Old May 07, 2005, 08:06 PM
MPL0527 is offline
Find More Posts by MPL0527
Western Massachusetts
Joined May 2002
2 New Micros (Work in Progress)
While I'm saving up for a Plantraco setup, I thought I would start building something to put it into.
#1 - Mini Bump Parasol:
w/s = 10"
length = 7.5"
airframe weight = 1.7 gram
2mm hot wire cut styrofoam w/minimum balsa reinforcing
Based on Epilot's drawing - just used the fuselage planform but turned it
upside down.
#2 - Mini LiddleDiddle
w/s = 11"
length = 8"
airframe weight = 2.1 grams
2mm hot wire cut styrofoam w/balsa reinforcing
Base on pictures posted in the Diddle and LiddleDiddle threads
Any comments welcome.
Mark
MPL0527 is offline Find More Posts by MPL0527
Old May 07, 2005, 09:58 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Those look very nice. They just have to fly great, and should put the Plantraco equipment to good use.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old May 08, 2005, 12:47 AM
Plantraco is offline
Find More Posts by Plantraco
Plantraco's Avatar
Saskatoon, Canada
Joined Jan 2003
Mark
Those are great looking airframes that will inspire others to try Micro R/C!
Love to see this - thanks for showing us what your are building!
Those are lightweight airframes!
Plantraco is offline Find More Posts by Plantraco
Site Sponsor
Old May 08, 2005, 04:40 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
I could have saved you the work on the fuselage
http://www.rcgroups.com/forums/showthread.php?t=359297
Nice models
Michael
epilot is offline Find More Posts by epilot
Old May 08, 2005, 09:15 AM
beanoman is offline
Find More Posts by beanoman
beanoman's Avatar
Akron/Canton, Ohio, United States
Joined Aug 2004
well, i saw the parasol, and i couldnt resist... and, i got a new camera on friday, and want to post pics...
heres the peices of foam, at the lowest quality, at the lowest size, in bad lighting conditions, without flash. lol.
and a few moments for the six foam plates who were grotesquelly(i love that word, cant spell it) mudered for materials......
beano
beanoman is offline Find More Posts by beanoman
Old May 08, 2005, 10:06 AM
beanoman is offline
beanoman's Avatar
Joined Aug 2004
ok, finished. i like the looks of mine, with the "huge" larry park wheels. it weighs a slightly heavy 1.6 grams, mines only a 8.5 inch span. not sure what equiptment will be in it- hopefully standard plantraco stuff, with a 6mm dd. that would be 8 grams at most. with about 6 grams of ballast, it flys slow enough but not slow enough for living room flight. or at least not for my livingroom . in a gym or a big ol' room, it should fly great.
erm, sorry for kinda highjacking the thread..
beano
Old May 08, 2005, 10:29 AM
epilot is offline
Joined Nov 2000
Grotesque certainly applies to the wheels Use some foam discs for wheels - adds very little weight.
Michael
Old May 08, 2005, 03:11 PM
beanoman is offline
beanoman's Avatar
Joined Aug 2004
foam ones might add little weight... larry park ones add NO weight . well, .3 grams for both, and they actually spin amazin', unlike my homemade ones.
i think the parasol needs to be the intermediate newbie plane(yes, theres a reason i made one ). first, the guppy with the build thread. then, the parosal. a little bit more complex because of the wing struts. then, the normal bump, with the full fuse.
beano
Discussion My new F3P work-in-progress Doug Cronkhite Indoor Pattern/F3P 13 Jan 19, 2008 09:16 PM
Discussion The new Shop! A work in progress..... Joe Bennett Aerial Photography 46 Aug 10, 2006 12:46 AM
My new GWS Spitfire - work in progress mattski GWS (Grand Wing Servo) 2 Sep 07, 2003 05:50 PM
RBC Beaufighter (work in progress!, long progress) Stuart Warne Scale Kit/Scratch Built 10 Apr 13, 2003 09:33 AM
Work in Progress Sail 'n Soar Parkflyers 2 Sep 21, 2002 12:13 PM
