May 08, 2005, 10:20 PM
Manila, Philippines
Joined Jul 2004
its Cheaper just buy a Ready-made 12 Volts Power supply from a Surplus store, I use a NOTEBOOK power supply with 12 Volts 4 Amps, for my Super_NOVA 250S from FMA Direct.......check the INPUT VOLTAGE RANGE of your Charger, cause same charger can accept 12 to 24 Volts.......its very common to find a 18 to 21 Volts Notebook power supply.......I just got lucky to find a 12 volts 4 Amps.
The notebook power supply I got, is almost the same size as my Super Nova Charger.
my friend use a computer power suppply, just need to put some load resistor on 5 Volts output a 10 ohms 5 Watts....some power supply need a mininum load of 0.5 Amps in order to work properly.
Ellion
