Old May 08, 2005, 04:52 AM
thanhTran is offline
Find More Posts by thanhTran
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
ARK X 400 build problem
I'll post the problem I face when building an ARK X 400 in this thread or some pictures when building it here
Here is one that I face now before I can do some hovering with it:
The problem is that the servo linkage won't be straight when connecting the link to the lever. HS56 servo is too high for this.
How would you fix that problem?
Thanh
thanhTran is offline Find More Posts by thanhTran
Old May 08, 2005, 05:18 AM
Norman Adlam is online now
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
Thanh
Thanh,
I'm unsure of what your problem is, it looks like you are concerned that the link is leaning out slightly (due to the servo height).
I don't this will represent any real problem for you, certainly not for hovering etc.
You'll be amazed how much slop, and misallignment helis can fly with - but the better you get them the nicer they are to fly (and when you are pushing the envelope, e.g. 3D flying then they start playing a part in producing problems).
You could, of course look at turning the 'Z' link up side down, so the 'Z' comes into the upper face of the servo arm, goes through, and comes out underneath!
Cheers,
Norman Adlam is online now Find More Posts by Norman Adlam
Old May 08, 2005, 06:09 AM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
I'm assuming a ball link on the underside of the servo arm will rub on the case? I guess that's going to depend on how long the arm is and how far it needs to travel.
Hard to tell from a pic, but a ball on the outside of the arm will make the pushrod angled quite a bit. I'm sure that would work but it's not the ideal situation, I think.
The HS-56 servos are really great but their odd dimensions, relative to most other servos, can be a challenge at times.
Anyway, if you want to retain the z-bend, you can try bending it. Keep in mind it's going to get a little shorter. If it ends up too short, maybe you could use a longer link? Again, not the ideal situation, but certainly usable for something like this.
ScotY is offline Find More Posts by ScotY
Old May 08, 2005, 06:15 AM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
One more thought...you could space out the ball on the collective swing arm thing. Again, not ideal but I'm pretty sure that will work, or at least help some.
Old May 08, 2005, 06:29 AM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
Lateral thinking cap on/// Is it possible to mount the servo >behind< the side plate? This would involve removing the side plate to do it, and there might not be enough clearance at the back of the servo, but it would line things up properly. Otherwise, there is no great harm in having a bend in the linkage rod, provided it is stiff enough not to flex in use.
My $0.02..
Tonystott is offline Find More Posts by Tonystott
Old May 08, 2005, 06:43 AM
cbfsoar15 is offline
Find More Posts by cbfsoar15
LOOK UP
cbfsoar15's Avatar
FLORIDA
Joined Dec 2003
Let it lean and go fly
cbfsoar15 is offline Find More Posts by cbfsoar15
Old May 08, 2005, 11:49 AM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
Get rid of the z-bends
TheX is offline Find More Posts by TheX
Old May 08, 2005, 02:13 PM
mdttb is offline
Find More Posts by mdttb
mdttb's Avatar
United States, CA, Stanton
Joined Jan 2004
Mount the HS-56 from the inside. In other words have the servos mounting tab holes on the inside of the frame. You'll have to take off the one mounting tabs on the 56s so they'll slide in from the back. The linkage may not be straight up and down put it'll be a lot closer then what you have now.
Just FYI before you screw the ball linkage screw in you should use a little bit of CA on the screw as the hole seems slightly larger for the screw.
mdttb is offline Find More Posts by mdttb
Old May 08, 2005, 02:25 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Hi Everyone,
Thanks very much for taking your time to give me answers.
The link will not be shorter if I bend it like ScotY suggested.
Tonnyscott, I already have the servo mount behind the plate . That only saves 1mm of servo height. All 4 servos were already behind the chassis plate.
If I let it lean, it touches the servo cases during its travel towards one of its limit ends.
I finally chose the bent method . it limits the negative pitch a little. But this could be saved by using longer servo arm to increase servo throw.
Old May 08, 2005, 02:27 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Elevator problem
I also found that the elevator control is very tought compared to the aileron and only have limitted travels. Is this true? or is it my build problem. I already have the Z bent 10mm away from the ceter of elevator servo arm.
Thanh
Old May 08, 2005, 02:31 PM
ScotY is offline
ScotY's Avatar
Joined Feb 2001
While I don't particularly care for z-bends, they aren't always that bad. This is assuming one end has a ball link for adjustability and the pushrod run is fairly straight. If you have slop where the z-bend goes into the servo arm, just use some medium CA and let it wick into the hole in the arm...apply with the z-bend in place. The CA won't bond well and will effectively get rid of all the slop.
Old May 08, 2005, 02:35 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Thanks Todd, in the picture, the servo already behinds the frame plate. Looks closely you wont' see the ear right at the shiny screw. I have had the servo mounted from inside the frame. That's why I said in another thread that it will take ALOT of time to fix this helicopter after a crash if I have to replace the servos. All 3 servos are mounted this way.
I used a longer screw for the collective ball link as the stock one kept falling off. It's weird to have steel screws (fine thread) to screw to plastic like this design.
Do you have problem with the elevator arm? It's tought to move and even toughter when the flybar is at 3 & 9 o'clock position . I've already smooth out all ball links that I even see some slop some where. When moving the elevator click, the frame even moves a bit.
thanh
Old May 08, 2005, 02:40 PM
TheX is offline
Old new guy
TheX's Avatar
Joined Sep 2004
True, but if he were to lean the link over to attach to the mechanism it would be pulling the z-bend part way out of the servo arm making it even worse.
Old May 08, 2005, 02:50 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
collective problem
Here is the result of the changes to the linkage and servo arm
The problem now is that negative pitch is very little. If I make negative pitch large enough by moving the servo arm around the servo shaft, there will be reduce pitch in positive range AND the pitch is NOT 0 WHEN the stick is at the MIDDLE. I currently have all pitch curve and throttle curve FLAT in the TX.
Any suggestion? I don't think I need much negative pitch at the moment as I don't do any 3D yet, but just afraid that I could need it in a loop.
Old May 08, 2005, 02:51 PM
That tree again!!!!
thanhTran's Avatar
Germantown, MD, US
Joined Sep 2004
Right, it touches the servo case. But i don't see how a EZconnector would be able to fit in this case. During servo travels, the connector would definitely hit the servo case.
Thanh
ARK X-400 Newer Version Review skeppley Mini Helis 486 Jan 11, 2009 02:13 PM
Is there an Ark X-400 build manual Online? Blaze_au Mini Helis 7 Nov 14, 2005 10:47 AM
Installing HS-56 in ARK X-400? jnyoun Mini Helis 1 May 19, 2005 11:42 PM
Question T-Rex 450 or Ark X-400 turbolover Mini Helis 4 Apr 25, 2005 09:39 AM
ARK X-400 CCPM Pro gigawatt Mini Helis 0 Apr 03, 2005 10:47 PM
