Old Jun 23, 2005, 02:21 AM
maarset is offline
Find More Posts by maarset
I can drift a heli
maarset's Avatar
USA, CA, Sacramento
Joined Mar 2005
Well I went back to the IPS drive and it seems powerful enough. This is now my favorite plane!
After many repairs to the wings from hitting trees and the ground the wings are now pretty much parallel to the ground. The wings no longer angle up. Is this going to effect how the plane flys?
I'm thinking that the angle of the wings allow for easier flying. But since I have alot of experience with the plane now it shouldn't be an issue. Guess I'll find out when I go fly it again.
maarset is offline Find More Posts by maarset
Old Jun 26, 2005, 08:02 PM
Wufnu is offline
Find More Posts by Wufnu
Pickin' an a Flyin'
Wufnu's Avatar
United States, TN, Knoxville
Joined Apr 2004
Dihedral will aid you in rudder-only turning. Try to put some more dihedral back in
Wufnu is offline Find More Posts by Wufnu
Old Jun 27, 2005, 10:03 AM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
If you run bracing threads from the top of the cabane struts (the ones by the cockpit) out to the bottom of the interplane struts and tighten them up you'll pull some dihedral into the bottom wing which will then push (through the struts) the same amount of dihedral into the upper wings. I read this tip for two of my other bipes made by A Company We Won't Mention Here and it worked great. Bracing threads/wires will also make your Moth a tad more robust if you really have to go flying into stuff!
I'm with Wufnu on this. Before I put some dihedral into them both my unmentionables (well actually Jenny and Scout) were real pigs in a turn and would side-slip away. Now the Jenny is OK and the other (also with bashed up wings) is, if not good, at least keeping out of the trash can which is where it had been headed. Give me more slowfly bipes Mr Lin!
Roger Lombard is offline Find More Posts by Roger Lombard
Fs: GWS Pico Moth unbuilt w/custom CD Rom brushless motor dawnron1 Aircraft - Electric - Airplanes (FS/W) 8 Aug 23, 2004 02:00 PM
GWS Pico Moth Kit plus - good deal? bhenry Electric Plane Talk 7 Jun 27, 2004 11:37 AM
F/S Almost NIB GWS Tiger Moth 400 Trikster Aircraft - Electric - Airplanes (FS/W) 1 Mar 29, 2004 02:44 PM
f/s,4 nib gws pico+f/bb servos Dennis Everett Aircraft - Electric - Airplanes (FS/W) 5 Feb 17, 2004 12:08 AM
F/S 2 ea. GWS Pico BB Servos Aobid Aircraft - Electric - Airplanes (FS/W) 1 Jan 14, 2003 09:51 AM
