Old May 07, 2005, 05:06 PM
AirBorne_AZ is offline
Find More Posts by AirBorne_AZ
Joined Nov 2003
How to Balance a Brushless Rotor ?
Hello All,
Just curious as to how one can balance the rotor on a brushless motor?
AirBorne_AZ is offline Find More Posts by AirBorne_AZ
Old May 07, 2005, 07:24 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
No different than balancing an Armature..use a magnetic balance and add or remove weight as needed..... except... often the Magnets are plated and removing metal is destructive/fatal to the Mag structure :-)
Are you absolutely sure balancing is even necessary??
Bare is offline Find More Posts by Bare
Old May 07, 2005, 08:16 PM
acrobatorcrash is offline
Find More Posts by acrobatorcrash
Dade City, Florida
Joined Feb 2005
That is what I was thinking. If the rotor is not balanced, unless this is a self build, I would take it back.
acrobatorcrash is offline Find More Posts by acrobatorcrash
Old May 07, 2005, 10:39 PM
DavidB. is offline
Find More Posts by DavidB.
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
I would definately only add material to balance the rotor, but only a badly made rotor would need balancing. On brushed motors, it's hard to get the coils exactly the same so they require balancing. On brushless motors, balancing can usually be omitted.
DavidB. is offline Find More Posts by DavidB.
Old May 07, 2005, 11:59 PM
Joined Nov 2003
Well, I am new to the brushless business and after crashing my plane, the motor's can got separted so I started searching for info here. Some one here on this forum said that he had to rebalance his rotor after he crashed, so I thought I might have to rebalance mine too. But it seems like its not required. I would just put the motor back as is and see if it runs ok. I hope there wont be any issues with it. Thanks for all the info though.
Old May 08, 2005, 12:15 AM
DavidB. is offline
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
If the "can" spins true when you run the motor, then I wouldn't worry about anything else. If it wobbles much, try to straighten it first. This is a standard cd-rom motor right?
Old May 08, 2005, 02:44 AM
Joined Nov 2003
DavidB. : This is Align 400L brushless. So I assume I shouldn't worry too much about balancing it.
Old May 08, 2005, 03:17 PM
DavidB. is offline
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
Hmm, if it runs true then don't worry about it. If the shaft is bent, get it replaced, but other than that I don't think there is much you can do to fix an align motor.
Discussion how to balance main rotor blades? jeff262 Micro Helis 12 Jan 30, 2006 08:17 AM
How do Brushless Motors Work? RazorB Electric Plane Talk 5 Mar 12, 2002 01:39 PM
How big a brushless can a zagi handle? Munch Foamies (Kits) 0 Feb 20, 2002 11:17 PM
How to connect brushless motor to esc? bradpaul Electric Heli Talk 4 Jan 11, 2002 09:21 AM
How to balance folding props? aireze Electric Plane Talk 3 Dec 14, 2001 03:54 PM
