Old May 09, 2005, 03:05 PM
ChrisT88 is offline
Find More Posts by ChrisT88
Palm Beach, FL
Joined Jan 2004
T-Rex XL pricing listed
http://www.align.com.tw/shop/product...roducts_id=825
Just cruised over to the Align site and found the price for XL eCCPM, mCCPM is $193. This kit is going to be awesome! IMO the most reliable 3D ship available. I've got my V1 just where I want it. For hard 3D all you need is:
- V1 kit w/XL upgrade and eCCPM mod
- Good electronics 401/hs56's/4s+ batteries
- Sab 320 blades(also Mahs available but I haven't tried these)
- Washers between the plastic grip spacers and rubber dampeners. The washers will help keep the dampeners loaded evenly and seated properly. This improves tracking A LOT. If you want to stiffen up the rotorhead just dremel a little off an end of the spindle. The washer will compress the o-rings further...
ChrisT88 is offline Find More Posts by ChrisT88
Old May 09, 2005, 03:32 PM
EddieNewYork is offline
Find More Posts by EddieNewYork
EddieNewYork's Avatar
Los Angeles, CA
Joined Apr 2004
Is the Trex XL lighter than the Trex V2 or Ark X400?
EddieNewYork is offline Find More Posts by EddieNewYork
Old May 09, 2005, 04:38 PM
ChrisT88 is offline
Palm Beach, FL
Joined Jan 2004
The XL is bigger then both of those you mentioned. I think the RTF weight will be around the same as the V1, maybe a little bit lighter. Weight IMO is fine where it is.
Added weight to XL:
- More bearings
- Longer boom/blades
Reduced weight on XL:
- Frames are lighter
- eCCPM requires less mechanics
Old May 09, 2005, 07:36 PM
rohan is offline
Find More Posts by rohan
that's normal...i think
Joined Feb 2005
would an AON 2812 (i think) - 3500 (3500kv) work in this new trex? I mean, I saw that the ccpm swashplate has been redesigned as it has the servo connection on the antirotation arm. Is there anything else that has been changed? would motors which normally fit in the regular Trex work in this one?
thanks
rohan is offline Find More Posts by rohan
Old May 09, 2005, 08:11 PM
ChrisT88 is offline
Palm Beach, FL
Joined Jan 2004
Yes it should work. The 11t will give you good headspeed.
Old May 09, 2005, 08:50 PM
rohan is offline
Joined Feb 2005
ok cool, thanks!
Old May 10, 2005, 09:58 PM
toecutter is offline
Find More Posts by toecutter
Joined May 2005
You Used An Hs56 For The Tail As Well?
toecutter is offline Find More Posts by toecutter
Old May 10, 2005, 10:02 PM
ChrisT88 is offline
Palm Beach, FL
Joined Jan 2004
HS56 is fine on the tail. I've tried the Futaba 3108 with GY240 and didn't care for it. I'm now flying a GY401 with HS50 and it feels locked in.
Old May 11, 2005, 01:09 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
HS 55 or 50 is faster than the 56 too.
Fred Bronk is offline Find More Posts by Fred Bronk
Old May 11, 2005, 09:25 AM
ChrisT88 is offline
Palm Beach, FL
Joined Jan 2004
Yeah but I think the HS56 is fast enough also. Corrado @ www.heliup.com flys the HS56 in all of his videos. Tail seems pretty locked in
Old May 11, 2005, 12:17 PM
spyder6166 is offline
Find More Posts by spyder6166
I thought it was charged!
spyder6166's Avatar
Westchester County
Joined Jan 2005
Christ88,
Make sure you read their website. It says for Tawian buyers only. It does look like a sweet deal though.
Jeff
spyder6166 is offline Find More Posts by spyder6166
Old May 11, 2005, 02:07 PM
ChrisT88 is offline
Palm Beach, FL
Joined Jan 2004
Align products are usually the same price once they hit the states. I believe the US dealers are being told 3 weeks.
I'm personally not going to upgrade. I've gone with most of their CNC parts and a few from Heliup, but a couple friends will be ordering a kit
Old May 11, 2005, 03:34 PM
rohan is offline
Joined Feb 2005
I will definetly be ordering one! I have been looking at a Trex for a while, but I didn't trust my shop skills to make my own ccpm mod. Also, I didn't like the fact that you had to cut and drill some of the frame to make other mods fit (again, i don't trust my shop skills). So, I am going for the CCPM Trex straight from Align!
Old May 11, 2005, 08:53 PM
rohan is offline
Joined Feb 2005
uh oh. Will the new trex fit in the align aluminum case? I know most of you will say "get/make your own cheaper case!" but, I (hopefully) will have the money to afford one by the end of summer after all my lawnmowing, yard work, etc. is finished. So. I saw on the new trex ccpm that the length is 650mm and rotor diameter is 680-700mm. On the old Trex 450X V2 the length is 610mm and rotor diameter is 640mm. Will the new one still fit in the "conquer your heart" case?
thanks
Old May 12, 2005, 06:38 AM
spyder6166's Avatar
Westchester County
Joined Jan 2005
I have been trying to get that Trex case for a month now with no luck. I don't want to buy it on ebay because I think the shipping is outrageous. Anyone know of a reputable site with them in stock?
Jeff
T-Rex XL - CDE.. Hottest Motor Proposal... NewHummer Mini Helis 8 Jun 28, 2005 02:19 PM
T Rex XL parts question Greybird Mini Helis 3 Jun 21, 2005 08:13 AM
T-Rex XL Vs Shogun Jumpgate2 Mini Helis 14 Jun 16, 2005 10:42 AM
Align's T-rex XL CARBON Steph280 Mini Helis 0 May 31, 2005 05:29 PM
T-rex XL kit pjr Mini Helis 1 Jan 02, 2005 05:02 PM
