Old May 11, 2005, 03:28 PM
sharkman is offline
Find More Posts by sharkman
sharkman
San Diego, Calif.
Joined Jul 2004
hard start vs soft start...??
Can someone please explain the difference between a hard start and a soft start? I'm somewhat new to RC flying and have only been doing this for a little over a year. I'm trying to figure out why my Tsunami 30A ESC only runs in contest mode.
thanks,
sharkman.
sharkman is offline Find More Posts by sharkman
Old May 11, 2005, 03:45 PM
BigShark is offline
Find More Posts by BigShark
How do I land this thing?
BigShark's Avatar
Joined Jul 2002
I don't know that ESC, but a hard start is fine for direct drive. Soft start will power up the motor more slowly to avoid damaging a gearbox.
BigShark is offline Find More Posts by BigShark
Old May 11, 2005, 04:14 PM
Chippie is offline
Find More Posts by Chippie
North East England UK
Joined Jan 2003
It will also be 'kinder' to your battery packs too......The initial power on is like a dead short across a battery pack so a soft start will be a gradual increase in load current........Its a bit like a Direct On Line(DOL) start for an industrial 3 phase motor...star/delta starters were considered soft start...
@Sharkman.....you should be able to change the esc settings...Have you got the instructions? If they appear confusing( they are not the best written...) p'rhaps we can help?
Chippie is offline Find More Posts by Chippie
Old May 12, 2005, 06:15 PM
sharkman is offline
sharkman
San Diego, Calif.
Joined Jul 2004
Hi Chippie,
Thanks. Yes, I do have instructions. I've been following them as best I can. My only issue right now is with getting the throttle to work after I program the ESC. That's why I want to understand the difference between a hard start and a soft start. So far, I've only been able to get the throttle to respond in mode 4 (contest mode).
I want to run the ESC in lipo mode (mode 5) since I'm using lipos, but I can't get the throttle to run the motor after I get it into mode 5. I've also tried mode 2 (motor mode) with the same results. According to the instructions, I'm in mode five because after connecting the battery with the transmitter on, I get the first beep, followed by the number of beeps for the number of lipos I programmed the ESC for, followed by the arming beep sequence. In the other modes, there are no beeps for the number of lipos programmed.
When I increase the throttle, nothing happens. What I'm not sure of and I don't see it in the instructions anywhere is what else I need to do to set the throttle after I have set the ESC to mode 5. The instructions tell me after I move the throttle to full for the number of lipos I'm using to disconnect the battery.
There is a mode 3 (heli) which the instructions mention requires a neutral setting for the throttle. I'm wondering if I am getting stuck in a neutral state somehow or if the throttle off position is getting stored backwards when I set it for mode 5. I guess I am a bit confused.
thanks,
sharkman.
Old Jul 07, 2016, 02:38 PM
Robert Boudreau is offline
Find More Posts by Robert Boudreau
Robert Boudreau's Avatar
United States, CA, Tracy
Joined Nov 2014
Could anybody help me setup a HSD 150amp ESC to soft start, it came set to soft start, somehow I changed it to hard start & it's makes the motor bang when starting. I think I cane get to startup but what to do after I enter it?
thanks.
Robert Boudreau is offline Find More Posts by Robert Boudreau
Hard start versus soft start electric motors Commando Sport Planes 5 Jul 09, 2016 02:40 PM
CC Phoenix 10....hard or soft start question kokamo Power Systems 5 May 21, 2005 08:57 PM
ESC hard/soft start? Will it help? Dr Kiwi Power Systems 2 Sep 08, 2004 04:02 PM
Question hard cut-off vs. soft cut-off? darrell_f Castle Creations 15 Mar 14, 2004 04:14 PM
High Start vs. E-conversion loads Sail 'n Soar Electric Sailplanes 0 Jan 20, 2003 04:49 PM
