Old May 30, 2001, 03:59 AM
Jeremy_D is offline
Find More Posts by Jeremy_D
RC Addict
Jeremy_D's Avatar
Central Coast, Australia
Joined Jan 2001
Mini IFO first flight , just one silly question though...
well i flew the mini ifo for the first time this evening under some park lights.
Setup is as follows.
GWS dx-a- 10/4.7
2x gws naro's
hitec feather 8 cell 280 nimh pack.
Seeing it was dark I only did a few circular circuts on low rate, not bad. Tried hi rates and wow, this baby really turns fast!!.
Just out of interest .. lets say when have full left aileron up should I have the right one down the same amount or would I be better to reduce the throw of the down aileron?? lets say to half to stop it inducing an airbrake effect, that may make it turn with some nose down..
All input would be great as I am doing an indoor fly this fri night in a single gym.
Jeremy..
Jeremy_D is offline Find More Posts by Jeremy_D
Old May 31, 2001, 07:04 PM
Jeremy_D is offline
RC Addict
Jeremy_D's Avatar
Joined Jan 2001
C'mon guys, someone must have one of these planes..
Jeremy..
Old May 31, 2001, 07:24 PM
BleuBuck is offline
Find More Posts by BleuBuck
Springfield, Missouri USA
Joined May 2001
That phenom is called Adverse Yaw. And... Yes, decreasing the "down" travel of the aileron will help counter this effect. That way there is more drag on the side of the direction you are rolling.
I don't have eny experience with the IFO (or much with small electrics in general) but I set up my larger glow-powered planes like this all the time.
Good Luck!
Sam
BleuBuck is offline Find More Posts by BleuBuck
Old Jun 01, 2001, 02:07 AM
Dan Kreigh is offline
Find More Posts by Dan Kreigh
Mojave CA
Joined Nov 2000
Hi Jeremy,
At the SWAC model show in Texas, I had a chance to fly an IFO with differentially set ailerons (actually elevons). I had a tough time flying it and I personally don't think it works for flying wings since the "ailerons" are also the elevator. So with differential aileron input, you're also commanding an unwanted "up" elevator. One can get used to it by commanding down elevator in the turns but than that defeats the original idea of differential aileron movement. Good question...just my two cents.
Dan Kreigh www.flyifo.com
P.S. My IFO mk3's weigh between 9oz up to about 11oz
Dan Kreigh is offline Find More Posts by Dan Kreigh
Old Jun 01, 2001, 02:56 AM
Jeremy_D is offline
RC Addict
Jeremy_D's Avatar
Joined Jan 2001
Thanks for getting back to me guys, I just had the little beast down the park about an hour ago, wow it can really go, inside and outside loops and all the rest. First indoor flight tonight in a single court. wish me luck..
Jeremy..
Old Jun 01, 2001, 03:05 AM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Dan should know, but my Mini IFO has probably 45 degrees aileron movement in each direction and doesn't seem to suffer. I wouldn't worry about it - just enjoy
May I take this oppurtunity of thanking Dan for such a wonderful aeroplane. I only happened to buy a Mini IFO because our field was closed due to the Foot & Mouth crisis in this country. It has been a complete revelation, now that we have the field back, outdoor flying of 'normal' models seems entirely boring. I have flown just about every type of model over the years and can honestly say that I have never had so much fun as I have with the Mini IFO.
Mike Smart
Mike Smart is online now Find More Posts by Mike Smart
Old Jun 01, 2001, 07:32 AM
BleuBuck is offline
Joined May 2001
I Forgot that this was an Elevon bird!!!
Sam
Old Jun 01, 2001, 05:51 PM
Jeremy_D is offline
RC Addict
Jeremy_D's Avatar
Joined Jan 2001
Wow, thanks for all the responses. I flew it indoors last night for the first time. not bad. I'm using a 8 cell pack but might change to 7 for indoor. It's perfect for what I need though. Next flight will be off the top deck of my parents house with the 8 cell pack.
Jeremy..
Old Jun 01, 2001, 06:23 PM
Danny Troy is offline
Find More Posts by Danny Troy
Danny Troy's Avatar
Westchester County, NY, USA
Joined Jun 2000
I'd like to thank Dan also for this great model. I had lots of problems at first with my IFO MKIII, but it was due to radio glitching and not the design of the model. I finally got everything working perfectly, but not until several nose in crashes that did a number on my Litespan covering. I bashed the kit a bit because I wanted a more positive elevon control, so I added a conventional hinge setup: http://www.dannytroy.com/IFO%20aileron%20setup.jpg
It really does fly great, and is super stable. Dan once told me the CG wasn't overly critical and this is definitely true. It's nice to be able to throw different size battery packs with worrying about the CG. I soldered on a light guage piano wire antenna and that is working great. Even though it's shortened I get all the range I need. I like the fact that my at field repair kit consists of a roll of Scotch tape. Someday I'll get aroung to re-covering it. BTW...the Hitec 555 and the Jeti ESC shown in the photo will be replaced with a lighter FMA Extreme 5 and a Pixie 7P which should be here any day.
Danny Troy is offline Find More Posts by Danny Troy
T-IFO first flight MilkmanDan Parkflyers 2 May 22, 2004 06:02 PM
Mini-Piper first flight Flybyguy Foamies (Kits) 12 Dec 08, 2002 08:30 AM
E3D, first flight, cut short, gearing question... Kosh Sport Planes 9 Nov 26, 2002 07:05 AM
Newbie Mini Max first flight (and crash) cdemiris15 Beginner Training Area (Aircraft-Electric) 21 Jul 11, 2002 12:55 AM
Mini IFO 1st flight, yeehaw!!! mthomson Scratchbuilt Indoor and Micro Models 0 Jul 01, 2002 08:52 PM
