Old May 08, 2005, 03:11 PM
Denis Leveille
Denis Leveille
Guest
n/a Posts
After run oil - Which one to use?
I am a newbie. Once I am done flying. I make sure sure I burn all the fuel
in the engine and then use a good amount of after run oil. I find commercial
after run oil too expensive at $2+ for a few ounces.
I have been told that several alternatives can be used:
Automatictransmission oil, Marvel air tool oil, and Starret tool and
instrument oil.
What should I use?
I have an OS .46 engine.
Old May 08, 2005, 05:11 PM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Re: After run oil - Which one to use?
ATF and most any air tool oil will work fine. You need more than a few
drops in the glow plug hole for it to work. a half teaspoon ful in the carb
and let it run into the crankcase then spin the prop a few times with the
starter.
Paul McIntosh
http://www.rc-bearings.com
"Denis Leveille" <denis54@videotron.ca> wrote in message
news:N8tfe.2277$2g1.92419@weber.videotron.net...
>commercial after run oil too expensive at $2+ for a few ounces.
> instrument oil.
> What should I use?
Old May 08, 2005, 09:11 PM
John Miller
John Miller
Guest
n/a Posts
Denis Leveille wrote:
> What should I use?
I use Break-Free(r) happily, but in these times, I must hasten to add
that should not be considered to be a recommendation, may cause your
hair to fall out, your dog to run away, etc., etc.
John Miller
email domain: n4vu.com; username: jsm(@)
Surplus (For sale or trade):
Besson (Kanstul) International Trumpet
Old May 09, 2005, 03:11 AM
Ed Forsythe
Ed Forsythe
Guest
n/a Posts
Marvel Air Tool Oil - recommended by Clarence Lee.
Tally Ho!
Ed
"Paul McIntosh" <goto@mywebsite.com> wrote in message
news:427e6845$0$542$ed2619ec@ptn-nntp-reader03.plus.net...
> carb and let it run into the crankcase then spin the prop a few times with
> the starter.
> Paul McIntosh
>> instrument oil.
>> What should I use?
Old May 09, 2005, 09:11 AM
Lyman Slack
Lyman Slack
Guest
n/a Posts
Denis --
Noted engine Guru C. F. Lee has for years recommended the use of Marvel
Air Tool Oil as an after-run. He also suggests a 50/50 mix of MATO and Auto
Trans Fluid (ATF) for long term storage. However, most important of all is
to run your engine dry at the end of the session before the after-run.
Cheers -- \_________Lyman Slack________/
\_______Flying Gators R/C___/
\_____AMA 6430 LM____ /
\___Gainesville FL_____/
Visit my Web Site at www.LymanSlack.com
> instrument oil.
> What should I use?
Old May 09, 2005, 11:11 AM
rcflyer620@gmail.com
Guest
n/a Posts
Read the label on the fuel you are using. Omega/Cool Power now
recommend that NO aftger-run oil be used because their fuels contain
enough lubricants to sufficiently coat the important parts. I stopped
usinf after-run during the season - I normally fly once a week - and I
have noticed that the engine runs-up faster when cold and doesn't smoke
like crazy when first started for the day.
I do, however still use some after-run if I know it will be sitting for
an extended period, generally more than two weeks.
Old May 09, 2005, 01:11 PM
Charlie Funk
Charlie Funk
Guest
n/a Posts
instrument oil.
Marvel is a cost effective choice. Buy it at Pep Boys or other auto parts
store for maybe $13 - $14 a half gallon. Smaller containers are available,
but if you fly a lot, the half gallon is a better choice from a cost
standpoint.
Charlie
commercial
> instrument oil.
> What should I use?
Ed Cregger
Ed Cregger
Guest
n/a Posts
"Charlie Funk" <charlie@justcruisinplus.com> wrote in
message news:d5ntmd$ini$1@news.valueweb.com...
>> Starret tool and
> instrument oil.
> other auto parts
> from a cost
> standpoint.
