
Can Anyone Help Me Re-wire This Speed Controller?? TONY DENTON Power Systems 1 May 27, 2002 11:27 PM
Batteries, Speed Controller, Servos for Sale renegade Aircraft - Electric - Airplanes (FS/W) 4 Apr 22, 2002 04:42 PM
