Old May 07, 2005, 02:39 PM
Bluecor is offline
Find More Posts by Bluecor
Joined Mar 2005
Yippee!
Telescoping Pole AP Camera Build Thread!
neato
Bluecor is offline Find More Posts by Bluecor
Old May 07, 2005, 03:37 PM
crashingagain is offline
Find More Posts by crashingagain
crashingagain's Avatar
Sacramento
Joined Nov 2003
I might have to try one of those, I found them at the same price but with free shipping at
http://www.gigaparts.com/store.php?q...trict=%21radio
part no mfj 1910 in search box
crashingagain is offline Find More Posts by crashingagain
Old May 07, 2005, 04:35 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
For pan all you would have to do is rotate the pole. And for tilt, maybe put a clevis joint on the mount and use a lever with a small rod for that.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old May 07, 2005, 05:55 PM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
How is it supported at the bottom? Is it wedged into the ground or into a stand? 33ft is quite long for a pole that's only supported by a person .... How did you find it handled?
I did actually try this a few years ago with some long pipes of some sort .... it may have even been bamboo canes! Let me see if I can find one of the photos I took ........
Blimey ... it's taken me over an hour to search through my photos (000s), but I finally found it!
Taken from the top of a rather wobbly bamboo'n'string construction!
Hogster is offline Find More Posts by Hogster
Old May 07, 2005, 10:19 PM
Bluecor is offline
Joined Mar 2005
Ha! Good idea! Now I am feeling really dumb. :P
Old May 07, 2005, 10:42 PM
Bluecor is offline
Joined Mar 2005
nice pictures
Old May 08, 2005, 07:53 AM
Rip-N-Burn is offline
Find More Posts by Rip-N-Burn
Rip-N-Burn's Avatar
Chandler Williams, Arizona, United States
Joined Nov 2002
The real challenge will be building a pan and tilt mount for this. Anyone have experience and care to join in on the insanity
X-10's Ninja works vey very well.
http://www.x10.com/cameras/vk74a_s_k_ps49.html
Rip-N-Burn is offline Find More Posts by Rip-N-Burn
Old May 08, 2005, 11:10 AM
mad mike is offline
Find More Posts by mad mike
I crash, therefore I FLY!
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
Using your car or truck to anchor the base plate is a good idea. But if you can't park where you are going to shoot, include a hand truck or dolly in your kit and include some sand bags.
That way, you aren't tied to your parking space.
Mike S.
Spring Hill, FL
mad mike is offline Find More Posts by mad mike
Old May 08, 2005, 11:21 AM
CAFplanekid is offline
Find More Posts by CAFplanekid
De-Brushed user
Midland, Tx / W. Lafayette, Ind.
Joined Dec 2002
If you have to have a car to anchor it, why not just rig it up so that it bolts into the trailer hitch?
CAFplanekid is offline Find More Posts by CAFplanekid
Old May 08, 2005, 02:27 PM
mad mike is offline
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
Don't see why not, but I think I'd rather be able to place the pole where ever I wanted, instead of having to use it where ever I could park.
No reason one couldn't be built so that it could be weighted with the tire, mounted on a hitch or truck bed, and used away from the auto with sand bags providing the anchor weight.
Versitility.
Mike S.
Old May 08, 2005, 03:09 PM
De-Brushed user
Joined Dec 2002
I too think that a setup that did not require a vehicle to anchor would be best, but if you are going to use a vehicle having it plug into the trailer hitch would be a better way than having to drive onto it to anchor it.
Old May 08, 2005, 03:19 PM
Rip-N-Burn's Avatar
Joined Nov 2002
edit
Old May 08, 2005, 05:14 PM
mad mike is offline
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
I'd say that things are never easy until you think.
Nothing difficult about steadying the pole with the weight of a car sitting on a base plate (or frame.) But without the car, the base plate can still be effective by increasing the diameter and putting the weights (sandbags,) on the outter edge (for leverage.)
Of course the easiest thing to do would be to buy one. But not all can, and some simply perfer the DIY approach. (For me, that usually turns into a sub-hobby.)
Listen to the experts, they'll point out all the "whys" it won't work, then you're free to make it work. I enjoy applying that to all the hobbies I've taken up.
So far, so good.
Mike S.
Old May 09, 2005, 11:03 AM
FrankB is offline
Find More Posts by FrankB
Joined Aug 2004
Bluecor,
I was planning on ordering one of the masts in the next few days and was wondering how robust the construction is and how much wobble you get with a small camera on top at full extension. I was planning on using a Sony p200, with housing and gear I should be around 11 0z. How much does the camera weigh that you are using now?
Thanks, Frank B.....
FrankB is offline Find More Posts by FrankB
Old May 09, 2005, 11:29 AM
Hogster is offline
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
If I can hold a 20ft pole made of 1/2" bamboo canes with a 350g camera on the top steady enough to take the photo I posted above, I would think a much longer but stiffer pole would be relatively easy to hold up. Just remember that with all that weight up top and a long pole means a bigger turning moment about the point where you hold it.
By the way, I was holding that pole at arms length (using just my hands) whilst standing tip-toe on a bench!
Build Log Build thread - 6' High altitude AP plane AXI Motor Models Aerial Photography 203 Jan 05, 2007 01:32 AM
Discussion Another "which AP camera" thread Griffo Aerial Photography 3 Apr 05, 2006 02:32 PM
My "soon to be' new AP ship (build thread) Vince inTX. Aerial Photography 70 May 13, 2005 12:40 AM
ap1 - dedicated AP platform build thread nihil Aerial Photography 178 Mar 15, 2005 11:27 PM
Looking for AP camera's for sale thread Yukonho Aerial Photography 3 Jul 31, 2004 05:58 PM
