Multiplex Easy Star Thread #19, Loved and respected by Beginners and Seasoned Flyers
Hello And Welcome To Thread 19.
It has not been even a month ago that thread 18 was started. So in less than 30 days "we" have gone over 500 messages. If you still do not have an Easy Star, get one and you will see why it is such a loved airplane. Perfect for those wanting to start and not sure of which way to begin. And wonderful for those 'seasoned' pilots who just want a plane to enjoy a fun but EZ (Easy) flight. Here is the link to part 18, Multiplex Easy Star Thread #18, Voted By Owners To Be The Best Airplane Ever! http://www.rcgroups.com/forums/showthread.php?t=356824 This forum is for those who love there Easy Star (EZ) and have made many modifications to it. From time to time you will see other "off topic" items come up. That is because this forum has become like a large family. So come and join in on the fun. Welcome to the family, the family of EZ owners. Brandie |
Vladm-
On another thought, take a ruler edge and put it fuselage direction under the horizontal stabilizer. If you see 'light' on either side of the elevator 'hinge' area, not the hinge groove itself, just the stabilizer rear and the elevator front, then your elevator is reflexed 'down' and that will nose dive the plane also. Try a little up trim or reset the elevator push rod connector forward a little more on the push rod to level it out. That's all I can think of besides what's already been mentioned, and I think this was too but just covering the bases!
I have a new desire…it’s ok…it is Multiplex and it is elapor…and it looks good
http://www.multiplexusa.com/product_fs.htm |
Sarge, I sort of knew you would have the tear issue covered.
![]() Bearded Flyer says: "The rudder moves smoothly however I still have the pronlem of it not centering consistantly." I wonder if it might be the "play" in the hole in the servo arm. Mine seems to do this as well occasionally. Just a slight offset rather than the rudder sitting even with the stab. Only occasionally does there seem to be an effect while flying, sometimes it seems to sit this way and produce a slight turn, but by just bumping the stick against the turn, it centers. I suppose the play in the servo hole could be fixed by putting a tiny tube on the bend or connector where it passes through the servo arm, then if the tube is too big, trying to increase the size of the hole in the arm to fit it snugly, but it hasn't been enough of a problem to cause me to go to all that trouble to fix it. Does yours cause problems during flight? tt Bill Lumberg, that thin CA is really dangerous stuff, I had no idea it had run down between my thumb and finger, couldn't feel it at all. Astroglide? sounds like a flying product. ![]() ----- Thanks Brandie for starting the new thread.
Hammer Head
You need to get on over to:
http://www.rcgroups.com/forums/showt...25#post3706316 and see what we have been talking about over there! Mine has been trying to work out what is should be called: "Mario", "Zap-ata" (it is glued with Zap-a-Gap) or "Mona Easa". All contributions gratefully accepted! Cheers Numb Thumbs
for any aussie lurkers out here looking to get an EZ* modelflight.com.au now has them in stock.
I just ordered one for $AUD99.00. Talk to chris@modelflight.com.au. Happy flying dudes
TN, USA
Joined Feb 2005
(I'm from Europe)Shaun, thanks a lot for explanations - I'll give it a try (as soon as this @#$ rain will be over) Vlad. |
![]() Personally, there are advantages in each system and I use both when necessary and sometimes interchageably. Kinda like Roman and Arabic numerals. Each has their place to be used for a given effect. At least we aren't using cubits! I'm curious to see if you get your EZ* gliding well. It shouldn't be too hard. It's pouring rain here in Central California as well... starting to think about building an Ark... maybe I need to look up a cubit again after all!
| Thread Tools | |
| Yippee! Multiplex Easy Star Thread #18, Voted By Owners To Be The Best Airplane Ever | Grassy Knoll | Foamies (Kits) | 511 | May 09, 2005 03:32 AM |
| Multiplex Easy Star - thread 7 | Zoomzoom | Foamies (Kits) | 506 | Jun 21, 2004 04:40 AM |
| Multiplex Easy Star - thread 6 | Zoomzoom | Foamies (Kits) | 495 | Jun 03, 2004 12:36 PM |
| Multiplex Easy Star - thread 5 | Treetop | Foamies (Kits) | 503 | May 18, 2004 05:47 PM |
| Multiplex Easy Star - thread 4 | jcosta | Foamies (Kits) | 501 | May 03, 2004 05:15 AM |