> Charlie
>> burn all the fuel
>> oil. I find
> commercial
>> Starret tool and
>> instrument oil.
>> What should I use?
I use Marvel Air Tool Oil. Don't use it in a YS unless it is
of the synthetic based oil.
Ed Cregger
Old May 10, 2005, 09:11 AM
Sport Pilot
Sport Pilot
Guest
n/a Posts
Just be sure you use fuel with plenty of castor, 20% of the oil, or
more. Using after run oil that will not mix with our fuel can actually
cause corrosion. Else lube the engine with castor oil after flying.
C G
C G
Guest
n/a Posts
Leaving unburnt fuel in engines will cause corrosion. It's important to
burn off the fuel at the end of the day, and while the engine is still
warm.
Old May 10, 2005, 01:11 PM
Ed Cregger
Ed Cregger
Guest
n/a Posts
"C G" <piper_chuck@yahoo.com> wrote in message
news:j12ge.22011$vi2.624325@twister.southeast.rr.c om...
>> the oil, or
>> fuel can actually
>> after flying.
> It's important to burn off the fuel at the end of the day,
> and while the engine is still warm.
So true.
Running a good quality fuel and burning off excess (glow
engines) at the end of the day actually alleviates the need
for after-run oil for short term storage. I don't bother
with after-run oil unless it is going to be a few months
before I fly again.
Ed Cregger
Old May 11, 2005, 09:11 AM
Jim Slaughter
Jim Slaughter
Guest
n/a Posts
don't use it. Never have, never will. I have engines that are 30 years
old....have been in unsealed storage for years, and run just fine. As far as
I'm concerned it's much ado about nothing.
> instrument oil.
> What should I use?
Old May 11, 2005, 11:11 AM
Sport Pilot
Sport Pilot
Guest
n/a Posts
and
> instrument oil.
parts
available,
> standpoint.
> Charlie
the fuel
> commercial
and
> > instrument oil.
> > What should I use?
Yes, do burn of the fuel at the end of the day. Still a small amount
of fuel will remain in the crankcase. Sometimes I forget to burn off
the fuel, no problems from that, but it is possible for the fuel to
soak up moisture.
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
I don't think anyone can prove that there is any fuel left in the crankcase
of an engine that was shut off when hot. The alcohol and nitro both will be
evaporated out. The only fuel left in the engine will be in the carb.
Paul McIntosh
"Sport Pilot" <hppilot001@cs.com> wrote in message
news:1115818654.810178.98550@o13g2000cwo.googlegro ups.com...
> and
>> instrument oil.
> parts
> available,
>> standpoint.
>> Charlie
> the fuel
>> commercial
> and
>> > instrument oil.
>> > What should I use?
> soak up moisture.
Old May 11, 2005, 01:11 PM
Sport Pilot
Sport Pilot
Guest
n/a Posts
crankcase
will be
carb.
> Paul McIntosh
> > and
> >> instrument oil.
auto
> > parts
> > available,
cost
> >> standpoint.
> >> Charlie
all
> > the fuel
find
> >> commercial
> > and
> >> > instrument oil.
> >> > What should I use?
amount
off
> > soak up moisture.
I should have said "may remain in the crancase" instead of "will remain
in the crankcase". If there is fuel in the carb it could well drip
into the crank case. Fuel can remain in the crankcase, especially on
cold days. I do not think the moisture will cause corrosion if you are
using an oil that will disolve in the fuel and any moisture it may
contain.
After Run Oil rabosr Fuel Plane Talk 28 Jun 12, 2015 04:44 AM
Discussion Do you use after run oil ?(pics) Allan Waterfall Motorcycles 7 Jan 05, 2006 10:25 AM
Thinking of painting the TM, which one to use? cruzomatic Parkflyers 7 Feb 13, 2002 01:05 PM
Which one to use: Epoxy, medium CA or Pro-Bond polyurethane for the FMA razor ?? ARE Foamies (Kits) 5 Dec 30, 2001 02:23 PM
