Old May 06, 2005, 03:27 AM
Danny Troy is offline
Find More Posts by Danny Troy
Danny Troy's Avatar
Westchester County, NY, USA
Joined Jun 2000
2 brushless motors with one ESC?
I know this has probably been discussed in the past but here it goes again.
I have a couple of applications, one being a tiny twin flying wing (the MiniTwin), and I was wondering if people are successfully powering two BL motors using one ESC. I have heard that as long as the two motors are exactly the same, and the ESC isn't overloaded, it would work.
Has anyone actually been using this type setup?
Danny
Danny Troy is offline Find More Posts by Danny Troy
Old May 06, 2005, 08:05 AM
Tim Cullip is offline
Find More Posts by Tim Cullip
Tim Cullip's Avatar
United States, NC, Pittsboro
Joined Aug 2003
I've used a Phoenix CC10 driving two cdrom motors in a scratch built p38 lightning.
The motors were wired for fairly low power - together at full power they draw about 3amps
on a 2 cell lipo setup.
I think startup is the big hurdle with 2 motors off of one controller. If you can get reliable starts, then running should be fine.
Mine starts a little rough sometimes, and fails to start both maybe 2% of the time.
I love my setup. Again, mine is a small, low powered setup: all up weight on this 28" bird is 6oz.
Tim Cullip is offline Find More Posts by Tim Cullip
Old May 06, 2005, 02:33 PM
Danny Troy's Avatar
Joined Jun 2000
Thanks for the info Tim. That's what I wanted to hear. And BTW, nice P-38. Mine still has the stock S-480s, but it flys like a dream. I forgot the manufacturer, but I bought it from Hobby Lobby a few years ago. This one has a fiberglass fuse and built-up wings, so it needs the 480s for power.
I'm thinking for the small twin I can use my 18 amp ESC for the two little Feigao motors. That should be well within the ESC limits. For a twin BP-21 application I'll use my Phoenix 25 and see how that works out. It might be marginal at full power though.
Old Oct 29, 2005, 01:49 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
How did it go?
Did you get the two feigaos to work on one ESC?
BEn_E
Ben_E is offline Find More Posts by Ben_E
Old Oct 29, 2005, 03:41 PM
Danny Troy's Avatar
Joined Jun 2000
No good. On the mini flying wing I had to go with two 10 amp ESCs. On the P-38 I just went with two inexpensive 18A ESCs feeding a pair of Himax inrunners. I recently bought a CoolRunning ESC and I'd be interested to know if anyone tried to run two motors with one of these ESCs. The problem is probably the ESC, not the motor.
Old Oct 29, 2005, 06:29 PM
ray foley is offline
Find More Posts by ray foley
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
The rule for multi-motor brushless applications is: N motors, N ESCs, 1 to N batteries.
Nothing else is reliable or particularly safe.
And yeah, this subject has been raked over time after time. Same results, see above.
Also:
Make sure you remove the red lead (+v) from the connectors of all but one ESC or make up a y circuit that only gets +v from one ESC.
Good luck, ray foley
ray foley is offline Find More Posts by ray foley
Old Oct 29, 2005, 06:36 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
www.m-a-e.com has a new design out, that uses twin westport cdrom motors and one esc. You could write Randy and ask what the secret is.
MKH
MKH is offline Find More Posts by MKH
Old Oct 29, 2005, 06:43 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Also:
What is an "N" Motor? Also what are "N" ESC's & Batteries. Please define "N".
-Thanks-
mrebman is offline Find More Posts by mrebman
Old Oct 29, 2005, 09:06 PM
volare est vivere
ray foley's Avatar
Joined Jan 2005
Remember algebra? N is a variable, sometimes read as "the number of" whatever you like.
So if N=2 then the multimotor rule becomes, 2 motors, 2 ESCs, 1 or 2 batteries.
Or if n=3 then the multimotor rule becomes, 3 motors, 3 ESCs, 1 to 3 batteries.
For larger values of N (3,4,5,etc.) The rule still applies but the wiring becomes more complex. This application is left to the student as an academic exercise.
And for you college calculus types:
What is the integral of (1/cabin)d(cabin)?
ttfn rjf
Old Oct 29, 2005, 11:54 PM
mrebman is offline
Joined Nov 2000
ttfn rjf
That's the complicated way of saying "You need (2) Brushless ESC's to run (2) Brushless motors.
-Mike-
Old Oct 30, 2005, 12:06 AM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Kontronik has sold a twin brushless setup for years that works just fine. CC are not the best choice for twins but some setups work.
http://www.kontronik.com/DSet400480Motse.htm
rpage53 is offline Find More Posts by rpage53
Old Oct 30, 2005, 08:44 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Starting twins on 1 esc:
It's not good practice.
It may work on very closely matched motors.
I will fail when you least expect it and need it most.
You can easily burn up an esc if one fails to start.
You can easily spin in a twin if only one motor runs.
Factory matched systems probably work fine, but is there a model replacement guarantee?
Nuff said?
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 30, 2005, 09:18 AM
Spadkun is offline
Find More Posts by Spadkun
Englishman in Japan
Spadkun's Avatar
Takasaki, Gunma, Japan
Joined Nov 2003
Try to make sure everything is identical, same motors, same length of wires etc.
Connect to the same phases on both motors.
I read a lot about it , seems you have a 50/50 chance.
I have profile P38 with two Komodo CD motors running on a single CC25 controller, works every time.
Good luck
Spadkun is offline Find More Posts by Spadkun
Old Oct 30, 2005, 10:34 PM
volare est vivere
ray foley's Avatar
Joined Jan 2005
For you calculus buffs out there.
answer: natural log cabin.
groans expected
rjf
Old Oct 31, 2005, 01:28 AM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
About 4 years ago I had a twinjet w/ 2 bl aveox1005/5 on one 60amp bl ESC. drew 45-50Amps, just had to make sure both motors started quickly and it worked fine. It did blow the big capacitor once which I replaced and had no further problems.
At one time mutiplex sold a dual motor bl ESC, but it wasn't rated for the amps I was pulling. don't know if they make it.
bmiller is offline Find More Posts by bmiller
Two brushless motors with one ESC is this possible davereap Power Systems 7 Nov 18, 2005 05:17 PM
Twin brushless motors with ONE ESC is it possible for MY E-STARTER TWIN ? agapornis Power Systems 3 Jun 05, 2005 11:45 AM
2 Brushless motors on one ESC? ToddL Castle Creations 4 Aug 04, 2004 11:31 PM
can you run 2 brushless motors off of one esc? jeff262 Power Systems 4 May 30, 2004 11:39 PM
Can you run 2 brushless motors off of one ESC nikolaus_c Power Systems 1 Jul 05, 2003 11:44 AM
