Illinois
Joined Feb 2004
Ok here are some plans I’ve found over the years.
The first link has plans for 5 ornithopters, scroll down to the bottom of the page. http://www.ornithopter.org/indoor.shtml This plan is from the October 1935 issue of Model Airplane News. http://www.theplanpage.com/Months/2105/flapper.htm This is a link to a thread that has a pdf. file with 4 interesting plans. http://www.ornithopter.org/forum/showthread.php?t=34 The Spencer Orniplane http://www.ornithopter.org/orniplane.shtml You can find some drawings on Patricia’s site. It has the drawings of her Behemoth 4, And John Mack’s “full size” dragonflys. http://www.ornithopter-pilot.com/Orn...27s_Forum.html 3 plans are available on Yohei Takatani site. Click on the picture to view the plan. http://homepage1.nifty.com/akatombo/e-product.html There used to be plans on this site for the dragonfly 1 as well, I can’t seem to find it though. I know it can be found somewhere. I actuialy built one of these, it did fly, but my version came in overweight, still have it. There are more plans out there. I can picture one or two more clearly in my mind but can’t remember where in the web they are. I’m sure Willi will have some links to add. |
Illinois
Joined Feb 2004
I don’t know if anyone has converted any of these over to electric, but I have heard of freebird electric R/C Conversions.
Speaking of R/C ornithopters here is a link to the Cui Cui Plans http://www.rcgroups.com/gallery/show...sort=1&cat=500 And the English version of the text from the construction article, in MS Word format. I was going to convert these to PDF but I think that would just make them bigger. I will continue to post other plans here as I find them. I hope others will consider doing the same. Zach |
The plastic bead on my Luna** wore through.
I replaced it with a Micro-X Teflon washer backed up with a brass one. It seems to perform much better after the change. Pat MacKenzie ** the Luna is sold at Ozone. About the same size as the Freebird but it is a "double flapper" design. Very durable. I usually give it to kids at indoor meets, and they have only managed to break it once. |
Latest blog entry: er9x heli 450 heli set up (flybar)
Illinois
Joined Feb 2004
Teflon Washers
I bought mine from FAI Model Supply. They offer them as a hop up part for a Science Olympiad plane. Hers a link to the page where they are listed. http://www.faimodelsupply.com/fai-sorcerer.htm
I’m going to experiment using Teflon tubing along with the Teflon washers. It would be nice if someone made Teflon coated glass or plastic bearings. The Teflon bearings I have been able to find were too large for our application and had not been drilled out. Friction can be a pain, Zach |
Their address is: Micro X PO Box 1063 Lorain, OH 44055 440-282-8354 As Zach pointed out, other suppliers of F/F and indoor stuff probably have them as well. Pat MacKenzie |
| Thread Tools | |
| ornithopter plans | _daniel_ | Ornithopters | 11 | Mar 13, 2005 08:30 PM |
| Ornithopter plans ? | steve lewin | Ornithopters | 9 | Sep 13, 2002 09:37 AM |
