Old Apr 09, 2002, 08:00 AM
Mikerjf is offline
Find More Posts by Mikerjf
Wayne, NJ
Joined Apr 2001
Hobbico P40 RC conversion
Just finished/flew the P40. It's a 20 inch span free flight from Hobbico. Used a GWS S1 drive, 6x5, 8c 220mah nimh pack GWS rcvr and servos and Castle Pixie 7P. AUW is 5.7 oz. First flight was in a pretty good breeze, had the throws really low , but it flew great. The 8c pack might be overkill, spent most of the flight at half throttle. Gonna try a 7c pack this week.
Mikerjf is offline Find More Posts by Mikerjf
Old Apr 09, 2002, 08:24 AM
DBCherry is offline
Find More Posts by DBCherry
Worcester, MA.
Joined Nov 2001
Mike,
That looks REAL sweet! Haven't seen it listed, where'd you get it?
DBCherry is offline Find More Posts by DBCherry
Old Apr 09, 2002, 08:50 AM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Mike:
Great job!!!!
Can you post some pics of the innards ?
thanks
poobs is offline Find More Posts by poobs
Old Apr 09, 2002, 09:32 AM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
Did you stiffen the wing?
frankenfoamy is offline Find More Posts by frankenfoamy
Old Apr 09, 2002, 12:29 PM
Mikerjf is offline
Wayne, NJ
Joined Apr 2001
Got it at my LHS ~$17. Anyplace that carries Hobbico can get them. They've also got a Zero,Spitfire,ME109, Staggerwing Bipe
and an 18.5 inch rubber powered P51. When I get a chance I'll take some pics of the innards. Didn't stiffen the wing on this one, I decided to try it as is and keep the plane as light as possible. The wind tossed it into a vertical power on dive on its first flight and I pulled it out pretty hard. The wings are still in one piece so I guess they're OK. I'm thinking about making the Zero S280 direct, so I'll probably stiffen its wings. I've got the P51 GWS direct (3x2), I made a depron spar and skinned over the bottom with 1mm depron sheet, but the damn stuff keeps warping (anhedral). Think I'll do the Zero with 1/32 balsa sheet.
Old Apr 09, 2002, 12:32 PM
Joined Dec 2000
I stiffened the wing on a similar project as the wing would twist in hard turns. NASTY tip stall.
Old Apr 09, 2002, 12:35 PM
Mikerjf is offline
Wayne, NJ
Joined Apr 2001
What'd you stiffen it with?
Old Apr 09, 2002, 12:45 PM
burgan is offline
Find More Posts by burgan
Joined Mar 2002
what is the p40 wing area?
or at elast what are the root and tip chord lengths?
thanks
jeff
burgan is offline Find More Posts by burgan
Old Apr 09, 2002, 12:48 PM
Mikerjf is offline
Wayne, NJ
Joined Apr 2001
Mean chords about 3 1/8, areas about 57 sq inch.
Old Apr 09, 2002, 01:06 PM
Joined Dec 2000
a piece of bamboo as a spar and a piece of depron covering the entire wing bottom. Got rid of the underchamber and went faster too. The bamboo keeps the wing and depron separated for the strength of a tube.
Old Apr 09, 2002, 01:22 PM
Mikerjf is offline
Wayne, NJ
Joined Apr 2001
That's pretty much what I did with the P51. I used a 3/16 wide piece of 3mm depron and glued it top and bottom with Elmers. When the Elmers dries it makes the spar very rigid (I'll probably do the Zero with carbon fiber rod). The wing came out stiff enough, but I can't keep the depron from warping. Did yours warp too?
Old Apr 09, 2002, 01:43 PM
Joined Dec 2000
No warping.
I used polyurethane glue and placed a sand bag on top of the wing until the glue cured.
Old Apr 09, 2002, 03:14 PM
burgan is offline
Joined Mar 2002
what is the empty p-40 weight?
do you have a good estimate of waht this plane weighs after one takes out battery pack and stock engine?
thanks,
jeff
Old Apr 09, 2002, 03:36 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
1-3/4 oz. without the decals.
DNA is offline Find More Posts by DNA
Old Apr 10, 2002, 07:06 PM
Jim C is offline
Find More Posts by Jim C
Jim C's Avatar
Lexington, Kentucky U.S.A.
Joined Oct 2000
Mikerjf-
Thanks for posting the info on your Warhawk. I have one waiting on the shelf ready for conversion! So it was great timing to see what you did with yours!
For those who don't have one of these...here's what it looks like as received in the box...
(hmmm my first post with a picture... <crossing fingers for luck>)
Jim C is offline Find More Posts by Jim C
Zero RC conversion Hobbico's Flyzone Electric Free Flight thecurriculum Parkflyers 35 Jan 14, 2013 04:36 AM
hobbico free flight to rc conversion Mal Foamies (Kits) 4 Feb 18, 2004 12:00 AM
GWS free flight P51 RC conversion iamDerrick Parkflyers 10 Mar 13, 2002 10:00 AM
Free Flight to RC Conversion RCFlybry Scratchbuilt Indoor and Micro Models 1 Dec 06, 2001 08:07 AM
Hobbico P40 Taniwha314 Parkflyers 15 Jun 25, 2001 12:08 AM
