Old May 04, 2005, 08:15 AM
davidb1 is offline
Find More Posts by davidb1
Joined Apr 2005
thinking of going seprats on my dragonfly#4 help wonted
as i dont under stand all this
can sumone put it in english as to what i will need whear to get it in uk or uther
the dragonfly# 4 is the 2005 vershion and came with a 6 chanel transmiter so will i still be abul to yous this, the heli is 4 chanel fp
brushles moters or brushed ? witch is best
only going this way as semms to be cheper to repaer in long run ?
and better fo fly/learn with
can you help please
regards david
ps lets not go in to the speeling thig again
davidb1 is offline Find More Posts by davidb1
Old May 04, 2005, 09:12 AM
Biffa is offline
Find More Posts by Biffa
Multi rotors and foamy planks
Biffa's Avatar
Bedford, UK
Joined Dec 2004
David,
Check all this out, should help a little
http://www.rcgroups.com/forums/showthread.php?t=355881
Biffa.
Biffa is offline Find More Posts by Biffa
Old May 04, 2005, 05:06 PM
Shortarse_Yoda is offline
Find More Posts by Shortarse_Yoda
Shortarse_Yoda's Avatar
West Sussex, UK.
Joined Mar 2005
Your Dragonfly is only 4 channel and the radio gear is not compatible with any other make it would seem (I know I have the same helicopter!) Going separates will not make a bit if difference to you learning to fly and will cost you at least twice the initial cost of your complete helicopter as you will have to be I new transmitter. Not becusae there is not eneough channels but because it won't work with Walkera receivers (nothing does!)
My advice would be to stick with the standard 4 in 1 replace the standard servos with 2 half decent ones, put a heatsink on the tail motor make a hole in the top of the canopy the size of a ten pence (main motor cooling) and when you get on to forward flight make your self some blade springs. Just do a search on threads for 'death wobble' if you haven't done so already.
Shortarse_Yoda is offline Find More Posts by Shortarse_Yoda
Discussion help on my dragonfly! DerekPB Micro Helis 2 Jan 08, 2007 08:39 PM
Discussion help with were to mount light on my R-4 burro breath Scale Kit/Scratch Built 1 Feb 06, 2006 07:31 PM
Question Help!!! I spilt fuel on my Futaba (4-ch YF) radio srbangash Radios 17 Jun 24, 2005 11:33 AM
Tailrotor extremely sensitive on my Corona!Please help! larsen2000 Electric Heli Talk 2 Jul 10, 2004 02:22 PM
Problems with few things on my RS4/ Please help latindragon79 Car Talk 1 Jul 06, 2004 05:51 PM
